Paging WavyDavy et les autres - X marks the spot
Discussion in 'UK Motorcycles' started by Pete Fisher, Nov 28, 2006.
  1. Pete Fisher
    Pete Fisher Guest
    Have you seen the high definition (but very old) aerial photos of France
    at mappy yet?
    http://www2.mappy.com/sid3YGEYIF9Iu/Mn21w/CGM?fsl=m1;csl=m1;gsl=m1;msl=m1
    ;out=2;xsl=1;guide=1;gb=air
    | Pete Fisher at Home: |
  2. Pete Fisher
    Pete Fisher Guest
    Bad form etc.
    A working URL (but you would have found it easily anyawy):
    http://www16.mappy.com/sid3+d2F6ZWxDfMn21w/CG?fsl=m1;csl=m1;gsl=m1;msl=m1;out=2;xsl=1;gb=air
  3. Pete Fisher
    WavyDavy Guest
    lI copied it in bits...
    And it was really nice trying to trace some of the trails I took ginge, dnc
    and spete along last month. If a bit weird as the pics all have greenness
    and things that are old and/or not there or things not there that are there
    iyswim...... :)
    WavyDavy, Nov 28, 2006
  4. Pete Fisher
    WavyDavy Guest
    Bad form. On checking Cahors, I'm guessing 5 years out of date,
    minimum......
  5. Pete Fisher
    Dave Emerson Guest
    When my fil was over last year I was showing him GoogleEarth.
    All was fine until we zoomed-in on his house and he went into a panic
    because his car wasn't parked on the drive (a friend having given him a lift
    to the airport).
    It took me ages to explain that the pics weren't "real time"!
    Dave Emerson, Nov 28, 2006
  6. Pete Fisher
    Pete Fisher Guest
    Indeed. I have managed to 'virtually' suss out a couple of possible
    newroutes in our area using it and a largish scale map (the blue ones
    from supermarkets - can't remember the name). Problem is that in a
    heavily forested region you often cannot see the line of the track on
    the photos.
    Now this is available I will be looking more closely at the digital
    photo I took of the enduro route pinned up at the start finish of the
    one I went to watch in October. Still haven't worked out exactly where
    the famous Gilles Lalay Classique 'Dead Crow Hill' is.
    From the ones of my place I reckon those particular shots were taken as
    long as 15 years ago or more (size of trees). The 'joins' are quite fun.
    the big lake was obviously choppy from wind on one shot and flat calm on
    the adjoining one.
  7. Pete Fisher
    I'm guessing at around 2000/2001. I can't be sure, but the car parked
    in our yard is certainly a long black one, which would point at the
    Volvo, hence after we moved in in 2000. But there's a roundabout at
    the bottom of our drive now which isn't there, and no hole for our
    pool, both of which I think were started by late 2001.
    So about a year older than the google earth one, then, which has the
    roundabout and just a hole for the pool. About the same level of
    detail in our area too.
    _______
    Ace, Nov 29, 2006
  8. Pete Fisher
    Pete Fisher Guest
    We are just a blur on Google Earth. Seriously 'stick the pig on the wall
    to watch the band go by' rural it is [1].
    [1] A very whimsical 'folk lore' reference from my native 'black
    country'[2] (Google is your friend).
    [2] Don't bother - I've heard them all before.
    Pete Fisher, Nov 29, 2006
  9. Pete Fisher
    Heh. We're in hi-res, I guess, due to our relative proximity to Basel
    and Mulhouse (~25km each) rather than any inherent interest in the
    area itself.
    47°32'54.61"N
    7°19'31.57"E
    If you're interested.
    _______
    Ace, Nov 29, 2006
