Paging Triumph Daytona (poss. speed triple) owners..
Discussion in 'UK Motorcycles' started by Christofire, May 12, 2004.
  1. Christofire
    Christofire Guest
    I need to do my steering head bearings. The problem is that
    fancy-shaped top yoke nut needs a special tool to remove it. While
    these are available I'm still looking at about 30 quid for what's
    essentially a socket.
    Does anyone have one that I can borrow for small recompense, or know of
    a method to get this one off?
    I plan to replace it with a normal nut until such time as putting it
    back is preferable. Anyone know of a reason why this is "bad"?
  2. yep. I'll bring one up this weekend and will phone to arrange a
    meeting place.
    Adie
    Triumph 955iSS / GSF600 bandit
    MRO#11 BOTAFOF#7 BOTAFOT#130 DIAABTCOD#17 MIB#24 YTC#16 BOB#15 ex-UKRMMA#22
    Adrienne M Jenn, May 12, 2004
  3. by do, do you mean tighten or replace?
    tighten you'll have no problems (apart from needing another BFO
    socket), if its replace then expect a couple of days work and an angle
    grinder cos you *wont* be able to get the fucker off. Dont do what Tim
    did and grind too much off!
    Adie
  4. Christofire
    Robbo Guest
    Well I got a 3/4" drive socket set that goes up to 56mm so what size you
    need?
    Robbo
    BMW K100 RS 1984
    BotaFOF #19. E.O.S.M 2001/2002/2003.
    B.O.S.M 2003/4.FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 12, 2004
  5. Christofire
    Tim Guest
    If you can get near some kind of hoist to lift the entire bike off the
    ground you should be able to do the whole job in about 1 hour. No need
    to fart about removing the plastics and all the other crap.
    Thanks Adie :)
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, May 12, 2004
  6. Christofire
    Christofire Guest
    Erk.
    There's a pronounced knocking coming from the bars, too much to be just
    the discs moving in the carriers.
    I'm hoping tighten up will be enough, but somehow I suspect it's going
    to be replace.
    With a spot of luck, a manual and a stand should be here by the weekend
    which will make it a bit easier than it is now.
  7. Christofire
    Christofire Guest
    Well, it's a cylindrical nut (i.e. not hexagonal) with a number of
    small cylindrical holes around the top, in which pegs locate and turn
    the nut.
    This is why I want to replace it with something a little easier to
    do/undo.
  8. Christofire
    Tim Guest
    Erk.
    to be replace.[/QUOTE]
    It'll be replace, you can only re-tighten so much.
    What kind of stand are you going to use?
    Tim, May 12, 2004
  9. Christofire
    Christofire Guest
    I don't know how much it's been done before, but it seemed ok when I
    picked it up. It's on 12500 miles now.
    An abba superbike. I've got a couple of options for raising the front.
  10. Christofire
    Tim Guest
    [/QUOTE]
    Oh well enjoy removing all the plastic and maybe the exhaust system.
    Tim, May 12, 2004
  11. Christofire
    Tim Guest
    the nut.
    [/QUOTE]
    I have a vague memory that it's not so simple because the threaded but
    is sunken in the top yoke.
    Tim, May 12, 2004
  12. Christofire
    Christofire Guest
    You're a bundle of joy, aren't you.
