I'm looking to buy a 1/2" socket set. After perusing the Teng Tools catalogue I noticed they do sockets in 6 and 12 point varieties, Bearing in mind it's for exclusive use on the bike, which should I go for ? Oh, and what's the pro's/cons of each type ? Thanks, Mike. -- '02 GSF1200 in silver Email address spamtrapped. Remove "your clothes" to reply.
You do not want a 1/2" drive socket set to work on a bike, mate. For one thing, the ratchet head size will preclude access to a large proportion of fasteners and for another, 1/2" sockets in 6mm and 8mm sizes are awful clunky things. Get a 3/8" set. It is cheaper (and cheaper to buy those odd sizes that you _will_ need - and will cover any size that you can get in 1/2". Go for 6-point - 12-point is so old fashioned and far more likely to slip off, or damage a stubborn fastener. Something that advertises that it bears on the flats, rather than the points of the hexagon is much preferable to a socket (or spanner, come to that) bearing on the points of the hexagon. I'd go for the biggest Halfords Pro set they do, with all the various extension sizes, wobbly bits and universal joints. All the extra bits are the ones that make working on a bike a pleasure rather than a pain.
Seconded. Or at least just get a small set with larger sockets in, they can be handy for engine mounts and wheel bolts. Yes indeed, I never found a bi-hex socket any use, except to round off things. Or Sykes Pickavant, I have a set of those - lifetime warranty too. If at all possible, look for the 'flank' drive design too, these have a small circle cut out of each corner and help reduce rounding off.
Already got a 3/8" set. It was mainly for the rear wheel spindle, 32mm. Maybe I'll just get a 32mm socket to go with the 1/2" torque wrench I just got off ebay. I'll go for the 6 point then. 12 points just looked so much more "high tech" to me ;-) Do Teng socket bear on the flats ? Doesn't mention it in the catalogue. I've had my Teng 3/8 set for 3 years now and its been great Once again ukrm saves me some money Thanks guys. Mike. -- '02 GSF1200 in silver Email address spamtrapped. Remove "your clothes" to reply.
"Flank drive". I'd attest to these; they fucking rock. I have a mixture of sockets and whatnot; mainly 3/4" drive, then 3/8" and finally, a few 1/2" mainly for the big stuff like Triumph single-sided swinging-arm rear-wheel nuts...Bit redundant now... -- | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12 |# You don't believe me | "Experience is the worst teacher. |That the scenery | It always gives the test first |Could be a cold-blooded killer. | and the instruction afterward." ***** human response from wik at blueyonder dot co dot uk *****
teng do combo sets with 1/4 , 3/8 and 1/2 inch alternatives if your budget allows i would go for these gives your kit a bit of future proof use
If the 1/2" is for the "big stuff", wtff is the 3/4" for? -- | ___ Salad Dodger |/ \ _/_____\_ GL1500SEV/CBR1100XXX/KH500A8/TS250C |_\_____/_| ..62743../..14835.../..3157./.19406 (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4 PM#5 |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11 WG* \ |^| / IbW#0 & KotIbW# BotTOS#6 GP#4 \|^|/ ANORAK#17 '^'
Goldwings. -- Platypus - (unreal) VN800 Drifter, R80RT, Z200 DIAABTCOD#2 GPOTHUF#19 BOTAFOS#6 BOTAFOT#89 FTB#11 BOB#1 SBS#35 ANORAK#18 TWA#15
I deliberately avoided use of that term as I assumed it to be a trademark of Snap-On, Inc. They do indeed - not just for corroded nuts either - they don't slip off anything like as easily and don't mark up the fastener as badly as the point-tearing-off types.
I use 3/8" gear for that too - a decent quality 'big' socket (like the 32mm 3/8") costs about a fiver. Fearing teaching you to suck eggs, you do know not to use your torque wrench to _un_do that big nut, don't you? Teng kit is decent stuff. Dunno if they bear on the flats or the points - if you look at the 'business end' of the socket and it has what appears to be holes in the corners rather than a sharp corner, yes. If it has a clearly-defined 60 degree angle, then it will bear on the corners. 6-point kit is no higher or lower tech ime, but does a better job - doesn't look as jewel-like in the box, is all.
I doubt that you'll bent the wrench but you do stand a chance of buggering up the springy ratchety bits inside.
Arse. Perhaps I'll just stick to large, medium and small... [slaps self round chops] I'm a total fucking moron, aren't I? I appear to have just invented an entirely new socket drive size. [hides] -- | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12 |# You don't believe me | "Experience is the worst teacher. |That the scenery | It always gives the test first |Could be a cold-blooded killer. | and the instruction afterward." ***** human response from wik at blueyonder dot co dot uk *****
Ah. Not having ever used a torque wrench, I did not know that. I tend to go for the "1 grunt, 2 grunt" technique...
[emerges] [slaps other cheek] *1/4"* drive and t'other way arou-- you fucking know what I mean, even if I'm incapable of expressing it! ;-) -- | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12 |# You don't believe me | "Experience is the worst teacher. |That the scenery | It always gives the test first |Could be a cold-blooded killer. | and the instruction afterward." ***** human response from wik at blueyonder dot co dot uk *****
