Paging TOG.
Discussion in 'UK Motorcycles' started by Zymurgy, May 4, 2004.
  1. Zymurgy
    Zymurgy Guest
    Being as I singularly failed to say any words to you over the weekend
    1) Thanks for the trip, as always. Excellent weekend.
    2) Where can I get a rebuild gasket set for a CB250N carb, at a
    reasonable cost. Do you have one in your gasket box ? Failing that,
    just the o rings for the inlet tract where they attach to the carb
    body and a float bowl gasket.
    Cheers,
    Paul.
  2. Zymurgy
    Robbo Guest
    Zymurgy in "Quiet as usual" shocker
    Thought it were quiet on here
    Feckin make one or alternatively tell me the diameter and thickness and I'll
    look in the big box of O rings at work.
    or
    NRP
    Contact Details
    Addr: Unit 2 Station Approach, Victoria Station, Manchester, Lancashire.
    M3 1NY
    Tel: 0161 8328646
    Opening Times
    Mon: 10.30 until 18.30
    Tues: 10.30 until 18.30
    Wed: 10.30 until 18.30
    Thur: 10.30 until 18.30
    Fri: 10.30 until 18.30
    Sat: 11.00 until 16.00
    Sun: Closed
    Robbo
    BMW K100 RS 1984
    BotaFOF #19. E.O.S.M 2001/2002/2003.
    B.O.S.M 2003/4.FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 4, 2004
