Paging TOG....Rebuildable?
Discussion in 'UK Motorcycles' started by Robbo, Jan 21, 2005.
  1. Robbo
    Robbo Guest
    Robbo, Jan 21, 2005
  2. Simon Atkinson, Jan 21, 2005
  3. OK.....
    2001 model, registered 24/10/2001 on a '51 plate.
    2 owners from new, has done 15,000 miles and has a full Triumph service
    history.
    OK
    <snip>
    Light damage is as follows:
    Front fairing - got replacement part (needs painting)
    That'll be a ton, then.
    Screen - got replacement part
    Headlight - got replacement part
    Pannier - got replacement part  (blue - needs painting).
    And again.
    The replacements are a pair, the one you do not need it scratched and
    could be sold.
    Side fairing is scraped  - Easy repair and needs painting.
    Another ton.
    Right front indicator.
    40 quid. I know. I've bought one.
    Mirror (right) - got replacement part
    Headlight & fairing support frame. This is a steel frame that I am sure
    could be straightened, with a little patience, or buy a new one.
    Right - this is the kicker. These component is over ukp300, IIRC. It's a
    really expensive bit.
    *Forget* trying to straighten it. You will *never* know whether it's
    straight until you try and replace all the body panels. There are well
    over 60 fasteners holding on a Trophy's bodywork - I counted over 50
    when I checked the shims on mine, and that didn't involve removing the
    centre fairing section and headlight. And if even one, never mind half a
    dozen doesn't line up, it's a PITA.
    So this component will have to be replaced.
    In total, I think this needs ukp750 spent on it, minimum. We're up to
    ukp2650 already. Add 50% because of Tog's Law[1]. The bike's worth, in
    decent nick, 3500 tops.
    Yes, it can be repaired for less than it would cost you to buy one. No,
    it's not worth the hassle.
    [1] Any restoration job will cost you half as much again as you first
    thought.
    The Older Gentleman, Jan 21, 2005
  4. OK.....
    history.
    OK
    <snip>
    And again.
    could be sold.
    Another ton.
    thought.
  5. Robbo
    Ginge Guest
    Find a mate with a similar trumpet and compare where the things bend..
    Easy.
    Ginge, Jan 21, 2005
  6. Robbo
    petrolcan Guest
    petrolcan, Jan 21, 2005
  7. Robbo
    Ginge Guest
    I'm good at undoing **** ups. it's a skill.
    Ginge, Jan 21, 2005
  8. Robbo
    Aye. Apart from the PITA stripping the other bike to obtain a
    comparator, when you come to tweak the bent one, it will not behave.
    The only way to do it properly is to make a jig which mounts to all
    the pick-up points and bolt the twisty little fucker to it, then heat
    and bend it - and it will still never be right.
    Pip, Jan 21, 2005
  9. Robbo
    Ginge Guest
    Hmm that'l take some planning, weekends are currently OU days...
    Ginge, Jan 22, 2005
  10. Says the man who's never removed Trumpet bodywork....
    The Older Gentleman, Jan 22, 2005
  11. Robbo
    Tosspot Guest
    I've given up. I just leave it on now :-(
    Tosspot, Jan 22, 2005
