Paging Timo and Krusty - SOC sig change
Discussion in 'UK Motorcycles' started by Pete Fisher, Nov 2, 2008.
  1. Pete Fisher
    Catman Guest
    I like them.
    www.cuore-sportivo.co.uk
    Catman, Nov 3, 2008
  2. Pete Fisher
    Pete Fisher Guest
    185/60 x 14
    Given the mileage the car will be doing it will take ages to wear them
    out, and something a little more extreme would be OK.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 3, 2008
  3. Pete Fisher
    But it's the 21st century now, Pete :)
    Toyo Proxes T1-R's is what you want - I've got them on the 330 after
    unexpectedly needing a whole set (don't ask), and then found out that
    Pat Sefton runs the same tyres on his Lotus Elise. Which I had a
    drive in last week - what a phenomenal car!
    Mind you, I then had to be a passenger in my own car when Pat showed
    me the fast line down the Lythe Valley road. I managed not to throw
    up.
    Champ, Nov 3, 2008
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Champ
    Oi! Consider yourself asked.
    Wicked Uncle Nigel, Nov 3, 2008
  5. Pete Fisher
    Pete Fisher Guest
    Ha ! I admit I did first use them two decades ago.
    They seem to be the tyre of choice for serious MX5 use. Bizarrely, the
    ancient 306 diesel which accumulated the NCB used to keep the insurance
    reasonable on the new toy came with Toyos. Would you believe on 17 inch
    alloys - with no power steering. Thaey were quickly Niged out on Ebay
    and replaced with standard steel wheels and utilitarian rubber. During
    the brief period they were on they did impress me with their shit to a
    blanket impression though.
    'Nuff said. I remember Pat driving one of his mates, our mutual mate
    Toby, plus me and my rally navigator (of the Welsh Alfa incident)
    companion to watch an RAC rally stage somewhere near Shap in a borrowed
    Range Rover.
  6. Pete Fisher
    Weirdly enough I had Toyos on my 323i - also about two decades ago.
    Nobody had heard of them back then.
    Even more weirdly, I had to replace my Toyos with something else after
    some **** slashed them all.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Nov 3, 2008
  7. Pete Fisher
    heh. I think I might have mentioned it on here at the time.
    I got punctures simultaneously on the right hand front and rear
    wheels. One would just hold some air, so I slung the spare on the
    other one, and headed off to Protyre in deep dudgeon. They did their
    usual helpful thing of telling me that the other rear tyre was nearly
    worn out anyway, and they could do me four tyres for less than the
    price of three.
    That was 600 quid I hadn't banked on spending that morning.
    Champ, Nov 3, 2008
  8. Pete Fisher
    I'd not heard of them before Protyre tucked me up with a set, but some
    post-purchase research calmed my mind, and I have to say they've been
    excellent on my car.
    It's been said that the only advantage to being a passenger with Pat
    is that it means you won't meet him coming the other way.
    Champ, Nov 3, 2008
  9. Pete Fisher
    heh
    CT, Nov 4, 2008
  10. Pete Fisher
    Ben Guest
    Those stingers are a bitch, aren't they?
    Ben, Nov 4, 2008
  11. Pete Fisher
    Simon Wilson Guest
    There are a few twiddly bits. The control arms have got eccentric
    mountings which I accidentally changed whilst removing a front shock.
    I'm planning to get it down to Micheldever to get it aligned soon.
    Simon Wilson, Nov 4, 2008
  12. Pete Fisher
    Pete Fisher Guest
    Hmm, reading the forum stuff has convinced me that a high tech four
    wheel alignment session would be a good investment before giving up on
    the P6000s. Judging by some other service frequency 'indicators' I doubt
    if it has been checked properly for ages.
    Luckily there is a place within 10 miles or so that seems to know about
    MX5s and has a good reputation.
    Pete Fisher, Nov 4, 2008
  13. Pete Fisher
    I think you should stick to giving advice on bikes :).
    They need very regular oil changes if you don't want to get a rattly
    top end because the because the hydraulic tappet adjusters tend to clog
    up on engines that should have had a few more oil changes than they got.
    Not a massive issue but it's a few hundred that you can save yourself
    by sticking decent oil in and changing it regularly.
    The suspension is fully adjustable on all four corners.
    No. Get the suspension checked out by SWK and *then* barrel around
    corners. A lot of them aren't set up very well and it does make a
    massive difference. As in "**** me is this thing unstable" type
    difference.
    Timo Geusch, Nov 4, 2008
  14. Pete Fisher
    Looks quite clean, that.
    Heh. I just got the mileage cap removed on the insurance for mine, then
    happily rattled down to the easternmost part of Switzerland where my
    mum lives. Just came back a couple of hours ago, actually...
    Ewwww. I have them on the Porker and I'm not exactly thrilled, so I
    know what you mean.
    The weight of the wheels also makes a difference the ones on your car
    look like Mk2 wheels to me, you might want to see if you can find any
    of the following as those would probably be an improvement:
    - 14" BBS as fitted to some Mk1s (there are also 15" kicking around,
    but
    they're a lot more expensive)
    - Watanabe RS-8 in 14" - they look a little more 'Minilite' than the
    originals, are very similar weight, too. Instant JDM kudos as well :).
    - The original Minilite style wheel - AFAIK they're very light, possibly
    the lightest of the bunch.
    I'd stay away from 15" wheels (which I've got on mine) for day-to-day
    usage as they can make the car feel harsher than necessary.
    There were a few for sale on mx5nutz recently for very reasonable
    money. It's a very worthwhile investment (stiffens up the chassis as
    well). Just make sure that you've also got the striker plates on the
    B-post.
    As to the pikey roof, make sure it isn't too pikey - the first one I
    had had a very pikey roof that was a lot noisier than the OEM one and
    wouldn't adjust properly.
    Heh. They all do that, sir :).
  15. Pete Fisher
    Wot 'e said. For road use, that is - the sidewalls on these are a bit
    soft compared to the more track-oriented tyre like the Hankook RS2s
    that seem to be the trackday tyre of choice if they aren't sold out
    (again..).
  16. Pete Fisher
    Pete Fisher Guest
    I was fully aware that there was no service history with it appart from
    the last 5 MoT certificates. Doesn't seem too tappety on start up, but
    on cranking it up again this afternoon there was a very brief bit of
    belt squeal. The auxiliary belt looks a bit old so I will popping a new
    one on. No power steering or A/C so should be within my capabilities.
    The oil looks pretty black and the filler cap has resisted simple hand
    pressure to remove it :( The dip stick pull ring has snapped of, but
    that seems to be common.
    I aim to get the oil and filters changed before the weekend. Having
    shuffled three SOBs in to the new shed I can get at least the business
    end of the MX5 in to the garage.
    See my reply to Simon.
  17. Pete Fisher
    Pete Fisher Guest
    Ah, I was wondering about those. Could they even be non=Mazda ones with
    Mazda centres, or is that not possible?
    Having no power steering is giving a nice seat of the pants feel anyway
    so I will stick to 14s. A quick google suggests that Toyo T1Rs may not
    be available for them though.
    If you mean funny metal plates with sort of notches in them - yes.
    I'll bear that in mind. At least the new window means you can see out of
    the back, but there are cracks on the ends of the folds IYSWIM. Doesn't
    seem to leak though.
    Long may it continue.
  18. Pete Fisher
    That's certainly possible and wouldn't be a good thing as most
    aftermarket wheels are a lot heavier than the Mazda originals.
    Yeah, I just noticed that camskill only seem to have CF1s in that size.
    BTW, the 15" improve the feel (especially with stiffer sidewalls) but
    they obviously make the steering heavier.
    Especially if they're notches like the ones used as counterparts for
    the roof locks. The same locks are used at the sides of the HT as well.
    Cracks on the window? Both you and the PO know that you're supposed to
    unzip the window before you lower the roof to prevent that from
    happening, right?
  19. Pete Fisher
    Pete Fisher Guest
    I do, perhaps the previous owner didn't. The cracks are in the roof
    itself right at the outer edge 'bead'. I assume they are where the roof
    concertinas when folded. Not that have dared to try folding it down
    yet. I once had a very nasty experience with a MKII Honda Civic sliding
    sun roof.
  20. Pete Fisher
    Ah, OK. The cracks in the beading are indeed a sign that you'd want a
    new roof...
