Paging them wot knows about bolts - again.
Discussion in 'UK Motorcycles' started by gazzafield, Feb 7, 2005.
  1. gazzafield
    Dave Emerson Guest
    The combination of stainless steel (bolt), alloy (case) and copper (grease)
    can set-up an electrolytic effect that causes corrosion and it's normally
    the case that suffers most.
    This is the stuff to use with stainless
    http://www.mandp.co.uk/productInfo.aspx?catRef=520256
    Dave Emerson, Feb 8, 2005
  2. gazzafield
    Eddie Guest
    I thought it'd be something like that, but I've never noticed it
    happening - presumably because I'm looking at the SS bolt, not the alloy
    case.
    Cheers. Come to think of it, whenever I've replaced any bolts with
    stainless, I think I've always used threadlock. Something to try to
    remember in future, though.
    Eddie, Feb 8, 2005
  3. gazzafield
    Dave Emerson Guest
    Threadlock's also fine, just choose the right one, depending how likely you
    are to need to take it apart in the future.
    See http://www.loctite.com/int_henkel/loctite_uk/ Loctite also an
    aluminium-base anti-seize, same page.
  4. gazzafield
    Eddie Guest
    Well, Halfords only do one kind of threadlock. (Although, for some
    reason I can't quite fathom, I appear to have three half-used bottles of
    it.)
    Loctite in a stick! Cool!
    Eddie, Feb 8, 2005
  5. gazzafield
    Eddie Guest
    I think they get thrown into the bottom of the toolbox, slip through the
    vortex in the bottom, go off for a little holiday with the biros and the
    odd socks (during which time I have to buy another one), then reappear
    on the workbench at a later date.
    It's stopped happening know I've started storing them in the door of the
    wall cabinet - they can't get to the vortex from there.
    Eddie, Feb 8, 2005
