There's an oil leak on mine, from the oil seal in the points housing on the head. Mine doesn't actually have any points, because it's an electronic ignition model, so the housing is just empty. Oddly, it doesn't leak all the time. I saw some oil by the left-hand plug, whipped off the cover, thought: "Oooohh, that doesn't look good...", and started it up. Sure enough, oil oozed past the end of the cam. Ho hum. I cleaned it up, and re-started the engine. No oil leaked at all in five minutes' running, and none has leaked since. I wondered if some oil had pooled by the seal, and then with the bike on the sidestand, worked its way through. But it's been on the sidestand for two days now, and it's still clean and dry. I know sometimes oil seals weep if a bike's been standing and they've dried out a bit, and they often swell as the oil gets to them and stop leaking. Fork seals do it from time to time, in my experience. Anyway, the XS650 has a ball and roller crank, so has a low-pressure oil system, so it's not as if there's a helluva lot of HP oil squirting around the top end. The cam is supported in four ball races (*waves* at Guy Fawkes) and, IIRC, the end housings (points left side, auto-advance right) don't support it at all. I'm 99% certain that you can remove the housing with the engine just sitting in the frame - three screws walloped with an impact driver, and off it comes. Then whip out the seal, whip in a new one, and replace the housing. Can anyone confirm?
