Paging the XPReinstallisti...
Discussion in 'UK Motorcycles' started by JackH, Mar 15, 2005.
  1. JackH
    JackH Guest
    Yes, I know, I know... my fault for relying on something so flawed...
    I've recently reinstalled XP Professional on my main HD - the problem I now
    have is this: Anything I downloaded under my old user profile, is now sat
    locked away due each user account being set up not to share access to
    anything saved in 'My Documents', with any other users.
    I did a full install this time, but didn't format the HD first, as I wanted
    to save all the music etc., on it.
    The problem now is... when I go into 'Documents and Settings' now, even
    though I've reinstalled XP, it's still showing the old users as well as the
    currently set up ones, and when I click on my old one to get at said files,
    it tells me 'inaccessible'.
    'Fine, I'll just have to go into control panel and set all users up so they
    allow anyone to look at their documents', I initially thought... but the old
    user accounts do not show up, so I can't change the access rights!
    So... any advice how to rest the access rights on the now redundant
    accounts, given I can't actually access them through control panel,
    gratefully received - any comments along the lines of 'LINUX!', or 'Get a
    Mac'... heard them all before. :p
    JackH, Mar 15, 2005
  2. JackH
    MattG Guest
    JackH says...
    With XP home you need to start in safe mode and log on as admin, I
    think you need to do that with XP Pro as well, I don't think a user
    account with admin rights is sufficient.
    http://support.microsoft.com/default.aspx?scid=kb;en-us;272723
    MattG, Mar 15, 2005
  3. JackH
    Eddie Guest
    JackH wrote:
    Log in as Administrator, or a member of the Administrators group, and
    change the security on the directories that you need to access to grant
    permission to the relevant users.
    Eddie, Mar 15, 2005
  4. JackH
    JackH Guest
    This is normally the case, yes... but unless I'm being even more dense than
    usual, this doesn't work - to summarise, when I reinstalled XP, it's asked
    me to set up user accounts as part of doing so, but it hasn't removed the
    restrictions on the old accounts, that whilst stuff still exists within the
    folders associated with said accounts, XP now no longer acknowledges as user
    accounts in terms of setting up the access paths etc.
    Ok... so now what I've done is 'right click' on said user folders within the
    'Documents and Settings' folder, and selected 'Properties'... under sharing,
    it tells me to 'drag the folder to the Shared Documents folder'.
    If you do this, you get the following: 'Cannot create or replace <folder
    name>: Access is denied. Make sure the disk isn't full or write protected
    and that the file isn't currently in use'.
    I am not logged into the account that corresponds to this folder - as I
    said, can't, as XP isn't recognising it as such... and I'm unaware of
    anything else running at the mo that would effectively mean it was 'in use',
    thus stopping me from shifting it as advised.
    I've also gone in to Administrative Tools, and nothing is apparent.
    AARGH!
    Cheers for the advice anyway.
    JackH, Mar 15, 2005
  5. JackH
    Eddie Guest
    You didn't do what I said. Don't worry about whether they're user
    accounts or not:
    1. Go to the "Documents and Settings" folder;
    2. Right-click on one of the "old" users' folders;
    3. "Properties", "Security", "Add...", type your user name in the
    relevant box, and click OK;
    4. Tick the checkbox for Allow/Full Control, and click OK;
    5. Don't piss about with all that Shared Documents rubbish, it's not
    worth it.
    Eddie, Mar 15, 2005
  6. JackH
    JackH Guest
    And that, was the missing link.
    Cheers Rob and Eddie. :)
    JackH, Mar 15, 2005
  7. Change the properties on the directories (under c:\Documents and
    Settings\).
    You will need to be admin though.
    Thats because the default is for those directories to be only
    accessable by the owner and admin. You can either change their
    ownership (right-click on the directory, select properties. Security
    tab and change ownership) or add yourself in with full access rights
    (same way - just give your user account full access).
    Thats becuase the c:\documents and settings\ directory hold user
    profiles - not user accounts. If/when you do take access and want to
    transfer stuff out remember to change it so that you see hidden/system
    files becasue most of the useful stuff is held in hidden directories.
    Phil.
    Phil Launchbury, Mar 15, 2005
  8. That is to share them on the network. It doesn't change their security
    settings at all.
    Phil
