Paging the Tank Bag Owners
Discussion in 'UK Motorcycles' started by Donnie, Mar 11, 2010.
  1. Donnie
    Donnie Guest
    Ok, never had one and just bought the £19.99 one in lidl on a whim for
    more space.
    Other than the fact that there are probably much better ones out there
    I was wondering if anyone had any tips or things they noticed when
    using one?
    For example, the only real issues i have is that now I can't see my
    neutral light, or the indicator light, or my velcro'd on digital clock.
    None of these are major issues, I'll simply go back to my habit of
    hitting the cancel button on the indicator switch every so often in
    case I've forgotton, also will retrain myself to feel the gearbox more
    for neutral, the clocks annoying as theres nowhere else to put it
    higher up.
    But all these are trivial compared to my one and only niggle.
    What I really want to know is if you all rely solely on the magnetic
    aspect of the bag, ie do you strap it down any other way at all?
    At up to 90mph it's stable but I didn't have much in it and I'm just
    wondering if I'm just being a bit paranoid? [1]
    [1] Which is the most likely aspect TBF
  2. Donnie
    Is there no strap to go around the headstock? My Oxford one did.
    Yes, I reckon you are.
    It will be fine[1]
    [1] Unlike un-strapped-down throwover panniers, which are fine at up to
    at least 130 when full, but don't like it so much when one goes over a
    hump onto a raised level-crossing at 50-ish. One needs to stop and
    re-adjust somewhat. And the panniers.
    CT, Mar 11, 2010
  3. Donnie
    boots Guest
    Magnets were fine until I bought a bike with a plastic tank. Put
    something between the tank and the bag or you'll scratch the paint. I
    had a thin and soft plastic mesh cloth, can't recall where it came
    from.
    boots, Mar 11, 2010
  4. Donnie
    Galet Guest
    I used to have a magnetic tank bag, I kept it for a year more or less,
    using it nearly every day. It worked kind of OK, but I always had the feeling
    that it was a precarious solution.
    I then bought a Bagster tank cover and I got a bag from Lozzo: overall it's
    probably 10 times more expensive than your configuration, but it's worth every
    penny. I highly recommend it if you plan to use the bag regularly, there is
    no comparison with the magnetic one.
    F
    Galet, Mar 11, 2010
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Galet
    So did I.
    Until one day I put it down in my workshop. On a bench that had quite a
    lot of ferrous swarf on it...
    Wicked Uncle Nigel, Mar 11, 2010
  6. Donnie
    rick Guest
    Ditto. I really liked my magnetic tank bag - it was fine at any spped on my
    old GPZ but the Sprint has a plastic tank :-(
    rick, Mar 11, 2010
  7. Donnie
    SaladDodger Guest
    Not as much fun as feeling them fall off on the M2, then watching from
    the hard shoulder as a National Express coach drives right over the
    top of them.
    Probably.
    SaladDodger, Mar 11, 2010
  8. Donnie
    'Hog Guest
    YTC!
    'Hog, Mar 11, 2010
  9. Using the patented Mavis Beacon "Hunt&Peck" Technique, 'Hog
    I find myself unable to formulate a credible defence.
  10. Donnie
    Donnie Guest
    CT said:
    Nope only a shoulder strap as this can be detached from the magnetic
    flaps
    I think so
    woops!
  11. Donnie
    Donnie Guest
    steve auvache said:
    It's a naked bike but Ive got a screen so seems to do the job
    Aye this is something that has dawned on me, think ill have to get a
    strap of sorts.
  12. Donnie
    Donnie Guest
    boots said:
    Not seen my bike have you :)
  13. Donnie
    DozynSleepy Guest
    I've got the Oxford sprint strap on tankbag base for, strangely enough,
    my Oxford sprint Tank bag. Not quite as convenient as the Baglux since
    you have to zip it on and off the base but it was available when I
    wanted it and much cheaper.
    Can't see them anymore on the sounddistribution.co.uk website but MandP
    still lists them.
    http://www.mandp.co.uk/productinfo/571188/Luggage/Soft-Luggage/Oxford/2008-Conversion-Kit
    DozynSleepy, Mar 11, 2010
  14. Donnie
    hahah - you tit.
    darsy, Mar 11, 2010
  15. Donnie
    TOG@Toil Guest
    What he said. I use that sort of rubberised net mesh - camping stores
    sell it. Perfect for the job.
    The K has an aluminium tank, of course, so my magnetic bag's no good
    on that but then the K's not short of luggage capacity anyway.
    TOG@Toil, Mar 11, 2010
  16. Donnie
    TOG@Toil Guest
    Or inhaling the great whiff of smouldering throwovers and their
    contents: something Champ and I are both familiar with...
  17. Donnie
    As is Preston, although in his case it's the plastics on which they're
    resting, rather than the pannier contents.
    Ace, Mar 11, 2010
  18. Donnie
    SaladDodger Guest
    Indeed.
    On the other hand, the Wing now (occasionally) sports a small tankbag
    over the top of the stereo controls.
    Attached to adhesive Velcro strips.
    It's a really tasteful *brown* vinyl.
    Can't remember the make, Kuryakyn, or something.
  19. Donnie
    Solo.
    Ace, Mar 11, 2010
  20. Donnie
    YTC#1 Guest
    YTC#1, Mar 11, 2010
