Paging the ST-isti (end of an era)
Discussion in 'UK Motorcycles' started by serf, Feb 19, 2009.
  1. serf
    serf Guest
    Finally parting company with CB500s (1). It's been a good run (2 bikes
    in 5 years) which I've thoroughly enjoyed. Ground hero blobs a lot,
    but never managed to get rid of chicken strips.
    Looking at ST1300 tomorrow, 04 plate, 25,000 miles. Anything Pan
    specific that I should be looking out for?
    (1) Head gasket gone, revealed by contents of cooling system being
    dumped out of breather hose onto back wheel. After replacing the
    engine a year ago, I can't face that again, even though bike has just
    had full service and MOT, so will punt it out as an engine replacement
    project.
    serf, Feb 19, 2009
  2. serf
    Oh. I thought you were going say you'd bought an Amiga.
    ogden, Feb 19, 2009
  3. serf
    it's what I thought when I saw the subject line too. Though YM
    "Atari", not "Amiga".
    darsy, Feb 19, 2009
  4. serf
    serf Guest
    I did buy an Atari ST about 20 years ago, to use as a MIDI sequencer.
    It came with Asteroids.
    serf, Feb 19, 2009
  5. serf
    ginge Guest
    You can get cream for that.
    ginge, Feb 19, 2009
  6. serf
    antonye Guest
    I've still got mine in the loft, which I upgrade to a 1040 by
    soldering in all the extra memory chips and caps myself!
    antonye, Feb 19, 2009
  7. serf
    SteveH Guest
    They're dropping value like nothing else, from what I can see.
    Whereas the old ST1100 values are holding firm, at worst.
    ISTR the ST1300 is rather unloved.
    SteveH, Feb 19, 2009
  8. serf
    Oh. Well.
    The ST and the Amiga were pretty concurrent, though the Amiga
    outlasted the Atari by a couple of years.
    darsy, Feb 19, 2009
  9. serf
    loser.
    If you'd bought an Amiga, you could have fitted a daughterboard
    upgrade in 20 seconds with no soldering.
    darsy, Feb 19, 2009
  10. Only that you should be looking at an older 1100. Seriously.
    The Older Gentleman, Feb 19, 2009
  11. *Perk*
  12. serf
    serf Guest
    My main problem with this is that I don't want a bike that is more
    than 5 years old. The repair bills for the 1100 can be pretty steep.
    serf, Feb 19, 2009
  13. serf
    SteveH Guest
    They can?
    AFAIK, they're one of the most robust and reliable bikes ever made.
    Didn't the police withdraw almost all their ST1300s due to some strange
    handling problem?
  14. serf
    serf Guest
    That may be, but several that I have looked at have recently had over
    a grand spent on repairs following big ticket item failures..
    AIUI they overloaded the back of the bike then experienced high speed
    weave problems. I don't plan to replicate this.
    serf, Feb 19, 2009
  15. serf
    SteveH Guest
    Look at the mileages they do, though - and at what mileage did the
    failures happen?
    There's a good reason why a late, low mileage ST1100 is more sought
    after than an early ST1300.
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, Steve
    Well generally, IME, some dozy **** puts the wrong fuel in and it's all
    downhill from there.
    Wicked Uncle Nigel, Feb 19, 2009
  17. A lot of private owners had the same problem, and (IIRC) there was some
    recall for engine mounts, or whatever.
    It may suit your needs perfectly, but it hasn't been one of Honda's
    successful models and it's being replaced soon. Draw your own
    conclusions.
  18. serf
    DR Guest
    darsy posted:
    Unless it was an Amiga 1200; certain daughterboards only worked on
    certain models depending on production date. DAMHIK and all that.
    DR, Feb 20, 2009
  19. I know nothing.... But apparently there's a much revised Pan on the way.
    The Older Gentleman, Feb 20, 2009
  20. serf
    Dave Benj Guest
    I've heard that it's going to be fitted with a supercharger...
    Dave Benj, Feb 20, 2009
