Paging the spelling police
Discussion in 'UK Motorcycles' started by Whinging Courier, Mar 27, 2005.
  1. How do you spell an abbreviation of I would have, as in I'd have. I want
    to make it even shorter by calling it I'dve, but that doesn't look
    right. Id've doesn't look right either.
    Cheers.
  2. Whinging Courier
    Howard Guest
    I'ld've written I'd've.
    Howard, Mar 27, 2005
  3. You can't ..
    'I'd have'
    ... is as short as you're going to get it, I think ..
    genuine_froggie, Mar 27, 2005
  4. Nothing, that's what I normally put.
    I'd have it is then.
  5. Whinging Courier
    Cab Guest
    Seems common enough when you do a web search for it. Doesn't mean it's
    correct though.
    It could be right, but I'm not commiting myself:
    http://www.orlapubs.com/AL/L67.html
    Cab, Mar 27, 2005
  6. Eh ??
  7. It's OK
    "committing"
    hth
    The Older Gentleman, Mar 27, 2005
  8. That's one thing I like about the spanish lingo (I suspect french is
    similar). That sort of "conditional" shit is built in. And of course,
    they don´t generally use personal pronouns here, so the verb "tener"
    would simply conjugate to "tendría" (I/he/she/it would have). I'm
    obviously assuming you mean "To have" in the possesive sense, rather
    than "To have done something" - that would be the verb "Haber" of course.
    I expect Domènec will be along shortly to correct me.
    Paul.
    CBR1100XX SuperBlackbird
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
    Paul Carmichael, Mar 27, 2005
  9. Whinging Courier
    Cab Guest
    Thanks. I'm indebted to you. I didn't spell chuck the post.
    Cab, Mar 27, 2005
  10. I just couldn't see how the conditional was 'built in' in French, that's
    all...
  11. Whinging Courier
    Cab Guest
    Not the same as French, I think. For example, if you want to say "I
    have a dog", then in French it'd be "J'ai un chien" whereas in Spanish,
    it'd be "Tengo un perro". But even then, it's not wrong to say "Yo
    tengo un perro" just not as common. I think.
    Another example :
    Il a les yeux bleus : Tiene los ojos azules.
    I think I've got the spelling right.
    Cab, Mar 27, 2005
  12. "Conditional" - "I would/could etc." Look, I'm not a fucking "linguist"
    like you. All this stuff is new to me. I can hardly speak english.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
  13. Hmm. Contrary to what you would appear to believe, I'm not trying to
    'catch you out', and really, my Spanish is so crap that I couldn't catch
    you out if I tried.
  14. In French you do (I don't know enough Spanish to correct you), but you're
    using the indicative; Paul cited the conditional, which isn't the same
    thing. However, you are correct in that the pronoun is required in French.
  15. "I suspect french is similar". Hardly a statement of fact.
    Paul.
    BOTAFOT #4
    BOTAFOF #30
    MRO #24
  16. Whinging Courier
    gomez Guest
    If you had been more positive you could have said "I did".
    gomez, Mar 27, 2005
  17. Whinging Courier
    raden Guest
    Why is blue plural ?
    I presume you mean he has blue eyes
    Just asking - I failed my French "O" level 3 times
    raden, Mar 27, 2005
  18. Whinging Courier
    Cab Guest
    'cos we're talking about two eyes and not one.
    Cab, Mar 27, 2005
  19. Becasue we have two eyes ....
  20. Whinging Courier
    raden Guest
    Sorry for being thick, but (see above) does the adjective take on the
    plural also ?
    I never knew that
    raden, Mar 28, 2005
