Paging the sparkies
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Nov 21, 2010.
  1. Wicked Uncle Nigel
    Ian Field Guest
    Wickes do electronic starters for about £5, they start much better than the
    gas tube ones and have built in spike protection.
    The landlords electrician fitted a 2D light in the bog with the wrong
    ballast in it, it was slow to strike from day 1 and took about an hour to
    warm up so it stopped shimmering.
    After about a years use I had to switch the light on and go have a cuppa
    while I wait for the tube to strike, a Wickes electronic starter got it
    going again till I could track down an electronic ballast at a reasonable
    price.
    For some unknown reason my flat has very spikey mains, I had numerous
    equipment failures before I started buying surge suppressor socket strips -
    when I fitted the electronic ballast to the bog light I left in the PFC
    capacitor and added a:
    http://industrial.panasonic.com/www-ctlg/ctlg/qAWA0000_WW.html
    Ian Field, Nov 21, 2010
  2. There are better solutions.
    Surge strips actually work, once or twice, but there's (usually) no
    indication the MOV(s) usually inside has buggered up or at the end of
    its life, so the user happily keeps on using the strip, unaware it's not
    much good anymore.
    Grimly Curmudgeon, Nov 21, 2010
  3. Wicked Uncle Nigel
    Ian Field Guest
    If those "better solutions" were readily available on the shelves I'd
    probably be buying them.
    Maybe the sheer number of anti-surge socket strips I have is holding the
    spikes down so they all last - the only ones to fail so far were Maplins,
    and they physically fell to bits.
    Also whenever I scrap any gear I open it up and if it has an MOV its
    salvaged and either grafted into something I know doesn't have one, or put
    in the parts drawer until needed.
  4. Wicked Uncle Nigel
    Eiron Guest
    I presume they have modern electronic high-frequency drivers.
    I would have thought that WUN wants a traditional starter and ballast
    inductor
    that makes a circular saw appear to stop so he can check it with a
    finger....
    Eiron, Nov 22, 2010
  5. Wicked Uncle Nigel
    davethedave Guest
    OK lets all sing along.
    I like to MOV it MOV it.
    As mentioned above you can never tell whether they are fubar or not. They
    are kind of like airbags. Once you've set it of to see if it works you
    need a new one.
    davethedave, Nov 22, 2010
  6. Wicked Uncle Nigel
    Ian Field Guest
    You can sing Loopy Lou from Andy Pandy as well if you like.
    Ian Field, Nov 22, 2010
  7. Wicked Uncle Nigel
    davethedave Guest
    Ah. I am but a young whipper snapper and don't know that one. I seem to
    remember he had blue and white stripy pyjamas though. I'm getting quite
    good at the theme tune from Caillou though.
  8. Wicked Uncle Nigel
    Beav Guest
    Nor should you, coz it was "Looby Lou" not "Loopy Lou"
    And a fucking stupid hat. Even for a 5 year old it was fucked.
    Beav, Nov 23, 2010
  9. Wicked Uncle Nigel
    Looby Loo, UTYF.
    Ace, Nov 23, 2010
  10. Wicked Uncle Nigel
    davethedave Guest
    I lubed up Lou once. Lovely girl. Still think of her fondly.
    davethedave, Nov 23, 2010
  11. Wicked Uncle Nigel
    I've done the same - sadly my Lou died earlier this year aged 37, so
    the lubing has stopped.
    Lozzo
    they churn out)
    Lozzo, Nov 23, 2010
  12. Wicked Uncle Nigel
    davethedave Guest
    davethedave, Nov 24, 2010
  13. Wicked Uncle Nigel
    muddycat Guest
    It's Gremlins.
    muddycat, Nov 24, 2010
  14. Wicked Uncle Nigel
    Beav Guest
    Sounds exactly the same to me.
    Beav, Nov 27, 2010
