Paging the sparkies
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Nov 21, 2010.
  1. My woodwork workshop has two fluorescent tubes, wired through a circuit
    breaker. They're on a separate circuit to the sockets.
    Last week, I was using a circular saw when the lights suddenly went out
    (both of them). I thought the circuit breaker had tripped, but it
    hadn't.
    Checking this evening reveals that power is getting to both tubes. The
    tubes themselves seem fine, so I'm guessing that something has killed
    the "starter" circuits in the lights. These fittings don't seem to have
    separate starter thingies (as I believe they are known).
    Is it likely that using the saw has done something nasty to the
    circuits?
    Any ideas very welcome.
  2. Wicked Uncle Nigel
    Pete Fisher Guest
    "Something Nasty In The Woodshed."
    Dunno. I recently added two more new fluorescent tube fittings to the
    garage wired in to the existing lighting circuit. They have separate
    standard little starter can jobbies. Yours must be posh.
    If they are on different circuits could a power surge still have
    affected them? Otherwise perhaps a strange resonance set up in starter
    PCBs or what ever by the noise from the saw. Pretty unlikely that would
    kill both at the same instant though. Rogue electrons more likely.
    | Pete Fisher at Home: |
    Pete Fisher, Nov 21, 2010
  3. Wicked Uncle Nigel
    A.Lee Guest
    MCB's? Or RCD?
    Presumably it is MCB's then if the saw was still powered?
    More info required.
    Is there power to the sockets?
    Or was the only fault a trip of the miniature circuit breaker?
    A MCB tripping is usually a overload, rather than a live to earth fault.
    A live to earth will cause the RCD to trip (you have got a RCD?)
    Probaby knackered ballasts. They are crap. I used to change one a week
    or so in my old job from a pool of 200 lights. £10ish new, so change the
    whole light fitting rather than trying to repair the existing fitting.
    I'm just fitting today a couple I've bought, same as these:
    <http://www.tlc-direct.co.uk/Products/GLWP236.html>
    Though I paid £15ea from my local electrical dealer. Good quality, water
    and dust proof, ideal for a garage.
    Alan.
    A.Lee, Nov 21, 2010
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, A.Lee
    MCBs. There's an RCD at the main feed to the workshop.
    No circuit breakers tripped at all.
    Both lights died at exactly the same time.
  5. Wicked Uncle Nigel
    A.Lee Guest
    New lights needed.
    Possibly the saw was drawing a lot of current, the volts dropped a bit,
    the lights then tried to draw more amps, as the volts were low, to stay
    alive, then overheated, and possible damaged the ballast.
    All the above could be bollocks, but is my theory!
    I'd check to see what size cable is feeding the workshop firstly. Has it
    got big enough conductors for the length of cable?
    If that is fine, then check each terminal connection to make sure they
    are all tight - very easy to have a loose connection that causes
    overheating.
    If you want to give me length/power consumption I can check it is rated
    correctly.
    Alan.
    A.Lee, Nov 21, 2010
  6. Possibly if the saw draws a large amount of power, you could be
    causing a power surge when switching it off ,this might fry the
    crcuits of the electronic starters .
    steve robinson, Nov 21, 2010
  7. Wicked Uncle Nigel
    John F Guest
    How did you check that power is getting to the tubes?
    My guess is no neutral.
    John F, Nov 21, 2010
  8. Wicked Uncle Nigel
    Ian Field Guest
    Are they "2D" or some other form of compact, folded or circular tube?
    If the tube is an assembly with plastic bits, check how many pins its got -
    2 for built in starter, 4 for starter in the light fitting.
    Just guessing, but if you can't find a starter on the fitting, its a 2 pin
    only and you can only use 2 pin tubes. AFAIK you can use a 2 pin tube on a 4
    pin fitting.
    It wouldn't hurt to distribute a few surge limited socket strips around the
    workshop.
    Ian Field, Nov 21, 2010
  9. Wicked Uncle Nigel
    which suggests a wiring problem - what did you check the power to the light
    units with? Did you measure across the L-N feeds with a meter or just look
    for hot wires with a neon screwdriver? If the latter, check the neutral
    wiring back to the panel.
    wessie, Nov 21, 2010
  10. Cheapo electronic ballasts knackered by dirty power spikes from the saw.
    Grimly Curmudgeon, Nov 21, 2010
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, A.Lee
    Thanks. The cable is 2.5mm diameter conductors in a shielded cable. It's
    about 12 metres long. Current draw would have been pretty small. The
    saw's a hand-held thing. I'm not sure what its rating is, but it's
    certainly not fused above 13 amps.
    Other than that, two fluorescent tubes and the radio.
  12. Easy way to check , meter out the switched live to neutral then
    switched live to earth , if either are broken it will show 0 volts
  13. Using the patented Mavis Beacon "Hunt&Peck" Technique, wessie
    Meter, it's reading 230V across the feeds.
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    That's what I wondered.
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, John F
    Meter. And wiring another lamp to the feed gets light.
  16. Wicked Uncle Nigel
    A.Lee Guest
    Thats fine, that cable should be able to handle 29A continuous.
    You'll only be losing around 2.8v as voltage drop at 13A over 12metres,
    so voltage drop is not an issue. Do check that all connections are tight
    occasionally.
    Typical hand held circular saws are 1200 - 1800 w, so well within the
    limits for consumption for that cable. I'm presuming it is a radial
    circuit only feeding the workshop?
    You should have a 20A or lower MCB for that.
    Note that it will not trip at 20a, but more like 30a after a couple of
    minutes. This allows for short over-amps such as starting a large motor
    etc.
    Main theory is still right. Cheap flourescent ballasts that have blown.
    Either drawing too much current, getting too hot, or a very short spike
    that burnt them out.
    Alan.
    A.Lee, Nov 21, 2010
  17. Grimly Curmudgeon, Nov 21, 2010
  18. Wicked Uncle Nigel
    Ian Field Guest
    They've served me well over the years, if you don't want any that's your
    look out.
  19. Wicked Uncle Nigel
    Beav Guest
    We've got those in the workshop and in the booth for safety reasons as they
    don't create sparks (supposedly). We have no power outlets in the booth, but
    in the workshop it's not unusual for them to go titsup when a particularly
    heavy load is drawn. That's usually when we're using infra red heaters and
    the compressor fires up. It's like the electric chair and all the lights go
    dim for a split second. Some of them go dim forever, but thankfully, it's
    not a regular thing.
    Or just spiked the current. I dunno, but it wouldn't surprise me to discover
    the saw was the sawce.
    Ditch that kind of light and get the ones with separate (and replaceable)
    starters. The starter types seem immune to power surges. At least at our
    place anyway.
    Beav, Nov 21, 2010
  20. Wicked Uncle Nigel
    Beav Guest
    Until the clips holding the clear front deteriorate and fucking fail. I had
    a clear front drop on me a couple of years ago :)
    They are good though, but dear at 15 quid a pop (ha) when you consider that
    I got probably 30 or 40 from a firm that moved premises. Cost me the huge
    amount of **** all but collection.
    I've got to still put a few up in my garage at home before they're all used
    by the boy-chic at work.
    Beav, Nov 21, 2010
