[QUOTE="SteveH"] I have found a Hepco and Becker rack that'll do the job - but it's nearly £100. Price worth paying - maybe, if I get desperate.[/QUOTE] IIRC it requires H&B rails (or mode to the stock rails) [QUOTE] As for the K-box kit - if you can fit a small K-box to it, surely you can source one of the larger versions, too?[/QUOTE] I couldn't honestly say, though as I've not seen the larger boxes on the earlier Ks I'd suspect not. That said, the suspend-it-in-mid-air approach on the Boxer might give you the clearance (if clearance is the problem)
