Paging the SO Airhead-isti
Discussion in 'UK Motorcycles' started by SteveH, Feb 12, 2009.
  1. SteveH
    SteveH Guest
    Shockingly, I appear to have almost done the deal on a bike.
    Bloke selling is an olde-worlde specialist mechanic and dealer who
    doesn't do 'new fangled digital photos' - so it's all down to the 35mm
    camera shots winging their way through the post overnight.
    Anyway - how do you adapt the BMW rear carrier to take a Givi top box? -
    I don't really want to buy a BMW box, as I have 2 Kappa Monokey cases
    and a Givi Wingrack (Monolock?) box in the garage.
    Can't find any listing on the Givi website - but I've seen some photos
    of airheads with Givi top boxes fitted.
    (The bike is an R100RT Mono with BMW OEM panniers)
  2. SteveH
    A.Lee Guest
    Givi sell (or did sell) a plate that you just bolt onto your existing
    rack.
    Be aware that there are 2 types of Givi mounts, I found out the hard way
    when a top box I bought wouldnt fit the mono rack I already had.
    Alan.
    A.Lee, Feb 12, 2009
  3. SteveH
    SteveH Guest
    Not quite that simple - look at the angle of the BMW rack:
    http://michaelmcbroom.com/bmwblog/wp-content/uploads/2008/03/r100rt1.jpg
    You need a whole replacement rack, or a plate which levels it out.
    Which is what I can't find.
    I know of the 2 different mounts - as I fitted a monorack plate to a
    monokey wingrack to get around this issue.
  4. Problem you have there is that the little BMW rack that's usually fitted
    to old airhead RTs and RSs (on top of the seat hump) actually slopes
    backwards a bit, which is why you hardly *ever* see one of these bikes
    with a top box.
    You're going to have to do some serious hunting around, but really, your
    best bet is simply to forget fitting a top box at all. Quite apart from
    anything else, airhead boxers really don't like them, handling-wise.
    Which is one reason why you hardly ever see them.
    The Older Gentleman, Feb 12, 2009
  5. SteveH
    SteveH Guest
    Katie wants the box as a backrest.
  6. SteveH
    Gyp Guest
    Let her drive and you can push her from behind
    Gyp, Feb 12, 2009
  7. Thought so.
    It's possible, but it'll be a lot of hassle, time and money.
    Like I said, you hardly ever see an airhead boxer with a top box. This
    is why.
  8. SteveH
    SteveH Guest
    Hmmm, I need to find a friendly local welder.
    I have a Rentec rack in the garage from the TRX and one from a Divvy
    600.
    I reckon someone with welding skills could weld an adaption to the BMW
    rack using one of those two.
    I assume BMW never offered an option of an OEM box on the airheads,
    then?
  9. Oh yes.
    Not on the twin-shockers, no. Factory luggage was always just panniers.
    I *think* there was a small topbox available for the Monolevers, but it
    was small - like the little one you sometimes see on Ks. But I've never,
    ever seen one in the UK. Timo is really the bod to ask here, mind.
  10. SteveH
    Gyp Guest
    Exactly the same as the one you see on Ks.
    And the same as the OEM one for the Mk 1 F650.
    I've got one on the GarageQueen
    Gyp, Feb 12, 2009
  11. SteveH
    google images throws up some awful looking bodges. I'm sure WUN could knock
    up something even more horrible!
    wessie, Feb 12, 2009
  12. SteveH
    SteveH Guest
    Surely they slope backwards, though? - looking at photos of the F650.
  13. SteveH
    Gyp Guest
    On the R80RT, the BMW fitting kit removes the back half of the rack and
    effectively suspends a K-series rack in mid air with a set of brackets
    that go from the original top mounting points to the pannier rails.
    I'm racking (he he) my brain to remember how it fitted to the Funduro. I
    seem to recall a custom mount that went betwixt the top case and the
    standard rack
    Gyp, Feb 12, 2009
  14. SteveH
    Gyp Guest
    I don't think that'll fit though :-(
    Gyp, Feb 12, 2009
  15. SteveH
    SteveH Guest
    I need to find someone with a K100/75/1100 and an airhead R Mono in the
    same place at the same time, as there's a Givi kit for the K series to
    mount a Givi box in place of the BMW rack.
    http://www.twistedthrottle.com/ezimagecatalogue/catalogue/variations/413
  16. SteveH
    Gyp Guest
    My dad had one of those on his K. The angle (and the mounting points)
    are different on the Boxer. The tail piece started to crack after a
    while with an E45 on there without a pillion ever leaning against it. I
    don't think the Boxer plastic would be up to supporting a wayward
    pillion
    You're welcome to have a look/measure/ponder at the rack on the GQ. As
    an aside, I'm always amazed at the level of stock that's still available
    for SOBoxers through BMW dealers, so you might find that the mounting
    kit is still available if a K box would be enough to give Katie enough
    confidence.
    Gyp, Feb 12, 2009
  17. SteveH
    Pete Fisher Guest
    In communiqué <1iv1qot.1cuc3divu3il9N%>,
    http://www.flickr.com/photos/21676903@N06/2314380717/
    Now that's what you call a SO Airhead, and that's what you call a top
    box.
    SWMBO#1 used to able to go to sleep wedged between me and that. Note it
    also makes front wheel removal easy.
    Lousy scan, though, as it is an ancient instamatic print behind a
    yellowing with age album protective cover.
    | Pete Fisher at Home: |
    Pete Fisher, Feb 12, 2009
  18. SteveH
    SteveH Guest
    I'll take you up on that offer once I have it.
    I have found a Hepco and Becker rack that'll do the job - but it's
    nearly £100. Price worth paying - maybe, if I get desperate.
    As for the K-box kit - if you can fit a small K-box to it, surely you
    can source one of the larger versions, too?
  19. SteveH
    Gyp Guest
    Gyp, Feb 12, 2009
  20. SteveH
    SteveH Guest
