Paging the plastic welders
Discussion in 'UK Motorcycles' started by Doki, Jan 9, 2008.
  1. Doki
    Doki Guest
    I've got some mouldings that I need to plastic weld. I've also got some
    mouldings that are knackered and I could use for filler rod. All made of the
    same plastic - PP/EDPM.
    The question is, what do I want to be using? Hot air gun with a nozzle?
    Soldering iron?
    Is filler rod special or is it just a conveniently packaged rod of the same
    plastic?
    Doki, Jan 9, 2008
  2. I've had some success with plastic coathangers as feed material -
    probably more luck than judgement, but if you're lucky both the broken
    part and the plastic hanger will have the same code letters.
    GS850x2 XS650 SE6a
    "A scone and tea at half past three
    Makes the day a little brighter
    Keep your cakes and fancy tarts
    And stick them up your shiter."
    Grimly Curmudgeon, Jan 10, 2008
  3. Doki
    Cane Guest
    PP yes but EPDM? that's a rubber dude.
    Hot air gun with a special nozzle attachment through which you feed
    the filler rod.
    Same material but shaped for ease of application
    You can buy it from
    http://www.amariplastics.com/amari/default.asp
    Cane, Jan 10, 2008
  4. Doki
    Eddie Guest
    Is that like a blow-up doll kind of thing?
    Eddie, Jan 10, 2008
  5. Doki
    Doki Guest
    God knows. There are rubbery parts on the rubbing strips, placed so as not
    to allow hard plastic to contact with paintwork, but the arches seem to be
    the same material right through.
    Aha. I had a go this afternoon with a hot air gun and a nozzle made from an
    old beer can, and filler rod made from another bit of moulding. It's worked,
    although it's probably not anywhere near as strong as a weld done with the
    proper kit, it's good enough.
    Doki, Jan 10, 2008
  6. Doki
    I did once weld up a polythene beer keg that had cracked near a
    flush-moulded handle using a Bernzomatic mapp gas torch and cut up
    bits of polythene beer can caps as filler. Worked a treat but was a
    slow job and looked a bit messy afterwards.
    Pip Luscher, Jan 10, 2008
  7. Doki
    Cane Guest
    If you find yourself near Stansted airport anytime I can show you how
    it's done with the right kit.
    Cane, Jan 11, 2008
  8. Doki
    Doki Guest
    Not likely unless I end up sent down there at some point by work. Is there a
    practical DIY method of blow moulding or vacuum forming BTW?
    Doki, Jan 11, 2008
  9. Petrol vapour, match.
    GS850x2 XS650 SE6a
    Grimly Curmudgeon, Jan 11, 2008
