Paging the grammar Nazis
Discussion in 'UK Motorcycles' started by Andy Cunningham, Feb 24, 2005.
  1. Absolut-ely!
    There homepage is quite nice, although being alcohol nazis here in
    Sweden they make you put your date of birth in before you can gain
    access.
    http://absolut.com/
    Andy Cunningham
    Stockholm, Sweden
    STX1300A
    UKRMMA#17
    The UKRM FAQ: http://www.ukrm.net/faq/ukrmfaq1.html
    #61
  2. Andy Cunningham
    MikeH Guest
    Could you keep it going a bit longer - my gran can only type slowly[1].
    [1] Expect a post reading "Slowly SLOWLY slowly s l o w l y sl*wly"
    MikeH, Feb 24, 2005
    #62
  3. Andy Cunningham
    Champ, Feb 24, 2005
    #63
  4. Andy Cunningham
    Ben Blaney Guest
    Tsk. Finlandia, please. Far superior.
    Ben Blaney, Feb 24, 2005
    #64
  5. Andy Cunningham
    Champ, Feb 24, 2005
    #65
  6. Andy Cunningham
    keep digging.
    darsy, Feb 24, 2005
    #66
  7. Andy Cunningham
    *ding*
    Finlandia Lime is one of my fav. vodkas.
    Tried Polstar? It's Icelandic, and pretty nice.
    darsy, Feb 24, 2005
    #67
  8. Andy Cunningham
    Cab Guest
    Heh.
    Cab, Feb 24, 2005
    #68
  9. Andy Cunningham
    Ben Blaney Guest
    [censored] off you French [censored].
    #69
  10. Andy Cunningham
    flash Guest
    "Jack me" and "tart"?
    flash, Feb 24, 2005
    #70
  11. Andy Cunningham
    Switters Guest
    Cheeky bugger, just because I was ill. Anyway, I recall we went through 7
    bottles on Friday night, and that was before you lot went clubbing.
    Switters, Feb 24, 2005
    #71
  12. Andy Cunningham
    Ben Blaney says...
    Finlandia is lovely when it's been in the freezer for a couple of days.
    Lozzo, Feb 24, 2005
    #72
  13. Andy Cunningham
    TMack Guest
    Quite a bit is wrong if you want to be REALLY picky. It is usually bad form
    to have a comma before a conjunction such as 'and' or 'but'. The easiest
    way to 'fix' this kind of problem is to use a full stop instead of a comma
    and delete the conjunction. This creates two shorter sentences. Deleting
    the conjunction may, in some circumstances, result in a need to rephrase one
    or both of the new sentences. In this example the first section lacks a
    verb. Splitting the sentence into two sentences will require a verb to be
    added to the first section. The grammatical status of "OK" is uncertain as
    it is a slang term but, if used, both letters should be capitalised. "OK"
    should be followed by either a comma, a full stop or an exclamation mark.
    The second section of the sentence contains redundant words and lacks a
    comma. The sentence could be re-written as follows:
    OK, that's no problem. If you could fax a copy, that would be extremely
    useful.
    OR
    OK, that's no problem. If you could send a copy by fax, that would be
    extremely useful.
    Tony
    TMack, Feb 24, 2005
    #73
  14. Andy Cunningham
    Switters Guest
    The thing that struck me was how windy it wasn't. I expected a blast of
    air to rush in, but it was really very pleasant.
    #74
  15. Andy Cunningham
    Paul - xxx Guest
    jsp composed the following;:
    I know what I ment ......
    Paul ...
    www.4x4prejudice.org
    (8(|) Homer Rules ..... Doh !!!
    ebay stuff Item No's
    5754626752
    5754638697
    Paul - xxx, Feb 24, 2005
    #75
  16. Andy Cunningham
    Mark Guest
    : The Automatic Teller Machine machine, you say?
    : (or have I been whooshed?)
    : Chris
    I can do pedantic............
    "Automated" not "Automatic".
    Mark
    Mark, Feb 24, 2005
    #76
  17. Andy Cunningham
    That's the rinse aid one isn't it?
    <sad voice>
    I can't remember my favourite vodka.
    sweller, Feb 24, 2005
    #77
  18. Andy Cunningham
    TMack Guest
    I would if I could.
    Tony
    TMack, Feb 24, 2005
    #78
  19. It was somewhere around Barstow, on the edge of the desert, when the
    Just what do they tell us, these teller machines?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Feb 24, 2005
    #79
  20. It was somewhere around Barstow, on the edge of the desert, when the
    But I can't, so I won't.
    GS 850 x2 / SE 6a
    #80
