Paging the cyclisti: fixed-gear bikes and brakes
Discussion in 'UK Motorcycles' started by TOG@Toil, Apr 13, 2011.
  1. TOG@Toil
    TOG@Toil Guest
    Sweeping generalisation: if you ride a 'fixie' (as I understand
    they're called) in London, then by definition you're a twat.
    Second generalisation: if you remove the rear brake, you're a
    dangerous twat.
    Why do so many riders feel obliged to do so? I suppose the argument is
    that 'my legs can stop the bike quickly enough' (they can't unless
    you're Superman), but what's the legal position? I always understood
    the bicycles used on the road have to have brakes on both wheels. True?
  2. TOG@Toil
    Worped and twisted, certainly, but why a twat?
    Eh? Rear brakes are totally useless in an emergency anyway, just like
    on a motorbike.
    No. A fixed gear is acceptable in lieu of a rear brake.
    Ace, Apr 13, 2011
  3. TOG@Toil
    Eiron Guest
    I have a vague recollection of a reluctance to fit any brakes at all
    on pushbikes/motorbikes, and that a feeble front brake was referred to
    as a bobby-dodger. I presume that was in Edwardian times though.
    Eiron, Apr 13, 2011
  4. TOG@Toil
    Jim Guest
    Not true. It's legal AIUI because your legs are the second braking system
    if there is no freewheel mech.
    There are weight and complexity savings to losing the rear brake: and of
    course the front brake is far more effective anyway due to the weight
    transfer, just as on a motorbike.
    I've no idea why fixie riders are particularly more twattish. It's seen
    as a bit weird even by other cyclists.
    London riders are a bit special though - the extra disposable income and
    the fact that none of them own cars means that it's quite common for them
    to be spending £5k on a bike. Perhaps the reason they jump red lights is
    that they're worried that if they stop someone will nick it off them.
    Jim, Apr 13, 2011
  5. TOG@Toil
    I'm not sure it's cause and effect, more likely a significant overlap.
    ogden, Apr 13, 2011
  6. TOG@Toil
    Not to mention the ride to work scheme that gets them a signficant
    discount.
    ogden, Apr 13, 2011
  7. TOG@Toil
    TOG@Toil Guest
    Depends on the efficiency of the front one, I'd have thought.
    Ah, right. Thanks. I really didn't know, and was wondering.
  8. TOG@Toil
    Tim Downie Guest
    It would seem that locking the back wheel isn't as hard as you might think.
    Not saying that it's an effective way of braking, but it does satisfy the
    rules regarding brakes.
    Tim
    Tim Downie, Apr 13, 2011
  9. A fixed gear is no substitute for a brake and don't let anybody tell you
    otherwise. I suppose that the amount of mass you may have to throw back
    at the pedal may affect the slowing down situation slightly but speaking
    as someone who rode a fixed gear bike as a reckless yoof, they are crap at
    stopping.
    steve auvache, Apr 13, 2011
  10. TOG@Toil
    Some of the comments are impressively spastic even by YouTube
    standards. How do people that dumb operate a keyboard?
    Krusty, Apr 13, 2011
  11. TOG@Toil
    TOG@Toil Guest
    Indeed. And as someone else said, the comments added make me despair.
  12. TOG@Toil
    If your front brake isn't enough to get the wheel lifting, chances are
    the rear one would be crap too, and therefore much less effective than
    a strong pair of legs resisting pedal rotation.
    If you've not ridden a vaguely modern bicycle, you perhaps wouldn't be
    aware of this, but truly effective brakes started, IMO, with the
    caliper type used on early MTBs, then 'V' brakes with a better
    mechanical advantage, and later hydraulic disk brakes. I have these
    latter on my MTB, as I'm sure do many here, and they really are
    incredibly good.
    Ace, Apr 13, 2011
  13. TOG@Toil
    If there's one thing that puzzles me more than the question of why
    people post comments on youtube and the like, it's why anyone would
    bother reading them.
    Ace, Apr 13, 2011
  14. TOG@Toil
    Jim Guest
    Don't you end up having to pay the list price as well?
    Jim, Apr 13, 2011
  15. TOG@Toil
    TOG@Toil Guest
    I've not ridden a vaguely modern *motorcycle* for years[1], so the
    chances of this are slim-to-none ;-)
    [1] Street Cripple excepted.
  16. I was pushed into fitting a set of front V-brakes to my elderly MTB and
    by **** are they an improvement on the original cantilever type (and so
    simple in design). I left the rear as original, as it's not needed to be
    that good.
    I might get a disc setup on the front, but I'll see what rim wear is
    like.
    Grimly Curmudgeon, Apr 13, 2011
  17. TOG@Toil
    Jim Guest
    I think you misunderstood me. I meant, under the scheme if you bought a
    5k bike you'd still only get that 400-450 off because it only counts for
    the first £1000.
    But if you went and bought the same bike in the sales you might get a
    discount of 15% or more off list price, thus saving £750 or more.
    Jim, Apr 13, 2011
  18. TOG@Toil
    Geo Guest
    Quite possibly a ginge but I think it's relevant and, to an extent,
    explanatory:
    Geo, Apr 13, 2011
  19. TOG@Toil
    Excellent. And so true.
    Ace, Apr 13, 2011
  20. TOG@Toil
    Eiron Guest
    Weinmann Vainqueur centre-pull brakes. YKIMS.
    Eiron, Apr 13, 2011
