Paging the charging system gurus.
Discussion in 'UK Motorcycles' started by Pete Fisher, Mar 21, 2011.
  1. Pete Fisher
    Pete Fisher Guest
    When I got back from my ride on the Morini on Friday I realised that the
    indicators weren't blinking and that the idiot light to show that the
    lights were on was fluctuating markedly with engine revs. Turned the
    headlight off and blinking was reinstated. A bit puzzled because it has
    been treated to a new battery. Only a 12v 5.5 Ah job as that's all you
    can squeeze in to a 250 and a quick check with a multimeter had
    indicated a healthy 14-15 volts across it when running.
    Checked this morning and still the same, then had a sudden realisation
    that I had fitted the Cibie headlight from the broken on Ebay 77 Strada.
    With that on, the voltage drops to just 12.2 even at 4000 rpm. So I had
    a look at the bulb in the headlight. An H4 type 60/55w job. A quick test
    revealed that with lights on (the pilot light stays on with the
    headlight so IIRC another 10w or so max) and indicators working a peak
    current of well over 8 amps is being drawn. Does that sound about right?
    The 350 motor in it has the 130w output alternator (well it was when
    new) and the standard bulb is a poxy little 35/25w thing. By my
    calculations it ought to be able to power the lights and charge the
    battery, but on the face of it doesn't. I suppose I ought to try a
    current reading, but I don't want to mess about with a stator rewind if
    it isn't going to be up to it even when tip top so I thought of trying
    one of these:
    http://www.redlineuk.co.uk/headlight-bulbs/all-xenon-bulbs/h4-45-40w-hs1-
    super-white-motorbike-xenon-headlight-bulbs-12v-pair.htm
    TBH, I doubt I'll be riding it much at night, but I do tend to keep the
    dipped beam on during the day, and ending up with non-functioning
    indicators after a reasonably long ride isn't an appealing outcome.
    | Pete Fisher at Home: |
  2. Pete Fisher
    Using my in depth electrical knowledge, I know that magic amp smoke =
    magic watt smoke / magic volt smoke, so assuming the indicator bulbs
    are 21 watts of smoke, 8.75 amp smokes would be about right.
    HID would seem to be the obvious answer, but a 45/40 xenon would
    probably do the job.
    Krusty, Mar 21, 2011
  3. Pete Fisher
    Simon Wilson Guest
    With your headlight on dip you're probably using about 55w + 5W pilot +
    5W tail. Then you need to add on something for the ignition - I've no
    idea what coil ignition consumes but it's either > 65W or your
    alternator isn't producing 130W. Situation gets worse when you're
    braking/indicating of course.
    An ammeter will prove whether current is flowing into, or as I suspect
    out of, the battery.
    Simon Wilson, Mar 21, 2011
  4. url:http://www.redlineuk.co.uk/headligh...-motorbike-xenon-headlight-bulbs-12v-pair.htm
    Probably do the job. The Xenon bulbs in normal 60/55W actually do
    produce extra light, but don't last as long as normal halogens. First
    time I've seen a 45/40W one, though. I'm wary of the blue coated ones,
    as they're usually indicative of bullshit.
    Whatever; a drop of a few watts draw while maintaining the same light
    output will do your alternator a bit of a favour.
    Grimly Curmudgeon, Mar 21, 2011
  5. Pete Fisher
    Pete Fisher Guest
    The weird Morini ignition system produces all the power it needs from a
    dedicated stator coil which i know has been rewound on this one.
    I suspect Lambertini or one of his minions thought 35w of yellow glow
    ought to be enough for anybody on a feeble 350.
    My multimeter has a 10amp DC plug and setting so I suppose that ought to
    cope in series though the leads don't look very thick. Nothing ventured.
  6. Pete Fisher
    Pete Fisher Guest
    Ah, forgot that they were as high wattage as that. All a bit marginal if
    the battery wasn't fully charged at the start (which it wasn't as I had
    fitted a couple of months ago).
    If all else fails I see you can get 35/35w H4 bulbs, that'll do for my
    purposes.
  7. Pete Fisher
    RatTig's got a 35/35 enduro headlight, & you really, really don't want
    to be riding unlit roads at night with one of those. Plenty good enough
    for daylight use though.
  8. Pete Fisher
    Ian Field Guest
    Where from?
    Ian Field, Mar 21, 2011
  9. Pete Fisher
    Mark Olson Guest
    Yes, it will.
    However, it is far quicker to measure the battery voltage. It is not necessary
    to use an ammeter to find out if there is current going into or out of the battery.
    If the voltage is higher than what the battery needs to charge, it is charging, if
    lower, it is discharging. The voltmeter won't tell you the magnitude of the
    current in/out of the battery - but you only need to know which side of the divide
    you are on. If the voltage is comfortably above the charging threshold, you're
    good.
    Mark Olson, Mar 21, 2011
  10. Pete Fisher
    Stick: 35w h4 bulb -hid in ebay.
  11. Pete Fisher
    Ian Field Guest
    Recently someone dumped a pair of car headlamp clusters in the flats bin
    room so I liberated the bulbs and connectors, one of the sidelight bulbs was
    blue coated - I didn't know such things existed.
  12. Pete Fisher
    Pete Fisher Guest
    http://www.startright.co.uk/index.php?main_page=product_info&products_id=2020
  13. Pete Fisher
    Simon Wilson Guest
    and no braking.
  14. Pete Fisher
    Pete Fisher Guest
    Not the done thing when riding a Morini anyway. Though I did sort the
    uneven pressure it got an advisory on the MoT for. Ditched the strange
    drilled disc from the Ebay breaker and put the one from the hill climber
    back on with brand new pads. This meant shimming the caliper as the disc
    offset seemed a gnat's cock different, but I knew from previous
    experience that old Morini rocker shaft shims are a good fit on the
    mounting bolts and just the right thickness. A few hard stops and it now
    has a pretty good brake (for a smallish single disc) and no pulsing.
    Don't like the 'feel' so much with the spiffy new braided line though.
  15. Pete Fisher
    TOG@Toil Guest
    This just sounds like inspired tinkering. Well done.
    TOG@Toil, Mar 21, 2011
  16. Sounds about right your headlamp will pull around 5 amps , if main
    beam and dip are on at the same time you could easily pull 9 amps
    from that alone
    If your running main and dip ,indicators and ignition system your
    pulling more out of the battery than your putting in
    Even just on dip your going to be close to the limit
    steve robinson, Mar 21, 2011
  17. Pete Fisher
    Start at the bottom and work up. Replace the rear lights, indicators and
    pilot lights with LED bulbs. Obviously changing the indicators might need a
    change of relay to set the flash rate. I think I'd do this for all SOB.
    http://www.autobulbsdirect.co.uk/led-motorcycle-and-scooter-bulbs/
    then
    www.autobulbsdirect.co.uk/RMU459-RING-12v-35-35w-PXPX43T-Halogen-Headlamp-Bulb.html
    Which I'm sure will be fine for your porpoises.
    Can the regulator be tuned or modified or replaced to change the charging
    curve?
    HID is possible of course, it just seems like a lot more faff.
    Hog, Mar 21, 2011
  18. Pete Fisher
    Pete Fisher Guest
    Hmm, if I can at least replace the pilot light, tail and instrument
    lights that might find me 10w and make the 45/40 jobs usable. In fact,
    apart from MoT time, there's no need for pilot and instrument lights at
    all for day time running.
    That would take it back to a standard load, so TBH is by far the
    quickest fix.
    It's a very primitive device and relies on thyristors to switch off the
    output from the single phase with centre tap (split or biphase)
    alternator.
    http://www.motomoriniclub.nl/spann4.gif
    The Dutch Morini club also quote the early alternator as only 100w
    output, the figure I have from a manual of 130wmust be for the later
    unit. So hardly surprising it's struggling.
    The system will not charge at all if the battery is very low, so a
    double whammy if balance conditions can't be maintained. Apparently the
    later models used full bridge regulators and some people have used Honda
    Superdream units but no idea if the improve low rpm charging. You
    certainly can't get the old CEV units any longer.
    Indeed.
  19. Pete Fisher
    Pete Fisher Guest
    In communiqué <-september.org>, steve
    They *should* be separate, but it's possibly with fumbling gloved
    fingers to get the SO CEV dip switch in to a both on position.
    Especially as I now discover mine has probably only got the original
    weedy 100w windings.
  20. Pete Fisher
    Mark Olson Guest
    The regulator (assuming it's a shunt type which it almost certainly
    is) doesn't really come into play until there's surplus...
    But the rectifier might contribute a tiny bit more oomph if diodes
    with lower forward drop were substituted. About all he can do is to
    reduce load, going to LED[1] lights will be a good way to start. Fitting
    a new rotor with more magnetism might give a bit more but at a huge cost.
    Probably best to just drop back to the highest lumen/watt H4 he can
    find in a 35W/35W variety and forget about doing much night riding.
    [1] 0.2W (and they're bright) LED instrument lamps here:
    http://www.superbrightleds.com/cgi-...Page&category=CAR&Page2Disp=/specs/74_t15.htm
    or
    http://bit.ly/ewJgHw
