Paging the camping-isti
Discussion in 'UK Motorcycles' started by Dan L, Jul 3, 2005.
  1. Dan L
    Dan L Guest
    I am considering getting a small camping stove for occaions such as *OSM's
    and the odd Zephyr based excursion.
    It would need to be very small, light and inexpensive.
    Having googled and ebayed I am still none the wiser as to what is the best
    option.
    I reckon a gas based one would be best, but then again some them seem to be
    able to run on unleaded, and there is one which you can recharge from
    lighter gas cartridges. AndyR's Triangia seemed to be a good bit of kit,
    but perhaps a bit too specialist for my limited requirements, and ISTR
    Ovenpaa had a rather natty little gas type one, but I didn't clock the name
    of the manufacturer.
    Any suggestions gratefully accepted.
    TIA
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Jul 3, 2005
  2. Well, if you're only going to use it with the bike, then a petrol
    version makes sense - you'll always have fuel with you, and it saves
    some luggage space (not carrying gas canisters).
    The problem herein, seems to be that reasonably good petrol burners
    aren't cheap.
    check out www.cotsoldoutdoor.com for some nicely priced, compact gas
    burner tops.
    Dnc
    ZZR1100 - tagline being developed
    B1200 - +30bhp ~|~ VS800 - borked
    TS150 - squatting ~|~ V2300 - flat cap and rug
    Doesnotcompute, Jul 3, 2005
  3. Dan L
    Beelzebub Guest
    I've got an ickle MSR gas one, a Coleman dual fuel, but what I was really
    after was the Whisperlite multifuel.
    Beelzebub, Jul 3, 2005
  4. Dan L
    Pip, Jul 3, 2005
  5. Dan L
    Dan L Guest
    Swot I fort.
    Mind you, Tallbloke's vintage petrol burner [1] seems to be a bit of a
    health hazard [2].
    They're not too bad, but look a bit bulky.
    Will do, ta.
    [1] The stove, not the Matchless.
    [2] The stove *and* the Matchless (sorry Rog ;) )
    Dan L (Oldbloke)
    Dan L, Jul 3, 2005
  6. Dan L
    Andy Hewitt Guest
    Personally, having tried everything from Primus paraffin burners to
    Coleman petrol stoves [1], the Trangia wins hands down for me. It's
    clean, quick and is very compact with all your pots in one package. OK
    you need a seperate fuel, but you can buy it in any hardware store and
    corner shop.
    [1] and even the occasional mud and paraffin in a tin box.
    Andy Hewitt, Jul 3, 2005
  7. Dan L
    Dan L Guest
    MSR ones look very hi-tech, and are a bit dear.
    The Coleman dual fuel one keeps cropping up in my investigations.
    Dan L (Oldbloke)
    Dan L, Jul 3, 2005
  8. Dan L
    Dan L Guest
    My parents have a hardly used one of those from the 1970's in their loft.
    Only drawback is the bottles are a bit bigger than I really want them to be.
    Dan L (Oldbloke)
    Dan L, Jul 3, 2005
  9. Dan L
    Dan L Guest
    I see that there is a gas attachment for Triangia's too. Not too sure if
    it's a bit too over the top for my limited needs though.
    Dan L (Oldbloke)
    Dan L, Jul 3, 2005
  10. Dan L
    Andy Hewitt Guest
    Indeed, far more complicated than you need it to be.
  11. Dan L
    Andy Hewitt Guest
    I had a Coleman petrol stove, and it was OK when new, but did have a
    tendency to leak and burst into flames after a few uses. I binned it in
    the end.
  12. Dan L
    DanTXD Guest
    I'd recommend the gas attachment as meths burning tends to cover whatever
    your heating in black sooty shit, which then gets everywhere.
    DanTXD, Jul 3, 2005
  13. Dan L
    Beelzebub Guest
    Depends what you want it for, but I've generally found that you get what you
    pay for. Then again, I used to do an awful lot of camping, both on pushbike
    and motorbike, so paying for good quality, small-sized equipment was worth
    it for me. I would generally only use the Coleman if I was camping in the
    <spit> car or I knew I was going to struggle to get gas as it's bigger than
    I like.
  14. Dan L
    You're taking the piss. Gas canisters for these are about the size of
    your clenched fist - and will do several days of three uses/day. I
    reckon it is more convenient, reliable, robust and cheaper than any of
    the multi/dual fuel jobbies and a **** sight quicker than a Trangia.
    Charmless and old hat, I'll give you - but you wanted small, cheap and
    light - it fulfills all of those.
    Pip, Jul 3, 2005
  15. Dan L
    Dan L Guest
    Hmm, perhaps an excursion to my fols loft might be in order.
    Dan L (Oldbloke)
    Dan L, Jul 3, 2005
  16. Dan L
    Steve Parry Guest
    Doesnotcompute fumbled, fiddled and fingered:
    http://www.cotswoldoutdoor.com/
    Steve Parry
    K100RS SE & F650
    and a 520i SE Touring for comfort [temporarily scarred]
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Jul 3, 2005
  17. Dan L
    YTC#1 Guest
    clean,
    DING
    Used them for years (since a boy sprout), burns meths which is easily and
    cheaply available in any country
    YTC#1, Jul 3, 2005
  18. Thanks, still haven't quite woken up yet. Long night.
    Dnc
  19. Dan L
    Salad Dodger Guest
    I wish I could remember the name of the things we used on our field
    weekends in the oggies.
    Little square flappy metal thing, with solid fuel block inside.
    Salad Dodger, Jul 3, 2005
  20. Dan L
    Salad Dodger Guest
    *ding* Seemed okay - it was the rations that were dreadful.
