Paging the brake issue isti
Discussion in 'UK Motorcycles' started by JackH, Nov 6, 2008.
  1. JackH
    JackH Guest
    The VFR, bless it, still has problems with the back brake, despite me
    refurbishing the caliper.
    Before I spend any more money, am I right in thinking the following symptoms
    point to a knackered seal in the master cylinder:
    * Not much going on, on the initial prod of the pedal.
    * Hit it again, and you get some braking, and slightly more if you prod it
    again.
    Leave it a bit longer then hit it again, and there's not much going on
    again.
    I've bled all five bleeding points (linked brakes innit, PITA) again, and no
    air came out, just pure clean fluid.
    TIA
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    03 VW Passat TDI Sport
    89 Vauxhall Nova 1.3 Pearl
    JackH, Nov 6, 2008
  2. JackH
    antonye Guest
    The rear brake on my 748 is notoriously bad to bleed, but the
    easiest way of bleeding it properly is to take it off and hold
    it *above* the master cylinder so that there is no air trapped
    in the line or the caliper. Take it off, string it up for a bit
    then go back and bleed it thoroughly while it's off. Once done,
    reassemble.
    antonye, Nov 6, 2008
  3. JackH
    JackH Guest
    Ok... well I've stripped the master cylinder off the bike now, so the system
    is nice and full of air anyway.
    Methinks I'll be calling that nice Mr Silver in the morning and ordering a
    master cylinder service kit.
    On the plus side, I had it all fired up today, and can confirm that a bung
    free Staintune end can is a beautiful thing. ;-)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 6, 2008
  4. JackH
    No, you've just got air in the system somewhere. Bleed it properly.
    Champ, Nov 6, 2008
  5. JackH
    JackH Guest
    Arse.
    Ok... I suspect, given the complexity of the system, this will take 'some
    time'.
    <looks on ebay>
    Anyone used either of these with any degree of success?
    http://tinyurl.com/62lpve (1)
    http://tinyurl.com/6x4qp6
    (1) Yes, I know it needs a supply of compressed air - got access to that.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  6. JackH
    JackH Guest
    ....is the wrong answer.
    I used the back brake all the time on the last one.
    That aside, it's not good enough for an MOT as is.
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  7. JackH
    I've got one of those - completely empties a small motorcycle system in
    seconds. Mine doesn't seal too well as the bike nipples are pretty small
    compared to other vehicles so drags air around the seal.
    I've used a Mityvac (that looks very similar) and it worked very well.
    My new method of choice is simply a big syringe which is controllable and
    effective.
    sweller, Nov 7, 2008
  8. New seals might help, but like champ says it still sounds like there's
    air in the system. Depending on the age of the brake fluid a complete
    change of fluid might also help. If air is in the system there's a
    possibility that other contaminents are also in there.
    Dunno the particular system, but on one of my trials bikes I had
    similar symptoms when all was working fine with the brake pedal and
    caliper, but the disc itselfwasn't sitting correctly in the caliper.
    Someone, the previous owner possibly, had used a wrong sized wheel
    spacer. It was only ~2mm too thin, but it meant the disc warped as the
    brake was applied, so the pads were only applying pressure
    'differently' ... might be worth a re-check. Not identical symptoms as
    air in the system, but it felt the same through the pedal ... no brake
    effect unless you pumped it.
    Paul - xxx mobile, Nov 7, 2008
  9. JackH
    TOG@Toil Guest
    It's not a knackered seal: that would mean a fluid leak. There's air
    in the system still. Pump the pedal half a dzen times, hard, before
    opening the bleed nipple. That really builds up pressure and expels
    air that sometimes gets trapped higher up the line.
    TOG@Toil, Nov 7, 2008
  10. JackH
    JackH Guest
    Ok, well I've gone for one of those - I kind of owe my mate a few favours
    for letting me do all the work up at his workshop, and he can take custody
    of it once I've finished with it.
    Plentiful free supply of those down any one of a number of dark alleys in
    Brighton, I should think. ;-)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  11. JackH
    Beav Guest
    That's probably because there IS air in the system but you've not managed to
    get it out. An old indian trick is to get the caliper higher than the
    reservoir and THEN do the bleeding. Obviously you have to have something
    between the pads to take the place of the disc and fingers aren't
    recommended.
    I drop an allen key between the pads/pistons, coz there's always on which is
    exactly the right size.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 7, 2008
  12. JackH
    JackH Guest
    So it would seem.
    Anyway, as per my other post, hitting it with a decent bleeding tool as soon
    as it arrives. :)
    JackH
    98 Honda VFR800FiW
    05 Sachs Madass
    JackH, Nov 7, 2008
  13. JackH
    Beav Guest
    And if violence doesn't work, use more violence (I'm not whooshed either)
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 7, 2008
  14. JackH
    DR Guest
    Two wrongs don't make a right. There has been no definitive
    proclamation as to the relative moral value of three or more, however.
    DR, Nov 8, 2008
  15. JackH
    deadmail Guest
    Well... the Mityvac isn't the solution to all bleeding problems. It
    doesn't seem to work well at all on the K100 sidecar; even with a
    previous set of brake lines/calipers.
    Odd that 'cos it worked well on the K75.
    deadmail, Nov 8, 2008
  16. JackH
    Beav Guest
    I've tried a variety of bleeders over the years and so far I've not found
    one that's perfect for all jobs. Getting the caliper above the reservoir
    works VERY well and using a **** off big syringe to shove the fluid UP the
    system if the caliper removing is too much hassle also works well. Very,
    VERY well.
    Have you got a high point in the caliper where air can sit and not be
    disturbed?
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 8, 2008
  17. JackH
    My experience is similar and have recently going down the syringe route.
    Very successful with bike systems - so far.
    sweller, Nov 8, 2008
  18. JackH
    deadmail Guest
    No. It's strange 'cos the K100 and K75 are virtually identical and I
    didn't have problems with the K75 (or any of the previous K100s I've
    owned (four of them I think).
  19. JackH
    Beav Guest
    Well other than a brake line that's porous, I can't think of anything that
    would stop the system from bleeding.
    A brake system needs..
    A master cyl that pumps but doesn't suck
    Brake lines/banjo's that don't leak
    Calipers that don't leak
    Pistons that move
    Seals that seal
    Nipples that close properly.
    If you've got all that, get a syringe (big one from t' chemist) and a length
    of tubing, attach the tubing to the caliper nipple, open the nipple and
    squeeze the syringe. The slower the better because it avoids frothing the
    fluid. Pump the fluid UP the system and the job "should" be sorted.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Nov 9, 2008
  20. JackH
    fragmented Guest
    You kinda forgot to say what the syringe should be full of, air or brake
    fluid? ;)
    fragmented, Nov 9, 2008
