Paging the BMW K'isti
Discussion in 'UK Motorcycles' started by Steve, Apr 15, 2011.
  1. Steve
    Steve Guest
    I got given a RH pannier in the belief that it was a GS pannier ,
    but its actually for a K1100 (I think).
    It's free if you want it.
    Steve
    Steve, Apr 15, 2011
  2. Steve
    RB Guest
    I could use that for the K1100LT I bought from my neighbour; I haven't
    got around to fitting the new latches to the panniers yet.
    I don't know your location, but I could sort out an interparcel
    collection & mail you the labels, (although that would leave you
    waiting in for a courier). I'd want to send you a token equivalent to
    (say) a bottle of Laithwaite's.
    Bear it in mind if you don't get a reply from a more regular (or
    local) contributor.
    Regards,
    RB
    RB, Apr 15, 2011
  3. Steve
    TOG@Toil Guest
    If you need a hand or advice with the latches, let me know. Last year,
    I spent a happy afternoon fitting new locks to the panniers on my
    K1100LT, and trying to figure out how it was done. Light dawned in the
    end.
    TOG@Toil, Apr 15, 2011
  4. Steve
    Steve Guest
    I can sort it out via parcel2go , shouldnt be more than a few quid.
    Drop me an e mail and we'll take it from there.
    Address in the headers is valid.
    Steve
    Steve, Apr 15, 2011
  5. Steve
    Had they changed? They used to be pop riveted on.
    Hog, Apr 15, 2011
  6. Steve
    TOG@Toil Guest
    They still are. I was fitting new locks.
  7. Steve
    Oh new tumblers, that's a fun little job ;o)
    Hog, Apr 15, 2011
  8. Steve
    RB Guest
    Thank you. I have new latches from Motobins & need to swap in the old
    locks. As ever, I was thinking "How hard can it be?" I'll have a go at
    the week-end (assuming I don't have to go and collect a new trials
    bike for son) & 'fess up if I fail.
    RB, Apr 15, 2011
  9. Steve
    TOG@Toil Guest
    It helps immensely if you put the key in the new locks, and turn the
    key this way and that, to observe how all the tumblers line up.
    Basically, there'll be one that doesn't. IIRC that'll be the one
    nearest the keyhole, as it were. And you need something slim and
    pointy to push that down. They're all spring-loaded, incidentally.
    Once you've got that sussed, removing the old ones is a matter of
    putting the key in the old locks, turning it to align the tumblers,
    and then using your pointy-thing to push down the tumbler that's still
    protruding, and then pulling the entire lock out of the barrel. It's
    harder to explain than it is to visualise when you've got all the bits
    in front of you.
    I must have spent an hour or more fiddling with the locks and
    squinting at the tumblers from a distance of two inches before this
    light suddenly dawned. I knew it should be very simple, because
    Motorworks offer to fit the locks for you for just a few quid if you
    buy panniers from them, so if you knew the technique, it had to be a
    swift process. And so it proved. Once sussed, a doddle.
    There's a good article (I discovered later) on one of the BMW sites,
    as well, with photographs.
