Paging the Bimmer K experts.
Discussion in 'UK Motorcycles' started by Brownz \(Mobile\), Mar 3, 2009.
  1. My ol' K100RS is in fine fettle, apart from the Belly Pan frame.
    It's 20 yrs old and sits in the road shite, so I'm not surprised.
    I ordered a replacement from Motorworks, it's second hand and slightly
    different, but looks as if it can be adapted with supplied bracketry.
    Only problem is the front LH mount, just in front of the oil filter cover on
    the sump.
    It looks as if it has had rubber attached to it at some point.
    I guess its replaceable, but am unsure if it should unscrew from the sump.
    Can anyone confirm / deny before I attack it with mole grips / cold chisel.
    http://atschool.eduweb.co.uk/brownie/kbp1.jpg
    http://atschool.eduweb.co.uk/brownie/kbp2.jpg
  2. Brownz \(Mobile\)
    Steve Parry Guest
    Yes they had a thread either end with rubber in between
    http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?mospid=47866
    Diagram #46_0170
    Steve Parry
    BMW R80RS, 03 BMW R1100S Boxercup, 07 K1200GT SE
    95 BMW F650, 87 Yamaha FS1, Sukida SK90PY, 91 Kawasaki AR50,
    BMW 330Ci
    www.gwynfryn.co.uk
    Steve Parry, Mar 3, 2009
  3. Brownz \(Mobile\), Mar 4, 2009
  4. Brownz \(Mobile\)
    Steve Parry Guest
    Glad to be of service :) I replaced that same part on mine after a few years
    when the rubber unglued itself.
    Steve Parry
    BMW 330Ci
    www.gwynfryn.co.uk
    Steve Parry, Mar 4, 2009
  5. Oh well, a good overnight soaking in wd40, and first I try the grip spanner,
    no luck.
    Mole grips prove to be useless as well.
    A cold chisel and hammer seems to do the trick, until <Tap tap tap - crack
    ping>
    http://atschool.eduweb.co.uk/brownie/oh_fup.jpg
    Anyone engineering guru types any good at extracting well seized M8 threads
    (recessed) from K100RS sumps and willing to travel to OX12, cash/wine
    renumeration and a free supply of tea/coffee/sandwiches available.
  6. Using the patented Mavis Beacon "Hunt&Peck" Technique, "Brownz (Mobile)"
    Clumsy ****.
    Email me a snail address and I'll pop a suitably sized LH drill bit or
    two in the post.
    Wicked Uncle Nigel, Mar 4, 2009
  7. Ohh ta, I'll give that a go first, if that ends in lots of "fuckits" then
    Bonner's helicoil idea is a good back up plan.
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, "Brownz (Mobile)"
    Okey doke. The gmail address ought to work.
  9. Brownz \(Mobile\)
    Steve Parry Guest
    Put it in the oven, on full blast, for 20 mins first.
    Steve Parry
    BMW 330Ci
    www.gwynfryn.co.uk
    Steve Parry, Mar 5, 2009
  10. It won't fit .... especially now I've bought a set of proper panniers
    instead of those city cases......
    browniebrownz, Mar 5, 2009
  11. Brownz \(Mobile\)
    Steve Parry Guest
    The sump cover :p
    Steve Parry
    BMW 330Ci
    www.gwynfryn.co.uk
  12. I was in the Fatherland from last Friday until about 2hrs ago.
    A quick search found a company called Siebenrock -
    http://www.siebenrock.com/ who advertised having a like new 2nd hand one in
    stock.
    Ordered on Thursday afternoon, delivered to my hotel in Hanover and arrived
    before I did on Friday morning.
    30 euros + 9 euros delivery, and they're not wrong, as far as I can tell,
    it's never been on a bike !
    I love it when a plan comes together !
    Brownz \(Mobile\), Mar 9, 2009
  13. Brownz \(Mobile\)
    zymurgy Guest
    ooh ooh.
    What's the smallest LH drill bit you have ? mine are all between 6 &
    8mm.
    Unfortunately I need to get a snapped screw shank out of an FJ block
    that's about 4mm in diameter.
    Do you have any 3 or 4 mm left hookers ?
    Cheers,
    Paul.
    zymurgy, Mar 9, 2009
  14. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    I do. Email me a snail-mail address to the gmail in the header and I'll
    pop some in the post.
    Wicked Uncle Nigel, Mar 9, 2009
  15. I'll drop yours back in the post this week as I have a spangly new sump (see
    above - result).
    Can I pop the old sump over to you at some point to give it a go ?
    I guess you may have a better setup than a B&D Workmate and an aging
    reversible hammer drill !
    No probs if it can't be salvaged.
    Brownz \(Mobile\), Mar 10, 2009
  16. Using the patented Mavis Beacon "Hunt&Peck" Technique, "Brownz (Mobile)"
    No problem.
    Wicked Uncle Nigel, Mar 10, 2009
  17. Brownz \(Mobile\)
    zymurgy Guest
    Will do, ta.
    Paul.
    zymurgy, Mar 10, 2009
  18. Brownz \(Mobile\)
    Adie Guest
    you'll both be in the same place in a couple of weeks.
    Adie
    UKRM FAQ: http://www.ukrm.info/faq/
    YZF-R1 : ZX9R-E1
    keeper of the FAQ for my sins
    Adie, Mar 10, 2009
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, Adie
    Ah! Good point.
  20. Aye, good call.
