paging the Benly-isti
Discussion in 'UK Motorcycles' started by darsy, Nov 8, 2003.
  1. darsy
    I have an 11/16th spanner anyway, so pffft!
    darsy, Nov 9, 2003
  2. darsy
    This is normal IME. It's weirdy brit bikes where this isn't the case..
    sweller, Nov 9, 2003
  3. darsy
    well, sure, on - say - my Fireblade, the sprocket isn't bolted to the
    rear wheel, it's connected via the cush drive; the CD is the same, but
    when you take off the rear wheel the sprocket remains in place, with
    no fannying around with the chain. This is not the case on any other
    bike I've owned.
    darsy, Nov 9, 2003
  4. darsy
    I meant that the rear sprocket remains attached to the swinging arm.
    Normally refered to as a QD wheel, v. common IME. All the '70's UJMs I've
    owned have it, as do MZs.
    I'm surprised that the fireblade doesn't, but I've not worked on any
    modern sports bikes so have limited experience here.
  5. darsy
    Salad Dodger Guest
    I guess the issue is decided by the depth of cush drive needed, in
    order to transmit the power.
    If the sprocket remained attached to the swing arm, you'd never get
    the clearance to pull the wheel out.
    It's hard enough on the Wing, and that's only possible, cos it's got a
    spacer like a waste pipe on the lhs.
    | ___ Salad Dodger
    |_\_____/_| ..61132../..14035.../..3157./.19406
    \|^|/ ANORAK#17
    Salad Dodger, Nov 9, 2003
  6. darsy
    deadmail Guest
    Coo. isn't it small.
    deadmail, Nov 9, 2003
  7. I've got to go through all this, because my/our/The Doctor's new Benly
    need a rear tyre and I picked one up at Kempton Park autojumble[1].
    Metzeler Perfect, 2.75-17[2], all of 20 quid brand new. SOBs, don't you
    love 'em?
    Oh, and a new chain. Also from KP, for a tenner.
    [1] Ash Of This Parish happened by, and we had a coffee, and a wander,
    and generally shot the breeze. And he fielded my stand and sold a
    tankbag to a punter, while I was off buying Jamie's army boots.[3]
    [2] It should by rights wear a 3.00-17, but the only tyres I could find
    in that size were Cheng Shins at ukp24 and something called a Deli, made
    in Malaysia, at ukp19, and with a tractor-like tread pattern. I figured
    a Metzeler, a quarter of an inch narrower, was better than either. And
    at that price....
    [3] Needed for the ATC. Germany paratrooper boots for ukp35.
    The Older Gentleman, Nov 9, 2003
  8. darsy
    deadmail Guest
    heh. they used to be my bike boots of choice. Think they cost about 6-
    when I wore them though.
  9. All the one's *he's owned*, YTC. In other words, just MZs.
    The Older Gentleman, Nov 10, 2003
  10. darsy
    deadmail Guest
    An MZ is a UJM???
    deadmail, Nov 10, 2003
  11. darsy
    Mmm, in hindsight given I've only owned Hondas (var. CBs) and Suzukis
    (var. GSs), which don't really cover the full spectrum of awful '70s UJMs
    your memory may not be as fucked as we think.
    "We'll be going for a walk later.."
    sweller, Nov 10, 2003
  12. darsy
    They became quite expensive at one point, but have come down in price of
    late. Mainly as they aren't steel toe capped and are unsuitable for
    workwear (building sites and the like).
  13. Oh, er, ah, yes.
  14. darsy
    Story of my life
  15. darsy
    deadmail Guest
    Err... I thought "J" stood for Japanese. So now I'm confused.
