Paging the aircraft anoraks
Discussion in 'UK Motorcycles' started by SteveH, Feb 19, 2006.
  1. SteveH
    Wizard Guest
    Rusty Hinge 2
    () says...
    Noisy for those not in it, though.
    The three streams of hot air from the engines would mix with the
    ambient air and each other and make a lot of noise.
    It's one reason why the 'British' engines-at-the-rear
    configuration largely died out in favour of the 'American'
    engines-under-the-wing layout.
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    BMW 520i (RIP- Ebay item 4601147727)
    Toyota Nondescript 1.3 Mobility Appliance (on loan)
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Remove location from email address to reply
    Wizard, Feb 20, 2006
    #41
  2. SteveH
    muddy Guest
    Fucking commies getting into everything again.
    muddy, Feb 20, 2006
    #42
  3. SteveH
    gomez Guest
    I thought butterflies were pretty much sole trader entrepaneurs?
    gomez, Feb 20, 2006
    #43
  4. SteveH
    muddy Guest
    The Party will have none of that.
    muddy, Feb 20, 2006
    #44
  5. SteveH
    gomez Guest
    There is a party? Why wasn't I told? Is it fancy dress or can I come
    as I am?
    gomez, Feb 20, 2006
    #45
  6. Trident?
    The Older Gentleman, Feb 20, 2006
    #46
  7. SteveH
    Wizard Guest
    @mygate.mailgate.org>, Andy Wegg
    () says...
    Thing is, Rusty Hinge referred to
    "a three tail-mounted engined thing about the same size"
    (as a Viscount)
    Both DC-10 and TriStar had two engines mounted below the wings,
    and only one tail-mounted, and were substantially bigger than a
    Viscount- 250-odd passengers.
    Three tail-mounted engines would be Trident, 727, or something
    Russian.
    <8P Wizard
    #47
  8. I think he might have had red admirals in mind.
    Rusty Hinge 2, Feb 20, 2006
    #48
  9. The message <1hb1qth.131qerhbzyqdbN%>
    from (The Older Gentleman) contains
    these words:
    Triplicate
    #49
  10. I only ever flew to anywhere in Scotland with British Cal or BEA, and
    I'm pretty sure the BEA planes were't Tridents.
    BICBW
    #50
  11. Which stats perplexed the crew of a Bear one day, when over the Arctic
    and pointing at the UK they found themselves being escorted by two
    Lightnings.
    Not before time, mid-air refuelling had been added to their functions.
    One of my mates was a Lightning engine mechanic/w.h.y? and he reckoned
    that they were the most difficult to work on, and that there had to be a
    special kit for one particular nut, with an assortment of multi-cranked
    spanners to turn it - a flat at a time, or similar.
    #51
  12. SteveH
    Tell him to try replacing the throttle cable on a Renault Kangoo -
    anything will seem a breeze after that.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    Krusty, Feb 20, 2006
    #52
  13. SteveH
    muddy Guest
    Right, there you go.
    muddy, Feb 20, 2006
    #53
  14. SteveH
    muddy Guest
    Something in dark green I think and a little red book in the pocket.
    muddy, Feb 20, 2006
    #54
  15. SteveH
    Andy Hewitt Guest
    Or even it's relative distance to the aircraft.
    Andy Hewitt, Feb 20, 2006
    #55
  16. SteveH
    Andy Hewitt Guest
    Actually it isn't. The greater force will only be minimised by the
    amount of the smaller force (providing they are along the same plane).
    In this case the effect will almost be immeasurable for practical
    purposes.
    #56
  17. If it was BEA they definitely *were* Tridents. BCal - dunno.
    #57
  18. SteveH
    Wizard Guest
    () says...
    Agreed, but if you look back that thread, Rusty's talking about
    Stornoway, where they had Viscounts, then extended the runway
    for jets. A DC-10's a bit of a big jump up from a Viscount.
    I know BCAL had BAC1-11s, and BEA had Tridents. Maybe Rusty's
    recollections has blurred them.
    Or did either of those airlines ever have 727s? Seems possible
    but unlikely.
    <Mode = Esther Rantzen>
    Unless, of course, you know different...
    <8P Wizard
    #58
  19. SteveH
    Ali Hopkins Guest
    Ah. Saw one at an airshow at El Toro, CA. V loud beggar.
    DC10, Shirley. Oh, whoops - maybe a Trident, do you know what year?
    Ali
    Ali Hopkins, Feb 20, 2006
    #59
  20. SteveH
    Ali Hopkins Guest
    Ye canna' change the laws o' physics, Cap'n.
    Ali
    #60
