Paging the aesthetes
Discussion in 'UK Motorcycles' started by ogden, May 14, 2005.
  1. ogden
  2. ogden
    Timo Geusch, May 14, 2005
  3. ogden
    Jesus H, man, pull your punches!
    ogden, May 14, 2005
  4. ogden
    tallbloke Guest
    The precise position and angle of visibility of direction indicators are not
    part of this inspection, but they must be on each side of the longitudinal
    axis of a solo machine.
    Pretty marginal in this case. Could be misinterpreted at night?
    tallbloke, May 14, 2005
  5. ogden
    tallbloke emerged from their own little world to say
    I agree with your point about being marginal as far as MOT regs are
    concerned. Why would the signal be misread?
    My VFR had a light unit with a central red section for the tail light
    with orange indicators either side.
    From the rear all another road user sees is an orange light flashing
    either to the right or left of a red light. Pretty obvious which
    direction the bike is going.
    (I'm assuming that the tail light is always on)
    wessie, May 14, 2005
  6. ogden
    mups Guest
    mups, May 14, 2005
  7. ogden
    mups Guest
    ogden says...
    Heh, wasn't what I was implying but it'll do.
    mups, May 14, 2005
  8. ogden
    simonk Guest
    simonk, May 15, 2005
  9. ogden
    darsy, May 15, 2005
  10. ogden
    You have the right of it there: Construction and Use Regs state it. I
    can't recall the exact figure right now, but it would mean that if I
    built the indicators in to the rear light on the RF they would be 5mm
    too close together.
    This is something you could be nicked for, but would pass the MoT test
    and therefore prolly worth the risk. Coming across a Pod of Plod
    comprising a Measuring Plod, a Counting Plod and a Plod Wot Knows the
    Law is unlikely, to say the least.
    Pip, May 15, 2005
  11. ogden
    tallbloke Guest
    Fair point. I wonder if there are enough red leds in one half to kick out
    the required wattage for a stop signal with the tail light on too.
    tallbloke, May 15, 2005
  12. ogden
    Salad Dodger Guest
    There are LED replacement stop-tails available that "spin" when on,
    and flash when braking. Probably totally illegal, but more than a
    little tempting.
    Salad Dodger, May 15, 2005
  13. ogden
    Salad Dodger Guest
    On a similar not, is there a limit to the number of indicators you can
    have at the back?
    Would a pair on the panniers and a pair on the topbox be okay?
  14. Plenty of lorries and buses have multiple sets.
    Grimly Curmudgeon, May 15, 2005
  15. ogden
    Ben Blaney Guest
    But he was talking about a Gold W...
    Oh, I see. As you were.
    Ben Blaney, May 15, 2005
  16. Axminster, iwt.
  17. ogden
    Bear says...
    You're dead right. They had to change the rear light lenses and fit a
    new set of indicators to the back of the pop-up headlight GSX750 Katana
    around 1987/88.
    Lozzo, May 15, 2005
  18. ogden
    Kiran Guest
    That wasn't always the way though, was it?
    Kiran, May 15, 2005
  19. ogden
    BGN Guest
    When I was last in Thailand I noticed that cars had these, very
    distracting. It would appear that some of them spin faster the harder
    the braking.
    BGN, May 15, 2005
  20. ogden
    tallbloke Guest
    @individual.net:
    Repeaters are ok AFAIK
