Paging Simon Atkinson
Discussion in 'UK Motorcycles' started by Nigel Eaton, Dec 14, 2004.
  1. Nigel Eaton
    tallbloke Guest
    Wow. A mate of mine is building a 5.2 litre RV8 engine. He's got a pair of
    heads from a 1964 buick which have the biggest valves feasible, and forged
    pistons etc.
    I asked about the turbo because SAAB have found they can get 10% more
    horsepower out of their standard turbo engine on LPG than unleaded.
    tallbloke, Dec 19, 2004
    #61
  2. That's right - I was agreeing with you.
    Bloody hell... You could buy an old Rangie with one fitted for that and
    swap over whatever you want.
    You'll need to tap a small pipe from the inlet tract upstream of the
    mixer (but downstream of the turbo) to the 'atmosphere' side of the
    vapouriser so that it understands the pressure it's working at (that
    part of the inlet tract would normally be at atmospheric pressure -
    unless there was a very restrictive air filter) and then regulates the
    lpg based purely on the pressure drop through the venturi in the mixer.
    Otherwise it wont release any gas once the turbo starts spinning as it
    wont 'see' any suck!
    Talk to the chap at RPI (Chris IIRC) he is Mr V8 tuning - it was him
    that built the engine in the SD1 for Clarkson.
    You will definitely be better off going closed loop - the feedback from
    the Lambda sensor will keep the gas mix a lot more accurate - it's only
    a stepper motor connected to the regulator and a PIC controller.
    Is it a carb'd engine then or injection? If it's injection you'd be
    much better off with gas injection - although it's dearer to fit - you
    can alter the characteristics via your PC.
    Simon Atkinson, Dec 19, 2004
    #62
  3. That's due to the 104 RON. You just need to get enough air and gas
    crammed in! And not to worry too much if the exhaust gas doesn't 100%
    comply with MOT requirements...
    #63
  4. Nigel Eaton
    I thought that the V12 was a lean burn / high comp engine?
    Muck, Dec 19, 2004
    #64
  5. It's quite low powered (by most standards) for the size.
    #65
  6. Nigel Eaton
    Is it what I thought it was then?
    Muck, Dec 19, 2004
    #66
  7. Nigel Eaton
    tallbloke Guest
    Sure, I was just restating for clarity.
    I meant an SGI system
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=9895&item=
    7940300773&rd=1 'kinell, it went fro 720 quid!
    Excellent, thanks for that.
    There actually is one in with the kit I got, but the guy threw in a simple
    'adjust the screw 'til it works' valve as well. I'll have a go at the
    Lambda sensor method if that'll be ok with the turbo.
    It's an early injection SD1 from 1983. Injection would be lovely, but see
    ebay auction above!
    #67
  8. Nigel Eaton
    tallbloke Guest
    Yep. The APC controller in the SAAB allows the boost to increase until
    it's about to cause pre-ignition, the higher octane helps prevent pinking
    up to higher boost pressures.
    I'm wondering if I could fit an APC circuit board from a SAAB to my lash-
    up and thereby create a variable boost system.
    My TVR exhaaust system is already suitably devoid of nasty resrictive
    boxes ;-)
    #68
  9. Not really. It's a standard comp engine tuned for torque.
    #69
  10. That's not all that cheap, even for an SGI system. You could buy new
    for not too much more (assuming self fitting).
    The screw adjustment ones are OK on low reving engines with lots of
    torque (rangies - especially if used round town), but as soon as you
    floor the throttle the mix tends to go horribly lean (can you say burnt
    out valves). Generally with them you rev to 1/2 maximum (about 3000 on
    the rangie) and tweak the screw until the engine starts to die, then
    back it off half a turn. Not all that scientific, but it works after a
    fashion.
    Closed loop is the kiddie. Effectively you are monitoring the exhaust
    and adjusting the screw with a stepper motor as you drive. Works well.
    When I changed my Rangie from the fixed screw to the closed loop I
    reckon I got about 2 or 3 mpg more and it felt like double the power
    when it kicked down to overtake. If you have the bits already, fit
    them and be impressed. You prolly haven't got a lambda sensor fitted,
    but it's a doddle, just fit one, at the point (or just after) where the
    two exhausts siamese into one (if yours do that). I believe you can
    fit two and join their output together, but you'd need an electronics
    gizmo to do that properly.
    #70
  11. Nigel Eaton
    tallbloke Guest
    It was a new Zavoli kit
    Excellent advice, thanks again.
    #71
  12. Nigel Eaton
    tallbloke wrote:
    There's also a knock sensor to go with that. It's screwed into the
    engine block somewhere and listens for the tell tale changes in sound
    that the onset of pre ignition causes. If it's not bolted in the correct
    place, or at the wrong torque, it'll give false positives.
    Muck, Dec 19, 2004
    #72
  13. Nigel Eaton
    Simon Atkinson wrote:
    Maybe I was hearing about some other lean burn high comp V12.
    Muck, Dec 19, 2004
    #73
  14. Nigel Eaton
    tallbloke Guest
    The new Jag Diesel? or is that a six?
    #74
  15. That's a 6 - and like driving a nicely updated Granada. It's not a Jag
    (not a proper Jag).
    #75
  16. Nigel Eaton
    *perk*
    Champ, Dec 19, 2004
    #76
  17. Nigel Eaton
    Naa, nothing new. It was a few years ago, when I was an AXE10 support bod.
    Muck, Dec 19, 2004
    #77
  18. Nigel Eaton
    LPG Saab Turbo company car sir? _Suits_ you sir... ooo...
    Muck, Dec 19, 2004
    #78
  19. Nigel Eaton
    Maybe that was it, for V12 values of clean. :eek:))
    Muck, Dec 19, 2004
    #79
  20. Nigel Eaton
    Not a bad improvement for sure, still better than my 2.25l Land rover
    and my old SD1.
    Yikes, I thought that replacing the plugs on my SD1 V8 was bad enough...
    but 12 of the buggers? No thanks. :) I don't think I'd want to do
    anything else on that motor. Those V12 motors look lovely when painted
    up and polished, I saw one in a big bike[1] at a Swedish bike show.
    [1]Tractor tires big.
    Muck, Dec 19, 2004
    #80
