Paging Simon Atkinson
Discussion in 'UK Motorcycles' started by Nigel Eaton, Dec 14, 2004.
  1. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    I'll do that. Ta.
    Nigel Eaton, Dec 15, 2004
    #41
  2. Nigel Eaton
    Bear says...
    Who will be whose bitch?
    Lozzo, Dec 15, 2004
    #42
  3. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    Look, it's a great car. But let's not get carried away, eh?
    #43
  4. Nigel Eaton
    Nigel Eaton Guest
    FS: Jaguar XJ40...
    #44
  5. Nigel Eaton
    Nigel Eaton Guest
    Hmm... You'd have to prove you've got somewhere to park it.
    And that you don't mind being rogered by Lozzo on a twice-nightly basis.
    #45
  6. Is that worse than being Lozzo'd by Roger?
    Christopher Des Clayes, Dec 15, 2004
    #46
  7. Right - sorry about the delay replying, been hiding.
    The bloke you want is (IIRC) Called Tim, and he's an enchanter...
    You can find him in the enchanted forest or ring him on 01536 201888,
    but don't di it if you're in a hurry...
    I bought a fuel pump off him for mine, 400 quid from Guy Salmon or 50
    quid from Tim. He's incredibly knowledgable about old XJ's and can
    talk for England about them.
    I noticed further down the thread you mention the fuel consumption and
    LPG - LPG isn't good on those engines. It'll work OK, but really you
    need a dual pressure Sequential Gas Injection system, and on a Jag of
    that age and milage, it's really not worth it. I always felt the Jags
    were quite frugal compared to my usual stable of Range Rovers.
    The gas isn't really better for the engine - the oil stays cleaner
    looking because you don't get the particulates of carbon dirtying the
    oil that you get with petrol - but equally you don't get a spray of
    nice cool petrol on the inlet valves... Save the money and buy big
    boot spoilers and a loud stereo.
    The brake booster error on it could easily be just the sensor - have
    you tried reseting it to see if it goes away? IIRC it's a matter of
    whipping the battery off overnight - watch out that you find the radio
    code. Otherwise it could be one of the relays for braking system
    playing up - that's what it was on mine - I kept getting ABS and other
    brake errors until I took all the relays out, cleaned them, checked
    them around a bit and reset the computer.
    Simon Atkinson, Dec 18, 2004
    #47
  8. Octane rating is 104, but the calorific value is around 80% that of
    petrol - so to make the same or more power, you need to get more in.
    I drove an LPG rangie a couple of years ago that was making 450bhp on
    gas. Went very nicely.
    #48
  9. The emulators merely stop the ECU going into limp-home mode when you
    shut off the petrol. They just feed an injector like signal back to
    the ECU when you're running on gas.
    The Rangies run better on a proper SGI system, but will chug along
    happily enough on an open loop demand valve system.
    #49
  10. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Simon Atkinson
    Heh. Noted, ta.
    I mentioned the fuel consumption in a "hey-ho" stylee. Others mentioned
    LPG, I wouldn't personally fit it to this lump.
    The battery was very. very flat when I collected it from Bear's Welsh
    Holiday Cottage, so I suspect that's been taken care of. I shall have a
    fettling session with the relays.
    Nigel Eaton, Dec 18, 2004
    #50
  11. Nigel Eaton
    Simon Atkinson wrote:
    Water injection at higher powers would cover the inlet valve cooling,
    I'd bet.
    Muck, Dec 18, 2004
    #51
  12. Nigel Eaton wrote:
    I wouldn't rely on that - as long as there are a couple of voles
    kicking around they seem to the keep the error codes stored.
    I'd certainly start with the relays and connections - it's all made by
    Joe Lucas for a start, so it's a bit of a no brainer. If that doesn't
    fix it, Tim will know the solution.
    #52
  13. It's not the higher powers that do it, it's the continuous running at
    power (like a long motorway drive) that burns out the valves.
    #53
  14. Nigel Eaton
    Pete M Guest
    In
    Those Jags have everything don't they? Electric windows, power steering,
    Voles.
    They've probably built a small squirrel into the dashboard to make squeaks
    as well.
    Pete M
    Mercedes 260E
    Ford Capri (ressurection started)
    "Never moon a werewolf"
    COSOC #5
    Scouse Git extraordinaire. Liverpool, Great Britain
    Pete M, Dec 18, 2004
    #54
  15. The nuts don't fall off Jags - they are hidden by the squirrels.
    #55
  16. Nigel Eaton
    I see, yes. Tricky problem that. A mate of mine had a LPG Jag in out in
    Oz, it may have been the V12. Maybe that's why it never burned any
    valves out?
    Muck, Dec 18, 2004
    #56
  17. Nigel Eaton
    tallbloke Guest
    450bhp? was it turbo'd?
    tallbloke, Dec 19, 2004
    #57
  18. Nigel Eaton
    tallbloke Guest
    So not needed on early sd1/rangies then.
    There's one of those on ebay atm which has hit 585 quid and 35 bids so
    far.
    I've acquired an open loop system to fit to the sd1 engine in my TVR. I'm
    intending to stick a turbo on too, but I'm getting conflicting advice
    about how to balance the diaphram pressure in the vapouriser.
    #58
  19. Much older engine and lower tuned. Maybe he was lucky.
    Simon Atkinson, Dec 19, 2004
    #59
  20. No. Owned by RPI (www.rpiv8.com), Heads skimmed, bigger valves,
    hi-comp pistons, Inlet manifold job done, exhausts and overbored and
    stroked to 5.3 litre (about as far as you can go without the pistons
    being visible from outside). Sports suspension, brakes. Was a thing
    of beauty.
    #60
