Paging Simon Atkinson
Discussion in 'UK Motorcycles' started by Nigel Eaton, Dec 14, 2004.
  1. I saw a great thing on Discovery last night where they were going to
    prove/disprove myths on driving and engines. They got themselves a
    Cadillac and tried various things to kill it like sugar in the petrol,
    bullets in the fuel tank, pennies in the carbs but the most interesting
    thing was mothballs in the fuel - this did make it run much sweeter and
    upped the octane rating. The thing that did finally destroy it though
    was bleach in the oil ;)
    Whinging Courier, Dec 15, 2004
  2. Nigel Eaton
    Excellent. How about these CNG cars, now they sound dangerous to me.
    Tallblokes Ovlov smelled weird like that, kinda nice though.
    <snip>
    Now.. If I could only run the FZR250 on gas...
    Muck, Dec 15, 2004
  3. Nigel Eaton
    :eek:)) That'll do it. I'd imagine that filling the sump with Castrol R40
    would have much the same end result.
    Muck, Dec 15, 2004
  4. I saw that, the mothballs definitely did something positive.
    Did the bleach dissolve (?) into the oil or would it be the same as
    putting a litre of water in with the oil
    Mick Whittingham, Dec 15, 2004
  5. But the smell man the
    smell................................................
  6. Nigel Eaton
    Castrol R40 is why I need another 2 stroke bike. :)
    Muck, Dec 15, 2004
  7. Nigel Eaton
    I think the bleach must have done something to the oil maybe, I tried
    soapy water in an engine, and it ran ok for 10 hard thrashed miles with
    no apparent ill effects like knocks or bangs.
    Muck, Dec 15, 2004
  8. Nigel Eaton
    tallbloke Guest
    Although LPG has a high octane rating, it has a lower calorific value than
    petrol.
    Well the early RV8 injected engines are ok on the bog flush sytem, but
    later Rangies need emulators on the injectors to function as dual
    fuellers.
    I wish my LPG powered VOLVO estate did.
    True enough :)
    tallbloke, Dec 15, 2004
  9. Nigel Eaton
    proper old-skool mothballs are mostly made of napthalene - it raises
    the octane rating. In the long term, some of the leastly components
    may **** the engine.
    darsy, Dec 15, 2004
  10. I luve the smell of Napalm in the morning..........................
  11. Nigel Eaton
    Muck says...
    You woouldn't have the smell for very long with a 2-stroke engine. R40
    isn't a 2-stroke oil.
    R30 on the other hand....
    Lozzo, Dec 15, 2004
  12. Nigel Eaton
    I live and learn..
    I thought R30 was just a thinner version of R40. I ran R40 in several 2
    stroke machines with no ill effects.
    Muck, Dec 15, 2004
  13. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Nigel Eaton
    55? Seems a bit small for a Jag tank. You sure there's not another one
    under the seats, a la Glodwing?
    Fwiw, the Scim has a 20gal (90L) tank; even the Tranny has an 80litre
    one.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Dec 15, 2004
  14. Nigel Eaton
    Muck says...
    You're lucky, it's not the stuff you should be using. 2-stroke oil is
    generally an SAE30 oil with additives.
    Lozzo, Dec 15, 2004
  15. Nigel Eaton
    Wik Guest
    FOYRNB(s).
    | Wik -UKRMHRC#10- 2003 R1150GSA -DC#1 -'FOT#0 'FOF #39 - BOD#12 BOB#12
    |# You don't believe me | "Experience is the worst teacher.
    |That the scenery | It always gives the test first
    |Could be a cold-blooded killer. | and the instruction afterward."
    ***** human response from wik at blueyonder dot co dot uk *****
    Wik, Dec 15, 2004
  16. Nigel Eaton
    Thanks, I'll use R30 next time then.
    Muck, Dec 15, 2004
  17. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    heh. It was 55-and-counting.
    Nigel Eaton, Dec 15, 2004
  18. I thought of buying some and skewering a couple on strings and
    suspending them in my petrol. It did sound much better.
  19. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Bear
    <Noted>
    I think a temporary bit of black tape may find its way over the light
    though. I'm anal about warning lights, and I keep catching it in my
    peripheral vision and twitching.
    I'll keep looking. I may have a go at a little gentle plastic welding.
    If you're a good boy I might let you have a go...
  20. Nigel Eaton
    Nigel Eaton says...
    Bring it round and let an expert at it.
    Lozzo, Dec 15, 2004
