Paging Platypus
Discussion in 'Classic Motorbikes' started by Lozzo, Apr 8, 2004.
  1. It was somewhere around Barstow, on the edge of the desert, when the
    50kwidlys and I'll pay for the pstoge.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Apr 10, 2004
  2. snigger.
    Austin Shackles, Apr 10, 2004
  3. anyone know?
  4. hmmm. possibly.
    Austin Shackles, Apr 11, 2004
  5. Lozzo
    I'm sort of considering slipping an old Daihatsu turbodiesel triple into the
    frame...
    http://www.peace65.freeserve.co.uk/Pictures/daihatsu.htm
    Platypus - (surreal)
    Triumph Trophy 1200 (The Incredible Hulk)
    VN800 Drifter (still for sale)
    R80RT (for sale - spares or repairs)
    Z200 (Fear the Distance Monster!)
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    platypus, Apr 11, 2004
  6. Austin Shackles, Apr 11, 2004
  7. Lozzo
    Ta, but I'm interested in the diesel route for reasons of weirdness and tank
    range, rather than simply getting it operational. I reckon a diesel RT
    could do Calais-Frankfurt non-stop.
  8. It was somewhere around Barstow, on the edge of the desert, when the
    Ya wee beauty! Somebody else has seen the light!
    'Bout 15 years ago I thought about that particular combination, but it
    was anothet 'tuit project. No particular reason that I could see why it
    wouldn't work, just a bit of custom flywheeling / engine plate and in it
    fits. The engine characterists are similar to the original lump, so the
    'box should be ok.
    The turbo 1000 pushes out around 90bhp, iirc.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Apr 12, 2004
  9. Lozzo
    The only drawback I can see is that I may need to make serious changes to
    the gearing - the RT's set to do 15mph/1000rpm (approx) in top. If the
    diesel will only rev to 3000 (say), then it's not going to be very fast.
    Better find some performance graphs for the diesel...
    platypus, Apr 12, 2004
  10. modern car diesels typically rev to about 4500-5000. Still only gets you to
    about 70 top speed, though, so yes, you'd need something done with the
    gearing.
    One day I may get around to making the 2-litre Rover motorcycle. I've a
    2000 TC rover engine sitting in the shed, 's been there about 15 years,
    since the car rusted away around it.
    Austin Shackles, Apr 12, 2004
  11. It was somewhere around Barstow, on the edge of the desert, when the
    Amendment - 70bhp, as I now recall.
    Aye, that was going to be a bit of a suckitandsee type of thing. I was
    thinking the top revs of the little Daihatsu lump wouldn't be too far
    off the boxer twin, but if necessary there would be a couple of
    solutions...
    a) Cheapest. A wire spoked rear wheel could be fitted and different
    (larger) diameter rim used. Clearance difficulties might present
    themselves, but that's what angle grinders are for.
    b) More pricey but possibly the most convenient. Search the Beemer
    archives for a suitable final drive box from some other model.
    c) More pricey but incovenient. Graft a Guzzi, Suzuki, Yam, whatever
    shaft / swingarm and bevel box on.
    d) Most expensive. Get some nice engineering shop to knock up a custom
    set of front or rear bevel gears.
    Whatever - I was convinced it was a do-able project and I'm still
    interested in it. I'm glad to see I wasn't wrong all those years ago.
    GS 850 x2 / SE 6a
  12. Lozzo
    The Older Gentleman was seen penning the following ode to ... whatever:
    Eh? I thought it didn't?
    Timo Geusch, Apr 13, 2004
  13. It did after the second instalment of bits went up, and timed out on
    Sunday evening :)))
    The Older Gentleman, Apr 13, 2004
  14. Lozzo
    On Fri, 9 Apr 2004 10:32:38 +0100,
    That's just criminal. How do you sleep at nights?
    Ace, Apr 14, 2004
  15. Lozzo
    Ace says...
    I've done worse. I broke an absolutely immaculate 13K mile old, rare
    blue paintwork RD250D with only 2 owners on the V5, purely because it
    was worth 3 times more in parts than as a whole. I did this 2 years ago.
    Lozzo, Apr 14, 2004
  16. Lozzo
    It was only a stroker, ffs. Get some perspective, you musclebound
    midget.
    Pip, Apr 14, 2004
  17. On a mattress stuffed with fifty-pound notes.
    The Older Gentleman, Apr 14, 2004
  18. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember
    (The Older Gentleman) saying
    something like:
    Can you feel the pea?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Apr 14, 2004
  19. Lozzo
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Grimly Curmudgeon
    With TOG in the bed you can probably smell it.
    Nigel Eaton, Apr 14, 2004
  20. Lozzo
    Yebbut, TOG did it with a proper bike.
    Ace, Apr 15, 2004
