Paging Platypus
Discussion in 'Classic Motorbikes' started by Lozzo, Apr 8, 2004.
  1. Lozzo
    Wassup wiff your BMW?
    Lozzo : The anti-Timo
    YZF1000R, GPZ500S, CB250RS x3
    BOTAFOT#57/70a, BOTAFOF#57, MIB#22, TCP#7,
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, BONY#9.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Artificial intelligence is no match for natural stupidity.
    Lozzo, Apr 8, 2004
  2. Lozzo
    Moffs, innit.
    Pip, Apr 8, 2004
  3. Lozzo
    Dropt a valve. Prolly. I haven't got around to stripping it down, but the
    noise and the chopped-up business end of the spark plug is evidence enuff.
    When the head comes off a valve, and you have a chunk of metal the size
    (initially) of a £2 coin being tenderised at 6Krpm, the result is going to
    be wildly unpretty. I expect that the inside of the combustion chamber will
    look like someone's been at it wif a blunt hatchet. Casualties will include
    head, barrel & piston, the conrod may be fuct and there's the possibility of
    crank damage.
    Still, mustn't grumble, good excuse to buy the Trofy etc.
    Platypus - (surreal)
    Triumph Trophy 1200 (The Incredible Hulk)
    VN800 Drifter (still for sale)
    R80RT (for sale - spares or repairs)
    Z200 (Fear the Distance Monster!)
    DIAABTCOD#2 GPOTHUF#19
    BOTAFOS#6 BOTAFOT#89 FTB#11
    BOB#1 SBS#35 ANORAK#18 TWA#15
    platypus, Apr 8, 2004
  4. Lozzo
    platypus says...
    <strikes R80RT off possible project list>
    Lozzo, Apr 8, 2004
  5. Lozzo
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    Emma Chizzit?
    Nigel Eaton, Apr 8, 2004
  6. Lozzo
    Nigel Eaton says...
    I've had her sister, Donna.
    Lozzo, Apr 8, 2004
  7. Lozzo
    New spark plug? Coupla quid. Don't reckon that's the only problem, mind.
  8. Lozzo
    platypus says...
    R80RT wiff a knackered engine's only gonna be worth about 50 quid.
    Lozzo, Apr 8, 2004
  9. Lozzo
    Bit more if I break it and stick the bits on Ebay:
    Technoflex shock (still under warranty)
    Full stainless exhaust
    Rear wheel with new (less than 100 miles) tyre
    Recent starter motor, coil, switches etc
    Rebuilt front forks with recon stanchions, Progressive springs etc
  10. ITYM "lots" more
    (Says the man who's just broken a running T&T 400 Four)
    The Older Gentleman, Apr 9, 2004
  11. Lozzo
    Cab Guest
    On Thu, 8 Apr 2004 22:53:43 +0100, Lozzo <>
    bored us all completely to death with wittery prose along the lines
    of:
    Why? Luvely bikes they are, IMO. Never had probs with the one I had
    years ago...
    Cab :^) - Ormiga Atomica
    GSX1400 - 'Tarts Handbag' (tm) Bike, dead 550/4 Rat
    UKRMMA#10 (KoTL), IbW#015, Bob#4, POTM#3
    P.S. Remove your_head from the cab. ICQ: 83023471
    Cab, Apr 9, 2004
  12. Lozzo
    Guest Guest
    <fx wipes slight drool from side of mouth>
    "Nah, wouldn't be worth much. But I'll take it off yer hands if you
    like..."
    Sereiusslly, are you going to mend it or flog it? If the latter, how
    much, and how far from Brisle?
    Regards,
    Simonm.
    Guest, Apr 9, 2004
  13. pity it's got a lunched top end, I quite fancy a set of 800cc barrels to go
    on mine. After carefully removing any indication of capacity, of
    course...:)
    spose I could fit one of 'em and have an R70...
    Austin Shackles, Apr 9, 2004
  14. *perk*
    now they'd go nicely on me R60. wonder if they fit? and wot sort of money?
  15. Lozzo
    Yup, make me an offer, and about a dozen miles.
    platypus, Apr 9, 2004
  16. Lozzo
    Depends on which R60: they're modified K100 telescopic forks on the
    monolever R80RT, and probably won't suit Earles-forked versions. Anyway,
    I'm a bit north of Brizzle: if you're in the vicinity, pop in and have a
    lewk. HBoL reckons stanchion OD is 38.425-38.450mm, which might be 2.5mm
    too big for you.
  17. Lozzo
    Rob Guest
    I think it was on Fri, 09 Apr 2004 20:24:03 +0100 that Austin Shackles
    A truly Sheddi proposition. I salute you sir!
    Rob
    Rob
    Broseley, Shropshire
    1991 Yamaha XV 535 Virago
    1997 Rover 623GSi
    Rob, Apr 9, 2004
  18. Mines a 60/6. Hmmm. HBOL say indeed what you say for an R80. it also say
    smaller ones for "all other models".
    bugger.
    wonder if the yokes would fit an' all... hmmm. only lists one kind of
    steering head bearings...
    Austin Shackles, Apr 10, 2004
  19. I try...
    Father once had a 175cc LE velo which had a 150 pot on one side and a 200
    pot on the other, apparently.
  20. Lozzo
    Mike Fleming Guest
    That'll be where Honda got the idea for the CB500T from, then.
    Mike Fleming, Apr 10, 2004
