Paging Paul Corfield
Discussion in 'UK Motorcycles' started by darsy, Nov 24, 2004.
  1. darsy
    Oyster cards. Pre-pay. Do you have to somehow specify the journey you
    will make with them?
    Say you wanted to go from a One Railways station near Enfield, which
    doesn't have a Oyster pad, to King's Cross, via Seven Sisters, which
    do.
    Here's the scenario:
    You'd get a Oyster, and charge it up. Then, you'd get on the train to
    Seven Sisters.
    At Seven Sisters, you'd do a "fake swipe in", by touching your Oyster
    card to the pad on the incoming gate. At the moment there's a "people
    diversion" out onto the street and then back into the station at SS, so
    this will confused things[1] , but we'll ignore that for now.
    Then, get the tube to King's Cross, and swipe out as normal.
    So, if I'm understanding how the Oyster card system works, you'd only
    be charged for a Zone 1-3 journey, rather than a Zone 1-5 one.
    The only catch I can see is if there is ever an inspector on the train
    between SS and the station near Enfield (I've never seen one after SS).
    Am I completely misunderstanding the Oyster card system.
    And apart from an analysis of my outlined fraudulent system, what are
    people who live outside the Oyster network /supposed/ to do?
    [1] currently, you'd swipe "out" and then back "in" at SS - if your
    first swipe "out" is on an Underground station, where does the Oyster
    system assume you'd swipe "in"?
    darsy, Nov 24, 2004
  2. First issue
    Oyster is not valid on One between Enfield and Seven Sisters. You need a
    separate ticket for that or you can dodge your fare if you wish to take
    that risk. It is TfL's wish to extend Oyster (and the LUL fare scale) to
    all rail services within Greater London and the Government have endorsed
    this policy - it is likely to be several years before this policy is
    adopted on all lines.
    Second issue
    Every Oyster card has the capability to hold a Travelcard Season ticket
    based on zones and also a Pre-Pay balance. You can opt to only have
    Pre-Pay if you wish. You can also chose to register your card or not -
    this affects your entitlement to refunds and to have the card "stopped"
    in the system if you lose it or it is stolen.
    Where you have a Travelcard ticket this will always override Pre-Pay in
    terms of travel validity. If you go outside the zones covered by your
    Travelcard then on exit the gate will look at the difference between
    where you are and where you are assumed to have travelled through and
    then your zones - if they both match then fine. If you have fewer zones
    then a deduction for the balancing cash fare will be made against your
    pre-pay. This will happen even if you have no cash in the pre-pay bit
    because the card balance can go negative. If this happens - the gate
    display will show this - then you cannot make another Tube, DLR or valid
    NR trip until you restore the pre-pay balance to a positive cash value.
    If you start your trip outside your zonal validity then a pre-pay
    deduction is made (see below for value) and then when you exist the
    correct balance is added or deducted to your pre-pay part to cover you
    for your whole trip. This is a nice automatic way of charging people
    who fare dodge by travelling outside of their zonal validity - assuming
    always that the gates are in service and people are forced to validate
    their cards.
    Now for some other things.
    Ironically Oyster is valid on the Main between Liverpool Street and
    Seven Sisters / Tottenham Hale and Walthamstow Central but not at any
    intermediate station. This is because those routes offer a parallel (in
    the loosest sense) service between Zone 1 and those stations - thus it
    is like a Tube line. There are many examples of this form of
    interavailable travel. Where there are no ticket gates at entry or exit
    points there will always be a validator to register the start or end of
    the trip.
    Oyster pre-pay works as follows
    As you enter the system the reader deducts £1.60 from your balance. If
    the fare for your trip is less than this then when you validate on exit
    the balance will be credited to ensure you are charged the correct. If
    your fare is greater than £1.60 then there will be an additional
    deduction up to that value. Special arrangements apply at Kings Cross
    and at Liverpool Street where you can exit from one side of the station
    (e.g. Vic Line) and then re-enter at another (e.g. Circle Line). The
    arrangements ensure you are charged a through fare from Seven Sisters to
    say Farringdon rather than Seven Sisters to KX and then KX to
    Farringdon. This only works provided that you change between the lines
    in a reasonable time.
    For your Seven Sisters example while the Seven Sisters Road tube bit is
    closed you would simply swipe in at the High Road entrance and then when
    you exit at your destination.
    Fares deducted from Oyster are at 2003 rates thus offering a discount
    over normal cash fares. There is also a big discount at weekends and
    bank holidays which is designed to encourage off peak traffic - from
    your nearest Picc Line station the fare to Zone 1 would be £1.80 rather
    than £3.40 on Mon-Fri. Bus fares are 70p rather than £1 for each trip.
    If you don't register in and then out consistently then your Pre-Pay
    will cease to function as there will be incomplete journeys on the card
    thus preventing the cash balance being reconcile. You then have to visit
    a ticket office to get your card reset with the correct deductions made.
    Pre Pay could, in theory be worth your while if you only travelled a few
    days a week and didn't need to use National Rail services. Given you are
    now a full flight management person a Travelcard would be better value
    when you are commuting regularly on public transport. There is no harm
    in having an Oyster Card to which you may occasionally load a Travelcard
    but meanwhile maintain a cash balance for Pre-Pay. You can then always
    get a discounted bus or tube trip if you need to.
    A full pre-pay only option would be to get a certain little local
    Enfield midibus service 3xx to a certain Underground station one stop
    short of the line terminus. You could use the other local midibus route
    1xx to a Victoria Line station from where you have the choice of pre-pay
    by tube or by National Rail. I expect that will be far too much bother
    for you to contemplate given your proximity to your local "One" station.
    Hope that long explanation helps.
    Paul Corfield, Nov 24, 2004
  3. darsy
    simonk Guest
    Wave your Oyster card at the bemused railway staff, who used to say "what
    the **** is that", but now generally say "My oyster reader doesn't work";
    and continue your journey.
    You get a printed ticket-style thing when you buy a monthly travelcard on
    Oyster from the station, which you can wave under the noses of benighted
    hayseed ticket inspectors, but IIRC you don't get one of these if you charge
    up your Oyster on the intarweb.
    A colleague at work was escorted off a (SWT) train when he was asked for a
    ticket, but could show only an internet-recharged Oyster card with no paper
    ticket. Feeling aggrieved, he got straight back on the train on the next
    carriage, and was then greeted by the police at Waterloo. When he proved to
    the assembled police and fat controllers that his Oyster was, in fact, valid
    "**** you all, you fucking fuckers" was I believe the phrase used
    simonk, Nov 24, 2004
  4. darsy
    Ben Blaney Guest
    It's good that he's so articulate. If only he'd thought to say
    something outstandingly witty such as "I'm as annoyed as Mr. Annoyed,
    winner of the Most Annoyed Competition". That would have been magic.
    Ben Blaney, Nov 24, 2004
  5. darsy
    I realised it is "fare dodging" - I just can't see how it could ever
    be caught, as there are never inspectors on the trains between Seven
    Sisters and Enfield Town; to me this is an inherant flaw in the
    concept.
    this is not for me - this is for Angie who usually works
    Unfortunately, despite what it says on the TfL Journey Planner, a bus
    from here to Oakwood (or Turnpike Lane, thinking "direct") at peak
    times can take up to 30 minutes.
    yes, and I very much appreciate you taking the time to give it.
    darsy, Nov 24, 2004
  6. darsy
    dwb Guest
    Does that include intercity services?
    dwb, Nov 24, 2004
  7. darsy
    Champ says...
    So am I, for a different reason.
    He's one of the few people I know who currently own almost as many bikes
    as I ever have done in total.
    Lozzo, Nov 24, 2004
  8. The concept isn't flawed. One Railway's revenue protection activity or
    the lack thereof is the flaw. Pre-pay was never designed to operate on
    your line - it is only recently that TfL have started to push their
    policy of fare integration so that all rail services will eventually
    have a common fare scale based on the Underground fare scheme. This sort
    of structure is common in Germany and the Netherlands.
    Any Pre-pay system (or stored value to give its proper term) should
    really be designed with a fully gated network where each rail network is
    sealed off from the other by gates to ensure everyone registers on entry
    and exit. Hong Kong and Singapore are designed like this.
    It is impossible to do this in London hence the validator concept which
    I accept can be evaded but the onus is placed on the passenger to
    validate and the system can detect persistent problems. I should know -
    I invented the validation concept in the LUL specification for Oyster
    (or Prestige as it was then called).
    Ah well then it is worth considering on that basis.
    Ah I had not considered the trunk services to Turnpike Lane but of
    course they are an option - a crowded and unreliable one but an option
    nonetheless.
    No problem.
    A further issue for Angie to consider is the launch of a 3 day
    travelcard ticket from Jan 2005. This will be available in peak and off
    peak versions - it's only marginally cheaper than a 7 day ticket but may
    be sufficiently attractive and flexible to allow for those ad hoc
    journeys without worrying about where Pre-Pay is valid.
    More info from here
    http://www.transportforlondon.gov.uk/tfl/downloads/pdf/fares-tickets/2005-fares-leaflet.pdf
  9. Champ wrote
    We are 'umble in his presence.
    steve auvache, Nov 24, 2004
  10. No because they all run beyond the current zone boundary or the proposed
    boundary for the London Rail Authority that TfL want to establish and
    then obviously control. There is some more info including maps of the
    boundary via these links. The government have not accepted the need for
    the authority although they have allowed Ken some additional leeway to
    implement some of his policies. As the government have grabbed back
    control of the railways into the DfT do not expect any largesse from the
    Treasury. Regrettably there will be much more of a focus on cutbacks but
    those which will appear to be "marginal" and "unimportant" - you know
    the ones like "use your bloody expensive rural railway line or we'll
    close it down" as announced by dear Mr Darling this week.
    http://www.transportforlondon.gov.uk/tfl/downloads/pdf/press-releases/rail-authority-proposal.pdf
    http://www.transportforlondon.gov.uk/rail/downloads/pdf/060504-LR-Conf-2004.pdf
  11. And that's not even my job nowadays. I've lost a lot of knowledge about
    how the system works.
    We have an American intern heading our way shortly for a 3 week spell
    with the overall team. I have been nominated by my boss as the
    "contract expert" to do the briefings for him.
    As I'm no longer in ticketing I doubt that reputation exists today but
    it certainly was the case as independent people told me that I had that
    reputation.
    <blush>
  12. My brain hurts.
    The Older Gentleman, Nov 24, 2004
  13. darsy
    oops - I didn't mean that the Oyster system itself was flawed, but
    that the ability to fare dodge in the way I outlined is "flawed", for
    the reasons you've said i.e. the system isn't designed to be used on
    our line.
    out of interest - is it as ludicrously expensive in those countries as
    it is in the UK? From next year, a return journey to work for myself
    or Angie will be over 9 quid - I think this is fairly high for a "as
    the crow flies" journey of less than 8 miles, and about 40 minutes of
    actual use of the service.
    if it's only "marginally" cheaper than a 7 day ticket, it won't be
    cost effective for Ang.
    ta.
    darsy, Nov 25, 2004
  14. darsy
    dwb Guest
    Are TFL advocating they RUN the services, or that the TOCS operate to a code
    of practice? In theory the example of having more Great Western Link
    services stop at Ealing sounds a good one - potentially FGWL will do that
    anyway. However they're there to make money and whilst it's nobel of TFL to
    say that's doesn't provide the best service, without
    nationalisation/increased subsidy, why would anyone want to do it?
    On the other hard, having a full intercity 125 stop at Ealing Broadway and
    other stations seems an invitiation to more breakdowns in terms of increased
    stops starts etc.
    I can see the idea of "people will get off, so more people can get on" but
    does it really work like that in reality?
    Which included such underused lines as the Slough/Windsor branch which,
    having lived there for awhile, was packed most of the time - UNLIKE the
    services into Windsor Riverside, which were 90% empty by Datchet, let alone
    Windsor.
    Branch = bad?
    Oh well, government knows best etc etc.
    dwb, Nov 25, 2004
  15. I'm rather out of date these days as I haven't been to the Netherlands
    or Germany for a few years. I think the very basic difference is that
    in most of Europe and, dare I say, even the States fares subsidy is not
    considered to be some form of economic evil. Thus cheap fares are
    considered to be acceptable and are provided in addition to high levels
    of investment expenditure. Parts of Germany (e.g. Berlin) and Amsterdam
    have experienced some cuts to their transport plans because the City
    authorities are effectively bankrupt and cannot afford to support
    expensive Metro and rail schemes. London's public transport fares are
    the highest or second highest in the world.
    http://www.tfl.gov.uk/tfl/pdfdocs/intfares.pdf gives a limited but
    interesting comparison.
    While it is demonstrably clear that LU and the TOCs receive subsidy it
    is not used to reduce fares which would increase mobility. Rather it is
    provided to underwrite the cost of investment for new schemes /
    upgrades, cover for risk borne by the private sector or to balance
    losses where the service is socially desirable but economically loss
    making. With a largely privatised structure a lot of that subsidy leaks
    into the profit margins of the private companies providing the services.
    You can argue that subsidisation of socially necessary services is akin
    to a form of fares subsidy but the crunch comes when the poor and
    disadvantaged have a train that runs but they cannot afford to use it -
    not what I would call effective mobility.
    Paul Corfield, Nov 25, 2004
  16. I suspect there is a bit of TfL that would like to run the services.
    However TfL is not without its own contradictions - you have LUL where
    the PPP has been criticised to hell and back by Mr Kiley and the Mayor.
    However you also have DLR which is a franchised private sector operation
    (Serco) with the Lewisham extension provided by a private concessionaire
    (CGL Rail) who charges a toll plus another one currently building the
    City Airport Extension (CARE) and another one planned for the Woolwich
    extension. Seems the private sector can be used to build and run things
    there. Croydon Tramlink is also a franchise operation involving the
    private sector. In other words there is a range of business models that
    can be used.
    I believe the current preferred stance is to ensure that TfL's plans are
    included within the franchise specification (TfL would pay the marginal
    costs of its requirements) or else TfL pays for a variation to the TOC
    franchise. The variation aspect has already happened with some fare
    changes on Southern and also for security improvements and increased
    frequencies on the North London Line.
    The Government has allowed for this in their plans to revise control of
    the railway. The test bed franchise for a wider TfL involvement is
    Silverlink where the Silverlink Metro services cover much of inner
    London and could be run like the Tube in terms of frequencies and
    service. If TfL do well with improvements to Silverlink Metro then they
    may be allowed to extend their influence to the other London TOCs. TfL
    have a statutory duty to represent the Mayor's interests for London Rail
    services and the TOCs and Network Rail cannot ignore the views and
    directions of TfL as they will, I believe, be in breach of statute.
    There is a big feature on London Rail schemes in the new edition of
    Modern Railways that should hit the shelves in W H Smith tomorrow. It
    has a feature on the Silverlink changes.
    In terms of stops at Ealing then there will always be issues about line
    capacity, dwell times etc. However there are always answers to these
    issues and if they are sufficiently beneficial then the money would be
    found.
    Although there is a superficial attraction to stopping Inter City trains
    at places like Ealing, Finsbury Park or Stratford the reality is that
    they never have stopped at places like that. They serve a different
    market sector where the disbenefit of stopping will always outweigh the
    small benefits to those people who would use such stops - the Olympic
    Games near Stratford would be an exception.
    I don't mind a strategy that genuinely tries to make rural railway lines
    a much more attractive proposition. The real issue is that rural lines
    are often exceedingly busy in the peaks / school times / weekends and
    market days. They also provide a lifeline if roads are cut off due to
    bad weather. They also underpin initiatives to reduce pollution and
    congestion from tourism. None of this was mentioned in the press
    announcements - the message was that costs were to be cut by scaling
    back the standards to which the tracks, bridges and signals have to be
    maintained to. This could lead to the service being slower and less
    attractive. The other message was use the line more or it closes because
    we "aren't in the business of carrying fresh air". Err cars and lorries
    carry millions of tons of fresh air around the country every day - don't
    see them being criticised or threatened with extinction.
    This government does not have a transport policy and as things now stand
    it never will have one. I am quite looking forward to tearing the Labour
    candidate to shreds on my doorstep when they come to ask for my vote and
    make more rash and stupid promises for the next term.
    It doesn't - the whole Railway Strategy exercise is motivated by
    jealousy from DfT civil servants who could not stomach the Strategic
    Railway Authority being outside of their control with much more
    attractive salaries etc. Oh and Alastair Darling and Richard Bowker
    didn't hit it off either if you believe the rumours.
    Under the guise of "reducing costs, improving efficiency and restoring
    accountability" the government has snatched back control of the railways
    but without the counterweight of something like the British Railways
    Board as used to exist in the old state owned structure. My personal
    view is that the government has made a rod for its own back. It has no
    one to blame for poor operation as it effectively owns Network Rail and
    the TOCs are now mere sub contractors. All the key decisions concerning
    service levels, subsidy, reliability, investment will rest with the DfT.
    When something goes wrong then the Minister is in the direct firing line
    - you will notice the very measured and cautious response given by
    Alastair Darling following the level crossing accident near Newbury. No
    rash promises to instantly spend millions to improve safety. Apart from
    London schemes I don't see any real development occurring on the
    national rail network for 10 years.
  17. darsy
    dwb Guest
    Are those areas where the company operates both the 'train' and the track?
    Possibly because taxation on cars makes them far more money.
    I really hope that isn't true, but then on previous track record I wouldn't
    be surprised.
    You could argue the SRA didn't do a huge amount themselves though.
    Unsurprising - elections coming up of course.
    Again I don't understand why they don't just fully privatise it and give the
    train companies control of the track.
    dwb, Nov 25, 2004
  18. darsy
    thanks for all this stuff, it comfirms what I'd started to suspect.
    I rarely use it myself, and on days like yesterday[1] or today[2] when
    I'm using it, I'll change my working hours so I can use an off-peak
    travel card, saving nearly a fiver.
    It just "feels wrong" that a journey that is less convenient and
    slower than doing the journey by bike should cost about 10 times as
    much.
    [1] when I was going out on the piss after work
    [2] when I've woken up probably well over the legal drink-drive limit.
    darsy, Nov 26, 2004
  19. No - TfL own the original DLR network to Beckton, bank and the Isle of
    Dogs. They own the trains. They franchise the operation and maintenance
    of the trains and track AND the operation of the trains and stations to
    Serco. On the Lewisham and planned extensions the infrastructure is
    maintained by the concessionaire (like Network Rail do on the main line)
    while Serco run the trains that travel over the tracks. Station
    operation, such as it is on DLR as they are unmanned, is with Serco but
    maintenance and upkeep is with the concessionaire.
    [rural railways]
    More to do with the votes associated with no pissing off car drivers and
    the power of the motoring and road haulage lobby. UK governments always
    have been shit scared about this - hence our lack of a remotely coherent
    transport policy.
    They didn't have the correct remit in my view. Dear Richard probably
    didn't help matters as he created an organisation full of former friends
    - I know as I worked with half of them when they were in LU! - which was
    too easy to criticise. I actually think the SRA did a number of good
    things but its role was ill defined and this resulting in too much
    political confrontation. That's a recipe for failure even if you
    discount the personality clash / jealousy issues.
    They are not allowed to under EU legislation where the costs of track
    and operation must be accounted for separately. In addition open access
    to the tracks for competing operators and a reduction in "barriers to
    entry" for new railway operators is also being driven through by the EU.
    A fully privatised network would be contrary to that without massive
    regulation which somewhat defeats the object of privatisation in my
    view. Sweller will know much more about all of this than I do.
    I also don't think the private sector would want to take on the risk of
    running the whole network given the catastrophic things that happened
    under Railtrack. This would result in the financial markets taking
    fright at the cost of the potential risk if any serious accident
    occurred or endemic degradation of assets was discovered. In other words
    it would cost too much for them to take the risk. I also think that
    voters would not wear it given what has happened over the last 10 years
    or so. Nice experiment but ultimately a failure.
    Paul Corfield, Nov 26, 2004
  20. darsy
    dwb Guest
    Blimey didn't realise that - how does it work in France and Spain?
    dwb, Nov 27, 2004
