Paging: Our Man in France
Discussion in 'UK Motorcycles' started by David Thomas, Aug 13, 2004.
  1. David Thomas
    David Thomas Guest
    Did you happend to stumble across that lappy hard drive? bit of a daft
    question really... sounds like you have had a busy week, been following your
    exploits :)
    D
  2. David Thomas
    Cab Guest
    Des is not "Our man". If he's appointed himself "Our man," then he's an
    even bigger twat than I thought.
    HTH.
    Cab :^) - almost as fast as G.i.n.g.e.
    GSX 1400 - 'Tarts Handbag' (tm) Bike, dead 550/4 Rat
    UKRMMA#10 (KoTL), IbW#015, Bob#4, POTM#3
    email addy : cab_dot_ukrm_at_rosbif_dot_org
    Cab, Aug 13, 2004
  3. David Thomas
    David Thomas Guest
    Not my words:
    "UKRM's Man in France
    Yamaha YZF-R1 | BMW K100-LT"
    D
  4. David Thomas
    Christofire Guest
    Is any part of that sig actually true?
    Christofire, Aug 14, 2004
  5. David Thomas
    Champ says...
    I'm willing to bet he does actually own a BMW....and I can't help but
    laugh about that. I don't like Des, but I do feel sorry for him in some
    strange way now. No-one deserves a BMW as punishment for being a ****.
    Lozzo, Aug 14, 2004
  6. David Thomas
    David Thomas Guest
    Ooh I've been there!
    D
    David Thomas, Aug 15, 2004
  7. David Thomas
    Ben Blaney Guest
    Bollocks. Cab and Ace live in France.
    Ben Blaney, Aug 15, 2004
  8. David Thomas
    Oh, dear. Here we go.
    AFAIC, Des is not *my* maninfrance and therefore cannot describe
    hisself as he does - he is assuming an appointment for which he would
    require a unanimous vote of all posters to this newsgroup, past and
    present.
    I have no doubt that he will petulantly disagree.
    Pip, Aug 15, 2004
  9. David Thomas
    Ben Blaney Guest
    If someone lives and works in a country and owns property there I
    don't think that makes them a tourist.
    If you do, you undermine your self-appointed "intelligent" status.
  10. David Thomas
    says...
    Shame about the helmet, I try hard not to leave bike kit anywhere where
    it can be stolen or damaged.
    As for the BMW...
    <opens new little black book>
    Lozzo, Aug 15, 2004
  11. David Thomas
    says...
    Check kill switch.
    If that's OK then open the throttle wide, if it has one leave the choke
    off as if the engine is already warmed up, press starter button for a
    few seconds. If it doesn't catch then leave the throttle open and try
    again for a few seconds. Repeat.
    If the engine still won't fire after 4 attempts then get a man in.
    Lozzo, Aug 15, 2004
  12. David Thomas
    deadmail Guest
    I think the kill switch kills everything.
    It's an injection bike so the choke is a fast idle.
    I'd:
    1. Check all fuses, it could well be that the injection control or the
    igniter doesn't have a feed. Fuses are under the LHS panel- blade
    types. There's a row of about 8 of them running vertically under a
    plastic cover.
    2. When the starter is churned listen for the fuel pump running (it's
    inside the tank)- this makes a 'whine' constantly.
    3. Remove a spark plug, place it on the head and turn it over, look for
    a spark. If there is one smell for petrol, it should be a *strong*
    smell.
    Spark plugs are on the LHS of the engine, behind the black panel marked
    'BMW' on the head (secured by 3 allen bolts).
    If there isn't a spark I'd check the connections around the coils
    (behind a black plastic cover secured by four allen-bolts) on the LHS of
    the engine (same side as the spark plugs).
    If there isn't a smell of fuel, I'd firstly check the fuel pump is
    running (open the tank when you churn it over, that will let you hear it
    more clearly).
    If the fuel pump's running I'd remove the LHS side panel and remove the
    connection to the 'black box' on top of the battery; this is the
    'motronic' fuel injection control. I'd then simply reconnect it.
    I'd put my bet on a fuel related fault.
    deadmail, Aug 15, 2004
  13. David Thomas
    Heh. It's not as if we care what he thinks, though. And I think he's a
    second-class, non-property owning immigrant, so we can both look down
    on him. From so many different levels :)
    Ace, Aug 16, 2004
  14. David Thomas
    Ben Blaney Guest
    You and I can raise a glass to him, sitting around your pool, in
    France in about ten days. Am looking forward to it.
    Ben Blaney, Aug 16, 2004
  15. David Thomas
    Cab Guest
    Ben Blaney bored us all completely to death with wittery prose along
    the lines of:
    26th Aug. Bollox. I'm off to Jordan just after that.
    Cab, Aug 16, 2004
  16. David Thomas
    Ben Blaney Guest
    I'll be at Ace's gaff on the 28th; my maths was out.
  17. David Thomas
    Jolly good. Spent half of yesterday tinkering with the Honda - I'll
    miss that, you know, even though I hardly ever ride it. Have to find
    something else I can disappear into the garage to do ;-)
    Realised that although I'd got a new oil filter about a year ago I'd
    never fitted it, so did an oil change and cleaned it up while I was
    about it. Even got round to lubing the rev counter cable so it doesn't
    jump around any more.
    For your interest, since I've had it it's had:
    New Koni shocks
    Braided front brake lines &
    Overhauled front caliper, new pads etc.
    New points
    New plugs
    Oil and Air filters
    Lots of TLC
    Overall it's a much better bike than when I got it, which is probably
    a first for me.
    Ace, Aug 16, 2004
  18. David Thomas
    Ben Blaney Guest
    Get some porn.
    That's excellent - thanks.
    Fucking ace, Ace.
  19. David Thomas
    Cab Guest
    the lines of:
    Even worse.
    Cab, Aug 16, 2004
  20. Out of interest Ben, once you've bought the Honda, what are you going to do
    with it (I assume you are not taking it back to the middle east, or maybe
    you are).
    oldbloke at work, Aug 16, 2004
