Paging Oldbloke
Discussion in 'UK Motorcycles' started by David Thomas, Jul 25, 2004.
  1. David Thomas
    you know, I've no idea, but I don't /think/ so.
    darsy, Jul 26, 2004
    #41
  2. David Thomas
    then the more cylinders the better. A 1000cc four will make more power
    than a 1000cc twin.
    darsy, Jul 26, 2004
    #42
  3. David Thomas
    David Thomas Guest
    Yeah I think I am.
    It's just that when I rode a friends bike (Magna 500 V4), when I rolled the
    throttle on it picks up nice and smooth and when I rolled the throttle off
    it didn't wedge my nuts in the tank, or make my eyeballs hit the inside of
    my visor like the my Bandit 600 does.
    D
    David Thomas, Jul 26, 2004
    #43
  4. David Thomas
    I thought Simian kept those for his 7R
    Champ, Jul 26, 2004
    #44
  5. David Thomas
    Would this be the ex-Simian bike we're talking about here? If so, I
    think it has indeed got flatslides on it - certainly his 'new' one
    has, and it's massively over-fueled and doesn't like to run below
    about 4k, or 8k at high altitudes :-}
    Ace, Jul 26, 2004
    #45
  6. David Thomas
    Eddie Guest
    Perhaps because the Magna's an underpowered barge, whereas a B6 is a
    not-so-underpowered not-so-much-of-a-barge?
    Eddie, Jul 26, 2004
    #46
  7. David Thomas
    PeterT Guest
    darsy
    Yes, but I thought we were talking about torque? Do fours make
    proportional higher power to the ratio of rpm at max torque?
    PeterT, Jul 26, 2004
    #47
  8. David Thomas
    I think he took the flatslides off this bike and put them on his tuned
    one.
    darsy, Jul 26, 2004
    #48
  9. David Thomas
    No. They don't. Here's a very quick example from an old 'Bike' that's
    lying around in my desk drawer:
    BMW 1150GS:
    max power 76.2 bhp @6500, max torque 69.1 lbft @5400
    Triumph 955i Sprint ST
    max power 104.7 bhp @9470, max torque 63.7 lbft @7380
    So, the smaller, three cylinder engine makes very nearly as much
    torque as the bigger triple, as well as much more power. And the
    torque curve is actually much flatter too, with >57 lbft from 4k-10k
    onwards, c/w about the saem between 3k and 7k on the beemer.
    but for pure laziness and a total disregard for which gear it's in, a
    Ace, Jul 26, 2004
    #49
  10. Absolutely correct, that is exactly right, it does allow you to ride lazily.
    Hopefully, once I've got to grips with it a bit more I'll ride it in a more
    spirited fashion. The CB certainly is more responsive than the Zephyr, but
    they are both fun, only in different ways. Yesterday's bimble home was a
    bit of a learning curve for me (and prolly the Zephyr also).
    This is true with the CB also, in fact it requires it in order for you to
    make good progress. The Zephyr on the other hand is happy either way (I
    think)
    oldbloke at work, Jul 26, 2004
    #50
  11. Whilst it's not a sportsbike, the CB changes it's character quite markedly
    at around 6000rpm.
    #51
  12. David Thomas
    This is mostly MCN-concieved rubbish. For bikes of equal capacity, a
    multi-cylinder bike almost always makes significantly more power than
    a twin.
    Twins's "feel" torquier because, having a lower rev ceiling, their
    torque starts lower down the rev range. But ride a Hayabusa and tell
    me it doesn't have any torque compared to any twin of your choice
    The best description I've read of this stuff is here :
    http://www.pumaracing.co.uk/power1.htm
    Champ, Jul 26, 2004
    #52
  13. David Thomas
    David Thomas Guest
    Went a viewed a CB locally yesterday.... I give up, it was described as
    "Mint", he forgot to mention that it was mint with huge amounts of
    corrosion, worn out tyres, replaced speedo, broken rev counter, scratches to
    most panels and when you open the choke the mirror moved with it!
    D
    #53
  14. darsy wrote
    Of course what you really meant to say was Electric /motor/
    Thank you.
    steve auvache, Jul 26, 2004
    #54
  15. David Thomas
    Well, those sort of things are dependent on the quality of the
    carburation, the flywheel effect (cranks with big flywheels give more
    engine braking) and several other factors.
    Engines with small cylinders (i.e. fours & sixes) tend to carburette
    better, and therefore give a better response across the rev-range, so
    that even if they may actually make less power at a certain revs, they
    feel better. Of course, fuel injection has made this a bit easier now
    - one of the main reasons Ducati were able to make such a big impact
    with the 888 and then the 916 was that decent fuel injection allowed
    them to run *much* larger venturi, and therefore much more fuel, and
    still provide decent fuelling at low revs.
    Champ, Jul 26, 2004
    #55
  16. David Thomas
    Sounds about right, now you mention it. I guess the question is
    whether he bothered to properly adjust/balance the ones he put back on
    yours...
    Ace, Jul 26, 2004
    #56
  17. David Thomas
    Damn damn damn! I meant "more torque than a twin"
    Champ, Jul 26, 2004
    #57
  18. David Thomas
    We seem to be bedevilled by typos here - you meant that "the smaller
    three cylinder engine makes nrealy as much torque as the bigger
    *twin*" I imagine.
    Champ, Jul 26, 2004
    #58
  19. David Thomas
    I doubt it. Hey, it seems to go OK.
    darsy, Jul 26, 2004
    #59
  20. As does the turbo, but - duh - that's becuase (approximately) where
    the turbo bit of it kicks in...
    William Grainger, Jul 26, 2004
    #60
