Paging Oldbloke
Discussion in 'UK Motorcycles' started by David Thomas, Jul 25, 2004.
  1. David Thomas
    David Thomas Guest
    Did you get it then... the Zephyr did you get it?
    If no response for a week I'll take that as a yes.
    D
  2. David Thomas
    Oldbloke Guest
    Yup, just got it home.
    It's, erm, big.....and thirsty.
    Dan L (Oldbloke)
    My NEW bike 1996 Kawasaki ZR1100 Zephyr
    My old Bike 2000 Honda CB500 (for sale)
    M'boy's Bike 1990 Suzuki TS50X (Heavily fortified)
    BOTAFOT #140, DIAABTCOD #26
    Oldbloke, Jul 25, 2004
  3. David Thomas
    David Thomas Guest
    yeah, bet it feels a tad more powerful, is it comfortable?
    D
  4. David Thomas
    So you ran out?
    platypus, Jul 25, 2004
  5. David Thomas
    Oldbloke Guest
    It's (obviously, I guess), a lot less buzzy than the CB500.
    I didn't give it anywhere near maximum beanage on the way home, but it feels
    like there's plenty there.
    On the move, it's a bit like driving an automatic, it'll pull in 4th or 5th
    quite happily, even round the bends.
    Dan L (Oldbloke)
    Oldbloke, Jul 26, 2004
  6. David Thomas
    Oldbloke Guest
    No, but when I got it the fuel gauge was reading empty, so I took it very
    steadily to the first petrol station I could find, only to find I could only
    get a tenner's worth in it. Therefore, the fuel gauge, whilst working,
    appears to be very inaccurate, so my next mission to find out what the tank
    range is (I reckon I'll get about 150 miles out of it).
    Dan L (Oldbloke)
  7. David Thomas
    "Even round the bends"? What do you mean by this?
    Champ, Jul 26, 2004
  8. David Thomas
    Sortof implies he slows down for bends à la Ginge[1] but still doesn't
    feel the need to change down.
    [1] You didn't really think this would change after last week, did
    you?
    Ace, Jul 26, 2004
  9. On the Honda, as you approach a tight (ish) bend, it sort of "asks" [1] to
    change down, from 6th to 5th.
    When out riding the Zephyr home yesterday, it didn't, and going round the
    bends in 5th (it doesn't have a 6th), it felt much the same is changing down
    to 4th.
    I expect it's most probably down to me taking it very easy until I have
    become better acquainted with the Zephyr, whereas I have the feel of the CB,
    and know what degree of corner requires a down shift.
    [1] it sort of chugs a bit mid corner, whereas down shifting makes it not
    chug, but more, sort of, buzz.
    Not explaining this very well, am I.
    oldbloke at work, Jul 26, 2004
  10. David Thomas
    David Thomas Guest
    No... but quite entertaining so carry on.
    D
    David Thomas, Jul 26, 2004
  11. David Thomas
    I don't really understand this at all. On a tight (ish) bend, I'd want
    to be in at least as low a gear as 3rd, to be able to give it full
    welly out of the bend.
    darsy, Jul 26, 2004
  12. David Thomas
    David Thomas Guest
    You've got a puch VZ50 haven't you?
    D
  13. David Thomas
    err, no - see .sig.
    darsy, Jul 26, 2004
  14. David Thomas
    David Thomas Guest
    Hmm it's just me reminiscing to my days of owning a VZ50 with three gears on
    a twist grip and going everywhere in 3rd (top) because I couldn't be arsed
    to change it.
    D
  15. David Thomas
    I did a bit of a run on the ZX-7R yesterday with SimonK - I don't
    think I got into a higher gear than 4th anywhere on the run. On that
    bike there's no power below 4K rpm, so you need to keep the motor
    spinning nicely so it feels right in the bend and there's decent
    acceleration out of the bend[1]
    [1] though I wasn't really using it as I didn't want to make the
    difference in power between a 400cc single and a 750cc inline four
    /too/ obvious.
    darsy, Jul 26, 2004
  16. Well, to be honest neither do I really.
    The Honda, being a fairly lightweight twin (I am guessing here) is fairly
    straightforward to set up for a corner, and power out the other side
    (sometimes in 3rd, particularly if I know the road).
    The Zephyr, being a bit of a barge (again, I am guessing here) didn't seem
    to worry about this so much (but then again, I was on unfamiliar roads at a
    fairly ponderous pace). It has an awful lot more low down grunt than the
    Honda (which seems to come alive above 6000rpm), therefore coming out of a
    (slow) corner in the "wrong" gear (i.e 5th) does not seem to cause it to
    stutter, like the CB would in similar circumstances.
    Any clearer?
  17. David Thomas
    absolutely. Basically you're saying the bike has enough power and
    torque to let you ride it lazily. I /could/ ride like that on the
    'blade as it's got plenty of grunt, but I choose not to, because I
    enjoy caning it in a lower gear out of corners. The 7R is a bit
    different - there's no power below about 4K so changing down is
    /necessary/.
    On either bike I tend to change down a gear or two before entering a
    bend, opening up the throttle slightly through the curve, and then
    wrenching it WFO as I exit the bend. This is fun.
    darsy, Jul 26, 2004
  18. David Thomas
    Porl Guest
    Is there any power to speak of on any sportsbike under 4k? There sure as
    hell isn't a hell of a lot on the gixxer.
    Porl, Jul 26, 2004
  19. David Thomas
    Ginge Guest
    But it's gone all French...
    Ginge, Jul 26, 2004
  20. David Thomas
    my 'blade will pull from about 2.5K.
    The 7R will not pull from less than 4-5K.
    darsy, Jul 26, 2004
