Paging Medion GPS Owners
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Oct 7, 2005.
  1. Scamera warning add-on details here:
    http://www.amngps4.wanadoo.co.uk/index.htm
    29 Euros one-off payment, which seems cheap enough.
    I've just installed it, and AFAICS, it works nicely.
    Wicked Uncle Nigel - "Oh Bollocks" said Pooh, having forgotten his lines.
  2. Wicked Uncle Nigel
    Daz Guest
    On Fri, 7 Oct 2005 11:45:35 +0100, Wicked Uncle Nigel
    Where does this payment come into it? You can download it from
    pocketgpsworld.com where it originated for *free*.
    Daz, Oct 7, 2005
  3. Wicked Uncle Nigel
    Steve Parry Guest
    Steve Parry, Oct 7, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Daz
    You can download the overlays for free, but the software on the Medion
    needs an add-in before it can use them. *That's* the bit that's
    chargeable.
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Steve Parry
    Yes. Very clever.
    How are you going to use them with a Medion GPS then?
    (Hint: Follow the link I posted).
  6. WUN:
    Just out of interest, which model do you have and what is your opinion
    of it?
    FrJack @ work, Oct 7, 2005
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, "FrJack @ work"
    I've got the PNA100. It works pretty well. As with all satnav systems,
    you have to apply a little common sense from time to time.
    The road database is getting a little dated (> 1 year old), but it's not
    bad enough that I feel a burning need to check for updates.
    I *love* having street level maps for pretty much all of Western Europe
    and Scandinavia. For me this is bloody handy.
    As a PDA it suffers from not having any Wi-fi connectivity, other than
    that it's fine.
  8. SanDisk 256MB+WiFi card, around £80 from a place in Manchester.
    I can look up details if you can't find owt.
    GSX600F, RG250WD, DT175MX-MIA "You Porsche. Me pass!" DoD #484 JKLO#003, 005
    Dr Ivan D. Reid, Oct 7, 2005
  9. Wicked Uncle Nigel
    I bought mine after hearing WUN raving on about his (it was a toss-up
    between a Garmin Quest or the PNA100, what swung it was the fact that the
    PNA can double as a PDA as well) and I'm pretty chuffed with it, too.
    Mostly does what it says on the tin.
    Timo Geusch, Oct 7, 2005
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Dr Ivan D. Reid
    Unfortunately it doesn't support SDIO cards. I'm told this is a
    licensing, rather than a hardware, limitation. If I could be arsed, I'd
    investigate more deeply.
    No biggie anyway, because the new toy (O2 XDA) had wi-fi built in.
