Paging Mash
Discussion in 'UK Motorcycles' started by Cane, Jan 18, 2004.
  1. Cane
    Cane Guest
    Do you know the make and model of the motherboard in my PC? I need to re
    flash the BIOS.
    Cane, Jan 18, 2004
  2. Cane
    deadmail Guest
    Is this as in "I need to **** it up badly, quickly?"
    Cane mate, don't do it...
    deadmail, Jan 18, 2004
  3. Cane
    Cane Guest
    I've tried that but my cock doesn't support XP
    Cane, Jan 18, 2004
  4. Cane
    Cane Guest
    Too late. I've already fucked it up badly which is why I need to do this.
    If only you'd said that earlier.
    Cane, Jan 18, 2004
  5. Cane
    Ginge Guest
    Are you sure you need to flash the BIOS, and not just reset it?
    What's the exact problem?
    Ginge, Jan 18, 2004
  6. Cane
    Robbo Guest
    Cane!
    Robbo
    BMW K100 RS 1984
    BotaFOF #19
    E.O.S.M 2001/2002/2003
    B.O.S.M 2003
    FURSWB#1 KotL
    YTC449
    PM#7
    \_-//' / / /<,
    / >> \\\`__/
    /,)-^>> _\` \\\
    // _//\\\\
    Robbo, Jan 18, 2004
  7. Cane
    Cane Guest
    Good question.
    Well it's two fold really.
    The original problem was that when I booted up the PC would often get as far
    as "windows is loading" with the blue XP Pro screen and hang at that point.
    Not everytime but maybe half of the time. It got more regular until it
    happened every time and I couldn't get into Windows.
    In my frustration I decided to look at the options by pressing 'del' at the
    start as this was the only thing I could get into. I somehow bolloxed it
    completely and ended up setting the BIOS to default in desperation.
    When I boot up now a message comes up about searching for IDE drives and not
    finding any. I press escape and it boots to Win XP. It still hangs at the
    2windows is loading" stage unless I hammer the enter key just prior to that
    screen appearing. Once I'm in it seems okay.
    The only other problem is that in the device manager it says that my SCSI
    RAID controller has no driver. I can't seem to find one :-(
    I should've posted this ages ago.
    Cane, Jan 18, 2004
  8. Cane
    Spete Guest
    Normally, when you're in the BIOS, it says the BIOS version on the first
    page. Bung that into Google, and you should get somewhere. Alternatively:
    pay my petrol and beers and I'll come over and **** it up for you.....
    Spete, Jan 18, 2004
  9. Cane
    deadmail Guest
    I did! When you were flapping about it last time and you said if
    someone could fix it they could **** Heather.
  10. Cane
    Cane Guest
    You're right you know. She sat by the front door all day.
    Cane, Jan 18, 2004
  11. Cane
    Ginge Guest
    From what you've described It's not the BIOS that's at fault, it's the
    install of Windows, possibly caused by corruption on the hard disk.
    If the bios is set to defaults then you should be working with an
    extrememly stable base set up, so leave that side of things alone.
    Find your Windows install CD, boot off it, and chose to "Upgrade" the
    existing installation, that'll re-install all the drivers and should
    sort things out..
    I've no idea why hammering the enter key should have any effect, what
    may be better is pressing F8 when it's booting up, and selecting simple
    mode to see if things start up properly or with any errors.
    Also if you click on the Start button, Choose "Run" and then type
    "Eventvwr" in the box that appears and press enter, you'll be able to
    see the system error log which may shed some light on what's fucking
    up.. Look for the warning messages with red icons by them.
    HTH.
    Ginge, Jan 18, 2004
  12. Cane
    deadmail Guest
    You're right you know. She sat by the front door all day.[/QUOTE]
    Blaney must have got lost.
  13. Cane
    Mash Guest
    No idea, what have you done to it you silly sod? Its an Abit board, the
    model number will be printed in bold between 2 of the white PCI slots...
    most likely.
    I *think* it was this one:
    http://www.abit.com.tw/page/uk/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S&fMTYPE=Socket+A
    Flashing the bios prolly isn't the answer though. I've detroyed many a
    computer, but not even I would flash the bios just like that. Keep pressing
    F8 while the computer boots, this will give you the windows boot menu. Pick
    "Safe mode without networking" and see if that works.
    In this situation I would slap the winXP CD in and choose reinstall, this
    will reinstall everything, but it won't destroy any of the files, documents
    etc.
    I've got a tape backup drive with 4x20gig tapes you can have for a few notes
    Mash, Jan 18, 2004
  14. Cane
    Mash was seen penning the following ode to ... whatever:
    What kind of drive and how many notes?
    Timo Geusch, Jan 18, 2004
  15. Cane
    Cane said...
    Useless tosser, mine supports a wet bath towel.
    Lozzo, Jan 18, 2004
  16. Cane
    Ginge Guest
    I don't think it matters, it won't be Timo-proof.
    Ginge, Jan 18, 2004
  17. Cane
    Ginge was seen penning the following ode to ... whatever:
    There isn't much in this world that is.
  18. Cane
    Mash Guest
    Mash, Jan 18, 2004
  19. Cane
    Hmm. Does it work, can you still get tapes for it and whereabouts in
    the multiverse are you?
    Oh, and is it IDE or SCSI?
