Paging Gasman - luggage
Discussion in 'UK Motorcycles' started by Fr Jack, Apr 15, 2004.
  1. Fr Jack
    Fr Jack Guest
    What make is the huge bag setup I saw on yer bike @ BOSM?
  2. Fr Jack
    Fr Jack says...
    And also, did the gearchanger work ok on the way home?
    Lozzo, Apr 15, 2004
  3. Fr Jack
    Charles Gill Guest
    [This followup was posted to uk.rec.motorcycles and a copy was sent to
    the cited author.]
    I dont know Fr Jack - I will look tomorrow. As for Lozzo it worked
    brilliantly.
    I had a super run back following PJ until I got to roads I know and then
    gave it some.
    Many thanks once again.
    I do believe that I have already sent thanks.
    I will email this also in case the newsreader is playing silly buggers
    Charles Gill, Apr 16, 2004
  4. Fr Jack
    Charles Gill says...
    I'm a bit suss about that 2A fuse, it seems very light for a solenoid of
    that size and power. It may be worth looking at what it's rated at and
    then working out what fuse it should be fitted with.
    Lozzo, Apr 16, 2004
  5. Fr Jack
    Statto Guest
    [of Kliktronic repairs]
    Or look at the possibility of replacing it with a similarly rated
    blade fuse.
    Statto, Apr 16, 2004
  6. Fr Jack
    Statto says...
    That's a pretty good idea, the blade fuses are less prone to failing due
    to vibration. My thought was that a solenoid the size of that one draws
    alot of current to operate. It's not a smooth operation either, it's a
    massive surge. The glass mini 2A one it has looked quite fragile and
    tbh, not up to the job.
    Lozzo, Apr 17, 2004
  7. Fr Jack
    In which case a 3A fuse would be more appropriate.
    Lozzo, Apr 17, 2004
  8. Fr Jack
    Statto Guest
    Would the circuit protected by the 2A fuse operated a relay, which
    turn would drive the solenoid? In which case the would the 2A fuse not
    protect the relay.
    Statto, Apr 17, 2004
  9. Fr Jack
    Statto says...
    It is wired directly via the ignition switch. No relay.
    Lozzo, Apr 17, 2004
  10. Fr Jack
    Statto Guest
    Having had a poke around the Klicktronic website, I now understand.
    Statto, Apr 18, 2004
