Hello all. I've just ridden my B6 home after getting it serviced (not at THAT garage, this time) but all is not cured. It wasn't running as it should have been before the service (explained later) and the Shoppe have replaced the plugs and one of the leads and done everyone usual on a full service but I need some advice on what I should point them towards tomorrow. They described my problem as 'running a bit fluffy low down' and suggested I replace the rear baffle in the exhaust. While I understand their suggestion the bike has had that baffle removed since just after I received it and it only started to go downhill power-wise quite recently. When chugging along up a hill it will appear to get behind on the power (if that's the phrase to use) and will then give medium length spurts of power and then they'll drop off a bit and come back. I thought the problem might have been carb related and they say that they've cleaned the carbs out. When going around a corner on a bend a brief unexpected spurt of power is not ideal. Before this started the power was delivered consistently. Another symptom is theat when I go up a steeper hill the machine will seem to lose a bit of power then the spurts of normal power are a bit shorter and may occasionally be accompanied with a pop (Like a mini-KSB) from the exhaust. Should I point them in any general direction tomorrow?
