paging (faux) frogs
Discussion in 'UK Motorcycles' started by darsy, Jun 26, 2008.
  1. darsy
    a question about the Parisien public transport system. I sometimes
    seem to buy the wrong ticket i.e. at Gare du Nord I use the machine
    and select "La Defense" as my destination, but when I get to the other
    end, the ticket won't let me through the barriers. I want to avoid
    this now I'm going to be there more often.
    I know there's no equivalent to the Oyster Card that we have in
    London, but what would be the best option for someone in my position
    i.e. will be in Paris every two-three weeks, and need to travel mostly
    just between Gare du Nord and La Defense, but occasionally into
    central Paris (AXA Group headquarters is on the Rue Matignon). Is
    there a book of tickets or something I can buy, and if so, what one do
    I need (and even more hopefully, how much does it cost?)
    ta.
    darsy, Jun 26, 2008
  2. darsy
    IANAFF but isn't the LUL Carnet ticket based on the original one used
    on the Metro?
    <fx:googles>
    11.10 euros for 10 tickets.
    http://europeforvisitors.com/paris/articles/paris-metro-tickets.htm
    CT, Jun 26, 2008
  3. darsy
    des Guest
    The problem may be coming from the fact that the métro station La
    Défense is in zone 2, but the RER station by the same name is in zone 3.
    Do you buy the ticket at an automated thingy or does a 'real' person
    sell it?
    If you just use the métro, zone 2 will do you but the RER is faster to
    La Défense (even though not direct, i.e. you'll need line B to Châtelet,
    and then line A to La Défense). For the latter, you'll need zones 1-3.
    The pass you want is called a 'navigo', and costs 70.80¤ for three zones
    for one month. If your employer is French (duh...), they reimburse you
    50% of that, but I have no idea where your situation would come in, as
    technically speaking, you live in the UK.
    If you're still stuck, reply to this post, and I'll go down to the métro
    station here (no way am I calling the cocksucking premium rate line) and
    ask them how much zones 1-2 cost, and why you keep encountering the
    problem mentioned in the first paragraph.
    D.
    des, Jun 26, 2008
  4. darsy
    des Guest
    The problem with the carnet (IIRC) is that the tickets are 'zone
    urbaine', i.e. zones 1 and 2 only. La Défense RER station is in zone 3.
    D.
    des, Jun 26, 2008
  5. darsy
    ah - I did wonder if it were something like that.
    no, I tend to get them from the automated machines.
    No, I use the RER via Châtelet, as you suggest (though when I was
    there last week line B wasn't running due to industrial action, and I
    had to use D). I hadn't noticed that despite being in the same
    physical location that La Defense was in a different zone dependant on
    whether you were using the Metro or the RER. The RER is much faster,
    though - and it may be my imagination or just bad luck - but it seems
    to be getting slower. A couple of years back I could get from Gare du
    Nord to La Defense in ~25 minutes, but I haven't done it quicker than
    ~35 this year.
    That seems quite high compared to buying single tickets - remember I'm
    probably only going to make 6-10 trips per month.
    technically speaking, as I'll pay for the thing on my corporate Visa
    card, my employers will pay for all of my foreign travel expenses.
    métro
    no, that should be enough info, ta.
    darsy, Jun 26, 2008
  6. darsy
    des Guest
    I've no idea _why_ they do it that way, though. Typical French
    'efficiency', sans doute...
    When you arrive at the Gare du Nord, try taking line 2 (dark blue),
    direction Porte de Dauphine, getting off at Charles de Gaulle-Étoile and
    getting onto the RER there. It _might_ not be any slower, except that
    you'll probably have a bit of a walk at the Gare du Nord as IIRC, line 2
    goes through La Chapelle...
    Ah, OK. In that case, a carnet should do you. When you go those
    machines (I assume you mean the one with the 'roller' that you spin
    around and then press the green button to select?), you can buy a carnet
    for zone 3, but you need to specify it.
    **** 'em, then. Get yourself a Navigo pass for three zones, and you
    just swan through the turnstiles.
    https://www.navigo.fr/
    D.
    des, Jun 26, 2008
  7. darsy
    Qu'a-t-il dit?
    wessie, Jun 26, 2008
  8. darsy
    Cab Guest
    Only poor people use the RER/Metro. Get a bike. I'll look after it for
    you.
    Cab, Jun 26, 2008
  9. darsy
    ta.
    darsy, Jun 27, 2008
  10. darsy
    what, and every time I need it, you'll deliver/collect from Gare du
    Nord in a timely manner?
    darsy, Jun 27, 2008
  11. darsy
    des Guest
    Well I use it and I'm not 'poor'.
    D.
    des, Jun 27, 2008
  12. darsy
    Cab Guest
    If I find the time, yes.
    Otherwise you'll need to catch the RER.
    Cab, Jun 27, 2008
  13. darsy
    Quelque chose au sujet de chicorée.
    ogden, Jul 8, 2008
  14. You'll be drinking that Camp coffee next;)
    Steve Fitzgerald, Jul 9, 2008
