Paging EXUP valve experts...
Discussion in 'UK Motorcycles' started by Spike@Work, Sep 29, 2003.
  1. Spike@Work
    Spike@Work Guest
    Fazer 1000 well overdue for 20K service... with couple of little probs
    pointed out on dropping off. Namely, rattle (assumed valves) and ocaisional
    1/2 secondloss of power when traveling at speed. Power comes back on,
    accompanied by huge backfire. Its exactly as if I had hit the kill switch
    and then popped it back on...
    Anyhow, upon service, get the call with the magic word "But..". in it.
    Apparently one of the cables running to the EXUP valve has broken, causing
    said rattle. New cables come in pairs and cost 90 notes.
    So cables replaced, rattle gone. But on first chunk of motorway riding,
    exactly the same thing happens- total loss of power for half a second, huge
    backfire.
    Now is this likely to be the EXUP valve still being knackered or would it be
    impossible for a fucked exup valve to cause these symptoms?...
    As is obvious, I know **** all about spannering....
  2. Spike@Work
    mups Guest
    Wouldn't have thought so. It sounds more ignition related. Sidestand switch
    or loose wire somewhere would be my bet.
    mups, Sep 29, 2003
  3. Spike@Work
    Nigel Eaton Guest
    You're not kidding anyone Pixie. We know those KSB's are deliberate...
    Nigel
    WS* GHPOTHUF#24 APOSTLE#14 DLC#1 COFF#20
    ZZR1100 and Enfield 500 Curry House Racer "The Basmati Rice Burner" (No , I'm
    not sure how that happened either).
    Nigel Eaton, Sep 29, 2003
  4. not a chance in hell!
    it's almost certainly ignition related.
    KillaHedgeHog AKA Paul Hendrick
    YZF750R Bultaco Sherpa Fantic200
    BONY#3 BOTAFOT#101
    Remove KHH to reply by email
    KillaHedgeHog, Sep 29, 2003
  5. Yup. It's ignition, for sure.
    The Older Gentleman, Sep 29, 2003
