paging everyone...
Discussion in 'UK Motorcycles' started by darsy, Jun 3, 2010.
  1. darsy
    oh sure - I was definitely a twat when I was 17.
    darsy, Jun 3, 2010
  2. darsy
    davethedave Guest
    As well as having the news groups widest vocabulary[1], Mr Bear was
    also a master of puncturation, sentence structure and the drinking
    of lesser men under the table[2].
    [1]There is evidence to back up this claim.
    [2]Arakis exists to train the faithful.
    davethedave, Jun 3, 2010
  3. darsy
    I've met you and I'd be quite happy if you died. I'd be even happier if
    you died in pain with a shitload of your hook-nosed sky fairy mates
    dying around you too.
    The 'It's only words on Usenet' defence wore thin a few years ago - you
    were a **** then, you're more of a **** now.
    Lozzo, Jun 3, 2010
  4. darsy
    Yeah but I think I was second or something so your method was clearly
    faulty.
    ogden, Jun 3, 2010
  5. darsy
    davethedave Guest
    I don't remember seeing you drinking! However... Err.. How many bottles of
    absinthe was that......? Sambuca...? Errrrrr oh yes.
    Regex word split yes that was it. Far from perfect but it was all for a bit
    of fun anyway. If you fancy I can mail you the code and you can giggle at
    my regex. ;)
  6. darsy
    YTC#1 Guest
    No one said you had to read any of it.
    But on the bright side, it is upping the NG usage stats :)
    YTC#1, Jun 3, 2010
  7. darsy
    TMack Guest
    Meaningless unless adminstered by an independent, qualified professional and
    still meaningless unless the test used is cited. Still pretty meaningless
    even with this added info. Also - different tests can produce different
    "IQ" scores. Wechsler Stanford-Binet and Cattel and other tests could all
    produce different scores for the same level of ability.
    TMack, Jun 3, 2010
  8. darsy
    petrolcan Guest
    I've snipped the extra shit out.
    petrolcan, Jun 4, 2010
  9. darsy
    I ought to append <irony> tags to all my posts, just to save you guys
    the bother.
    darsy, Jun 4, 2010
  10. darsy
    Cab Guest
    Oh, I dunno. I'd consider them as bites.
    Cab, Jun 4, 2010
  11. darsy
    well, there is that.
    I wasn't really trolling though - as I discussed with Ogden IRL a
    month or so ago (and which he confirmed he did the same), I post stuff
    for my own amusement, not for that of the rest of you.
    darsy, Jun 4, 2010
  12. darsy
    you make so many assumptions, it's laughable.
    for instance, think about the medium through which you "learned" that
    I was "wishing"[1] death on you - isn't it just "words post to
    Usenet"?
    [1] by the way, it was a "hope" not a "wish". Subtle difference.
    darsy, Jun 4, 2010
  13. darsy
    If I relied on you lot to post something worth reading, I might as well
    give up.
    ogden, Jun 4, 2010
  14. darsy
    et tu brute
    darsy, Jun 4, 2010
