Paging electronic types at work
Discussion in 'UK Motorcycles' started by Grimly Curmudgeon, Dec 30, 2010.
  1. I need a set of diodes for my duff alternator
    3 off 1N1186-ND and 3 off 1186R-ND, or equivalents.
    They're rated 35Amps in a chassis stud mount.
    Case is DO-203AB, DO-5, Stud
    Anyone got a source for these, as cheap as possible?
    url:http://search.digikey.com/scripts/D..._link=hp_go_button&KeyWords=1n1186+nd&x=0&y=0
    This is an American supplier, and if I can't find them here at a decent
    price I might just have to order them from abroad.
  2. Grimly Curmudgeon
    Geoff (raden) is your best bet
    wessie, Dec 30, 2010
  3. Grimly Curmudgeon
    Malc Guest
    What's the difference between the two? A quick glance at the specs
    doesn't reveal anything obvious but I'm almost certainly missing
    something. You can get a straight 1N1186 from RS Components for about
    £2.73
    Malc, Dec 30, 2010
  4. I was unaware of Digi-Key Ireland, thanks for that - they look ideal.
    I'm sick of being pissed around by breakers who want a ton for a 20 yr
    old alternator, simply because they're getting a bit unusual now. A ton,
    then testing it and quite possibly having to rebuild it anyway, no
    thanks. Any other Jap alternator of this size is going for 30~50quid
    around here.
    I've already spent some money on new brushes and new reg (the old reg
    was defective, but it was masking a dud diode or two) so will remove
    this alt and repair it myself. In the normal course of events, I'd have
    slung the old one and put on a 90A Bosch I have lying around, but the
    brake vacuum pump is on the back of the Toyota alternator and this
    complicates things.
  5. One's forward, one's reverse, to enable mounting on two seperate plates,
    fitted in the alternator body.
    See here, what I'm on about...
    http://www.toyotadiesel.com/forums/showthread.php?t=529&highlight=diodes
    Yeah, if you buy 250 of the little fuckers.
    Plus, they have the cheek to charge extra because they're kept in a
    shoebox in a shed in the Utter Hebrides, cunts.
  6. Grimly Curmudgeon
    Ian Field Guest
    AFAIK you can buy single QTY here:
    http://uk.farnell.com/jsp/search/br...ions=false&ref=globalsearch&_requestid=527030
    Ian Field, Dec 30, 2010
  7. Grimly Curmudgeon, Dec 30, 2010
  8. Grimly Curmudgeon
    Ian Field Guest
    Their website was often down for maintenance - but I haven't ordered from
    them for months.
    Note the part number with the full suffix letters you quoted gives 0
    results, the base part number gets a page with a few you can chose the exact
    right one from.
    I didn't check that page, but most part listings include the full PDF
    datasheet you can right click and save.
  9. Grimly Curmudgeon
    geoff Guest
    I'll see what I can do on tuesday
    Not much chance of having them at work, a bit of a special
    geoff, Dec 31, 2010
  10. Cheers, but no worries if not easily available; as Mark pointed out,
    Digi-Key Ireland is figuratively just up the road and their prices are
    ok. What threw me was the apparent lack of them on my usual hunting
    sites.
    Grimly Curmudgeon, Dec 31, 2010
  11. Grimly Curmudgeon
    geoff Guest
    Well, you've got my email if you need some help
    geoff, Jan 1, 2011
  12. Ok, I'll bear it in mind, ta.
    Grimly Curmudgeon, Jan 1, 2011
