Paging computerists
Discussion in 'UK Motorcycles' started by Whinging Courier, Oct 14, 2004.
  1. Whinging Courier
    tallbloke Guest
    Words to Fathom?
    tallbloke, Oct 15, 2004
    #41
  2. Whinging Courier
    tallbloke Guest
    ISTR Mac also had an issue with laptops running very hot. So hot you
    couldn't leave your palm on the rest....
    #42
  3. Whinging Courier
    Loz H Guest
    To be fair, Quake 2 used to run *mint* on my old Celeron 450Mhz with a
    GF2GTS video card.
    With games like that, it`s the graphics processor which is more important
    than the main processor.
    As for G4 vs Athlon, hard to compare as (obviously) they like in completely
    different subsystems. However, in terms of raw processing ability a site
    I`ve found seems to suggest that a G4 500Mhz is comparable to an Athlon
    700Mhz.
    Loz H, Oct 15, 2004
    #43
  4. It's on the cards...
    That means it could be some time away. Don't get excited, I'll let you
    know when I need Wi-Fi ;-)
    I had a 700MHz Celeron desktop before this with a 64MB GF4 graphics card
    and that worked really well.
    It did, but when you buy a 2.8GHz laptop with 512MB RAM, you do expect
    it to perform better than something that came out in 2001.
    The video RAM is shared with the main RAM and is fiddlable in the BIOS
    between 32 and 128MB, and I reckon it's this that is causing performance
    issues.
    I could whack another stick of RAM in but the 2 slots I've got are
    already full :-\
    Whinging Courier, Oct 15, 2004
    #44
  5. Whinging Courier
    Steve Parry Guest
    In
    Heated grips ... kewl
    Steve Parry
    http://www.gwynfryn.co.uk
    http://www.arrivedeprived.org.uk/
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Oct 15, 2004
    #45
  6. Whinging Courier
    Loz H Guest
    Whinging Courier <> spewed forth the
    following...
    A lot of laptops are not designed with high performance 3D in mind.
    For example, looking at some Sony laptops with similar specs to yours, I see
    there are 2 distinct video systems used. One being the ATI Radeon IGP 345M,
    which is mainly 2D based and the other being based on a Radeon 9200.
    The 345M (from what I can find) appears to have a similar performance to the
    Radeon 7500 when it comes to 3D stuff. Not much cop, in other words.
    Whereas the 9200 should probably hold its own in games like Medal of Honour
    and so on, I would expect it to fall flat on its arse with the likes of Doom
    3 or Far Cry. It`s probably comparable to a GF4MX or maybe an FX5200 in
    terms of performance. However, with your having shared memory I don`t think
    it`ll be a 9200, and if it is it will be hampered with the shared memory
    bus, bringing it down to 9200SE performance levels. A GF4MX kicks the arse
    of a 9200SE.
    Out of interest, what model laptop do you own?
    Loz H, Oct 15, 2004
    #46
  7. This I already knew. I'm not a mad-for-it gamer but do sometimes like a
    go. I thought the laptop I bought would be at least as good as my old
    desktop if not better.
    That'll be mine then.
    I know bugger all about the inside of a laptop.
    What I can tell you is that an old black and white King Kong movie was
    smoother than Doom3.
    PCG-K115B
    #47
  8. There are other compromises - laptops generally have hard drives that
    rotate at 5400 RPM rather than the usual desktop 7200RPM (or 10K RPM
    for some modern drives). This limits the data transfer speed (and they
    generally have worse seek times as well).
    They also tend to use lower-power motherboard components as well - and
    sadly this usually means 'less fast'.
    Phil
    Phil Launchbury, Oct 15, 2004
    #48
  9. You live and learn. I wrongly assumed a computer with a 2.8 gig
    processor would have hardware to match.
    As I've found out to my cost.
    This thing's ok, it does most stuff reasonably speedily but for the die
    hard games that are coming out now, a desktop is really the only way.
    There's also the dedicated games consoles, of course, but I don't spend
    enough time playing them to warrant the expense or space it will take
    up.
    #49
  10. Whinging Courier
    Ben Guest
    It's a laptop. Primary design concerns are heat, weight and battery
    life.
    Unless you pay serious wedge or are prepared to sacrifice some of the
    portability you're not going to get equivalent desktop performance
    even when things like processor and memory spec are the same.
    Ben, Oct 15, 2004
    #50
  11. Ben wrote
    putting the makers label in front of suits.
    steve auvache, Oct 15, 2004
    #51
  12. Whinging Courier
    Something like that. I thought it meant 'what the ****?'.
    Muck, Oct 15, 2004
    #52
  13. Correct.
    Buying a spaztop from Lidls or somewhere else from an unknown maker
    would also prove to be unworthy when the time comes for repair if the
    factory that made it goes tits up.
    #53
  14. Sadly no.. PC's tend to be tuned to whichever task they are meant for -
    laptops for power consumption, desktops for general use and servers
    tend to be optimised for data throughput (15K RPM Ultra SCSI 320 drives
    - yum).
    Indeed. Plus in a desktop you can easily replace the graphics card when
    the flavour of the week changes.
    Unlike my Dell laptop which (although it has a 64M graphics adaptor as
    a plug in part) seems to have a propriatory Dell plug on it that means
    I can replace it with a faster generic laptop module..
    Plus the fact that a good desktop is usually faster than a dedicated
    console and can do other things as well..
    Phil
    #54
  15. Whinging Courier
    SleeperMan Guest
    could be...
    SleeperMan, Oct 15, 2004
    #55
  16. Whinging Courier
    mb Guest
    Oh good grief Penfold... Let me explain:
    In answering WC's initial posting, I assumed a few things. First he stated
    that his Sony Vaio laptop was from May this year, i.e. fairly new.
    I assumed that Sony, being a well known company in this field, would
    ensure that the latest hardware was in place on their laptops and USB2 has
    been around for a couple of years now.
    Who makes laptops *without* USB2?
    I also assumed he was using Windows, I'm a bad person.
    mb, Oct 15, 2004
    #56
  17. Whinging Courier
    John Higgins Guest
    In that case, when it eventually comes back, disable hyperthreading.
    See if it improves.
    John Higgins, Oct 15, 2004
    #57
  18. I doubt it. It is a humble Celeron.
    Ditto. Also, the memory read/write is rubbish; this PC that I'm using
    now, has the same read/write speed as a desktop that was built 10 years
    ago! The CPU performs better but it is the memory that lets it down very
    badly. I do have that "cure for cancer" thing running most of the time
    but even in snooze mode it isn't much better.
    Weird. Mine slows down if it's on batteries but that's by design I
    reckon.
    #58
  19. Whinging Courier
    Loz H Guest
    Starter for 10! Hyperthreading is disabled in the Celeron.
    The Celeron 2.8Ghz only runs at a FSB of 100Mhz, therefore memory access for
    the CPU is quite slow, as you have noticed. A cure (well, more an assist
    really)for slow memory access is to have a large L2 cache. Unfortunately the
    Celeron only runs 128K L2 cache, hitting performance again.
    Pure clock speed is also not an indication of performance, especially where
    gaming comes into it. Large cache and "work per clock cycle" help quite a
    bit.
    An example I`m looking at now is a CPU comparison of Call of Duty. Boards as
    similar as they can have em, with similar memory and video cards. An 1.8Ghz
    AMD (Barton 2500+) CPU outperforms the 2.8Ghz Celeron by 100%, the AMD
    scoring 116fps compared to the Celerons 56fps. A P4-2.4Ghz CPU on the same
    motherboard as the Celeron outperforms it by a similar margin.
    Of course, this does not mean that it will be half the speed of the other 2
    CPUs whilst pottering around within Windows or using some usual
    applications, just that whilst running something which strains the entire
    memory/bus/cache subsystem the speed difference will be more evident than it
    will be using Office 2000, for example.
    Intel really dropped a bollock with the Celeron CPU range, and of course the
    high Mhz rating is bound to attract the buyer, when for a similar price (for
    the CPU itself) better performance can be had.
    Loz H, Oct 15, 2004
    #59
  20. Whinging Courier
    I thought that hyperthreading was only an advantage in some sorts of
    database servers.
    Muck, Oct 15, 2004
    #60
