Unless he only has USB 1 ports........ -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
What a load of unmitigated tosh! USB2 requires compatible hardware it's not just a software based implementation. Also it's worthknowing that under Windoes XP there are a lot of problems with both the VIA and ALI chipset implementation of USB 2.0, the NEC chipset is the one that's known to work properly consistently. HTH.
Why not? I`ve got an AMD 2500+ Barton. Stock speed 1.83Ghz (166 FSB) running happily as a 3200+ Barton 2.2Ghz (200 FSB). It will run higher but the PCI bus starts to shit out as it`s not frequency locked. Memory is happy at 200 (400DDR) too. My video card. GF4Ti4200. Stock speed 270Mhz core and 550Mhz memory is running like a charm at 300Mhz core and 625Mhz memory. Again, it will go higher but at this level of overclock it stays nice and cool. The memory on the video card is rated at 3.3 ns/606Mhz anyway, so a safeish memory overclock there. Use a little common sense and spec out your components so you don`t aim too high at first and it`s a quite safe and fun thing to do.
SleeperMan explained on 14/10/2004 : t'other way round.... USB to com port. I don't think a serial com port would support anything close to the data rates of USB.
"I know just what you mean"? -- Steve Parry http://www.gwynfryn.co.uk http://www.arrivedeprived.org.uk/ K100RS SE F650 (not forgetting the SK90PY)
I think it's a x86 laptop, it runs hot anyway, he will kill more than just the processor if he starts farting around with clock speeds. If he wants it to go faster, either get a better operating system, more ram or a different computer, or all three together and buy yourself a Mac G5. <snip>
It's on the cards, but not just yet. A few quick benchmark tests saw this thing performing at a rate comparable to a 1.6GHz Athlon FFS, and I don't even want to talk about the memory speed except that it runs at the same speed as some poxy PC100 SD RAM. No wonder I couldn't get Doom3 to run properly, it doesn't even run stuff that came out two years ago smoothly in all places!
very few laptops are in the high performance stakes compared with desktop pc's -- Steve Parry http://www.gwynfryn.co.uk http://www.arrivedeprived.org.uk/ K100RS SE F650 (not forgetting the SK90PY)
Well I know that now! <rolls eyes> I'll probably keep this laptop for a while but I won't be rushing out to buy another one.
Doh... Well, it's still a useful computer, as it works at the moment. You saw Quake2 running on my 800 Mhz G3 Mac, fast and smooth wasn't it. I wonder how fast a 800Mhz G3 is in Athlon terms?
Yes, but as WC said his computer is from May this year, I think it's safe to assume the required hardware is in place. USB2 support came with SP1a. Fascinating.
Agreed, but conceivable -- Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 Tyger, Tyger Burning Bright (Remove rust to reply) Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 75 2.0 TS Triumph Speed Triple: Black with extra black bits www.cuore-sportivo.co.uk
That's pretty cool. I like that way it continuously updates, if you use it with no load on my machine it quotes the processor a 600Mhz, give the machine a bit of load and you can see the processor up it's speed to cope[1]. [1] P-M 1.7 Dothan.
