Paging computerists
Discussion in 'UK Motorcycles' started by Whinging Courier, Oct 14, 2004.
  1. How can I tell if my computer's got USB2 Support?
    It's WinXP, I've looked in device manager and System Information but
    this doesn't throw any light on the situation.
    It's a Sony Vaio laptop that I bought from new in May this year. I'd
    have thought it would have USB2 support, but you never can tell, eh?
    I've just found this natty little TV tuner with a lot of good stuff
    that's about the size of a Bluetooth dongle and I'm very tempted to buy
    it but I want to make sure it'll work as it ain't cheap enough to sell
    at a fraction of the cost if it doesn't work, if you get my drift.
  2. Whinging Courier
    mb Guest
    If SP1 has been installed, then it should have USB2 support.
    mb, Oct 14, 2004
  3. It had SP1 from the factory and I installed SP2 a while back with no
    probs, so I can assume its ok then, before I wield the plastic?
  4. Whinging Courier
    Dr Zoidberg Guest
    Well you could always look at the Sony website.......
    Alex
    YZF 600
    "I laugh in the face of danger"
    "Then I hide until it goes away"
    www.upce.org.uk
    www.drzoidberg.co.uk
    Dr Zoidberg, Oct 14, 2004
  5. Whinging Courier
    Steve Parry Guest
    have a look in Device Manager and see if it says
    Universal Host Controller
    or
    Enhanced Host Controller
    the latter is USB2 support
    some machines have only USB1, some have USB2 .... some have both ;o)
    Steve Parry
    http://www.gwynfryn.co.uk
    http://www.arrivedeprived.org.uk/
    K100RS SE
    F650
    (not forgetting the SK90PY)
    Steve Parry, Oct 14, 2004
  6. Whinging Courier
    Steve Parry Guest
    PS if you examine your pc with this software
    http://www.lavalys.com/products/download.php?pid=1&lang=en&pageid=3
    it details all your hardware far better than device manager
    Steve Parry
    K100RS SE
    F650
  7. Whinging Courier
    SleeperMan Guest
    I've heard that for laptops there are some sort of adaptors which are
    connected to COM ports and then you get USB input...not sure if it's true,
    though.
    SleeperMan, Oct 14, 2004
  8. Whinging Courier
    Yeh, but that doesn't help if your Pc hasn't got a USB2 port in it.
    Muck, Oct 14, 2004
  9. Whinging Courier
    mb Guest
    Go for it.
    See http://support.microsoft.com/?kbid=312370 for more info.
    mb, Oct 14, 2004
  10. Good point!
  11. Hokey doekey.
    As it doesn't say anything that exactly matches what you've said there,
    I'll list what it does say, although I can guess the result is a good
    one. Here is the list of stuff that comes under Universal Serial Bus
    Controllers:
    NEC PCI to USB Open Host Controller
    Standard Enhanced PCI to USB Host Controller
    USB Root Hub
    USB Root Hub
    USB Root Hub
    Cheers.
  12. Whinging Courier
    Steve Parry Guest
    "Standard Enhanced " don't ya just love contradictions like that ;o)
    It may indicate USB2 but be a poorly worded description.
    For example mine says
    "VIA PCI to USB Enhanced Host Controller"
    To be sure try that software I posted ^^^ up there that'll definately
    confirm if USB2 is present
    Steve Parry
    K100RS SE
    F650
  13. Whinging Courier
    Loz H Guest
    Whinging Courier <> spewed forth the
    following...
    Thats the one. USB 2.0 ahoy..
    Loz H, Oct 14, 2004
  14. I am trying. Either the download location is very busy, I'm not
    connecting to it for some reason or it's just borked.
    I'll keep trying.
  15. The 'enhanced' bit sounds good but it is the other bit that is stopping
    me right now.
    It does sound positive, mind.
  16. Whinging Courier
    Loz H Guest
    http://www.majorgeeks.com/download4181.html
    For a couple of mirrors to that software (Everest Home Edition) that Steve
    has pointed out.
    And it does kick arse in a system-information kind of fashion. I use it
    myself when speccing out peoples PCs prior to upgrading them.
    Loz H, Oct 14, 2004
  17. Wow, what a cool prog!
    I would've posted a bit quicker but was doing benchmarks and stuff (this
    thing's a bit slow!)
    Anyway, the only thing I could see that relates to this is under
    'operating system/system drivers', are two entries, thus:
    Driver Name Driver Description File Name Version Type
    State
    usbehci Microsoft USB 2.0 Enhanced Host Controller Miniport Driver
    usbehci.sys 5.1.2600.2180 Kernel Driver Running
    and
    State
    usbhub USB2 Enabled Hub usbhub.sys 5.1.2600.2180 Kernel Driver
    Running
    Sorry for the shite formatting but I copied it dirstly from the viewing
    pane. The results look good though.
    Anyway of editing/changing things within this, like CPU and memory clock
    speed?
  18. Whinging Courier
    Steve Parry Guest
  19. Yeah, I have. Thank you :)
  20. Whinging Courier
    Catman Guest
    USB 2 devices are backawards compatible with USB 1 ports. It will work,
    just slower. I really doubt that the data rate would be an issue. Equally
    it seems unlikley that the Vaio would not have USB 2 support.
    www.cuore-sportivo.co.uk
    Catman, Oct 14, 2004
