Paging Cab
Discussion in 'UK Motorcycles' started by Higgins not @ Work, May 23, 2005.
  1. Here you can have this back...UKRMMA#23, hardly used and in excellent
    condition.
    I must say it's very nice to be able to argue with Radio 4 again,
    particularly the guy today who was claiming that 4x4's are essential
    for "a 21st century lifestyle".
  2. Higgins not @ Work
    Cab Guest
    I get Radio 4 over here. Occasionally. When the sun spot acitity is
    just right...
    Cab, May 23, 2005
  3. Cab wrote
    You can get it on the interwebby, who needs satellite dishes anymore?
    steve auvache, May 23, 2005
  4. It's great when it works. The R4 server seems to be the most in demand
    at midnight, just when I want to hear the news.
    Grimly Curmudgeon, May 23, 2005
  5. Higgins not @ Work
    Eddie Guest
    I was *well* confused this morning[0], when I dragged myself out of the
    depths of slumber to hear JaM instead of Today.
    [0] Even more confused than usual[1].
    [1] Especially for that time of day.
    Eddie, May 23, 2005
  6. I never get a chance to listen to it during the day. LW reception only
    here when I'm out and about and that's fairly crap most of the time.
  7. Higgins not @ Work
    Salad Dodger Guest
    New series starts BHM at 18:30, apparently.
    | ___ Salad Dodger
    |_\_____/_| ..75127../..18653.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
    Salad Dodger, May 23, 2005
  8. Higgins not @ Work
    Other than the origin encoder, the R4 streams are served from the
    same machines as (pretty much) all the other streams. I can't see
    from where when peak time is, but it's definitely not around
    midnight.
    Must be something else.
    ogden, May 24, 2005
  9. Higgins not @ Work
    I completely forgot about the strike, and when I turned on the radio at
    7:30 and got ISIHAC[1]
    I thought maybe there'd been a revolution or something.
    [1] or JAM - I forget which now, they were both on before and after the
    8:00 micro-news, but I forget the order.
    darsy, May 24, 2005
  10. Odd thing is; when I have trouble getting a R4 stream, the R3,2,1,etc
    streams work fine - therefore I was assuming overloading of the R4
    server. Otoh, since I don't know how it's set up, that's probably
    bollocks anyway.
    I've noticed problems when ICQ is running - but this happens even when
    ICQ is disabled.
    Grimly Curmudgeon, May 24, 2005
  11. Higgins not @ Work
    DR Guest
    There's a piece from "The Wizard Of Oz" that would be most apposite...
    DR, May 24, 2005
  12. Higgins not @ Work
    I do, and it is :)
    ogden, May 25, 2005
  13. We were somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember ogden <> saying
    something like:
    R4 server.
    So there's no queuing? Or is load shared? There must, surely, be a limit
    to how much traffic the whole streaming setup can handle?
    Grimly Curmudgeon, May 25, 2005
  14. Higgins not @ Work
    Load shared across a farm of machines. The same machines will spit
    out pretty much all the live streams (likewise all clips are served
    from the same kit, whether radio4 or 1xtra, whatever) with a few
    exceptions.
    As to a limit, yes, there is. But unless something huge is kicking off
    (eg. Olympics, Diana's death, world cup final - certainly not the news
    at midnight!) you won't find it.
    There are three main farms in the UK. One legacy Realmedia, where each
    box can pretty much saturate 100Mbps FE, and there's probably about 80
    of them, plumbed across three or four gig circuits to a fat core. One
    legacy Windows Media, which never (afaik) maxes out. And the new farm
    put in for the Olympics, where each box can spit out about 700Mbps of
    streams, and they're wired straight in to the fat core (we're talking
    bonded ten gig Ethernet on 720Gbps chassis, not a couple of netgears
    and some damp string)
    I don't think that gives away anything likely to get me a bollocking,
    but should hint at the capacity. And you really really really aren't
    going to stress it with the midnight news.
    That said, you *may* find (depending on your ISP) that you're served
    from the farm in New York, which is a bit different, but still
    shouldn't max out at 7pm.
    ogden, May 25, 2005
  15. Must be something my end then. It's odd that only R4 is affected -
    possibly a port issue, do you think?
    Grimly Curmudgeon, May 26, 2005
  16. Higgins not @ Work
    Same port, same servers, different stream (like requesting a different
    file from a web server - it's still port 80. Or not, as it were.)
    ogden, May 26, 2005
