Paging Beemer owners
Discussion in 'Classic Motorbikes' started by Rasman99, Jan 23, 2004.
  1. Rasman99
    Guest Guest
    The point is to know what you're taking on. It's like buying anything
    mechanical on eBay - you work out the risks of something not being as it
    should be, the costs of putting it right, and bid accordingly. Or at
    least I do (and I know you do too). I'd rather know about something, and
    then be able to choose to ignore it, than not.
    Regards,
    Simonm.
    Guest, Jan 24, 2004
  2. Rasman99
    Well with 23k on it that shouldn't really be an issue.
    The rear crank seal isn't difficult to repair in situ IYKH, the gearbox is
    another matter.
    Hog, Jan 24, 2004
  3. Rasman99
    Hog was seen penning the following ode to ... whatever:
    Agreed, but you never know.
    You still have to take the 'box out, don't you? That's at least a lot
    of hassle, so I'd try to get some money knocked off the price.
    Timo Geusch, Jan 24, 2004
  4. Rasman99
    What's special about the spanner?
    sweller, Jan 24, 2004
  5. Rasman99
    It has little flanges that locate into the fins on the nut. More special
    tool than spanner.
    www.nithburgcycle.com/bmw/tools.jpg
    Hog, Jan 24, 2004
  6. Not for the power.
    There is that.
    pseudoplatypus, Jan 25, 2004
  7. We-ell, it's geared so it jut redlines in top, so yes, ISWYM about the
    power, but IMHO if they'd just geared it up so it wouldn't pull the
    redline in top it would make it a bit more relaxed at speed, and more
    economical.
    It is a touring bike after all.
    Some owners gear them up using a different crownwheel assembly. OK, so
    you lose a bit of top-gear driveability, but wtf.
    The 800 engine itself is much nicer than the 1000cc ones, IMHO.
    The Older Gentleman, Jan 25, 2004
  8. Rasman99
    The Older Gentleman was seen penning the following ode to ... whatever:
    AFAIK the usual mod is to fit the crownwheel assembly from the
    unfaired one, although that might be a bit too high geared.
    That it certainly is.
    Timo Geusch, Jan 25, 2004
  9. Rasman99
    What utter tosh, it's an underpowered shed!
    On the subject, BMW are launching an all new 1200cc boxer engine according
    to MCN (spit) with a balancer shaft and lots less weight/more power. An
    R1200S boxer cup along those lines might tempt me back.
    Hog, Jan 25, 2004
  10. Yes, I was looking at the cutaway of that, with all those chains
    twirling around inside it, and wondering how long they'd last.....
  11. Rasman99
    Guest Guest
    Why? Perfect primary balance (supposedly) - one reason for a flat twin,
    shirley? Or are they admitting to something else...
    The "less weight/more power" bit sounds nice though.
    Regards,
    Simonm.
    Guest, Jan 25, 2004
  12. Rasman99
    The BMW twin engine design has a rocking couple due the the offset
    crankpins.
    Hog, Jan 25, 2004
  13. Rasman99
    I did wince for a moment but the K camchain didn't give problems and the
    oilheads have been ok in that respect AFAIK. I guess chains are considered
    quieter in these fucked up times.
    Hog, Jan 25, 2004
  14. Rasman99
    Guest Guest
    Good point. But it sounds hard to balance that out with yet another
    shaft. There ought to be some way of adapting the Harley approach for a
    flat twin (he said, struggling to think of a way to have two big ends
    180deg apart but on the same lateral axis), or is it just Germanic
    pride?
    Still sounds like a bit of a dog's...
    Regards,
    Simonm.
    Guest, Jan 25, 2004
  15. Forked conrod, like Harley do.
    It does to me too. It sounds like they've enlarged the engine beyond its
    intended limits, at 1200cc, (shades of the od boxers) and realised that
    the things shudder nastily.
    1.2 litres is a bit big for any twin, IMHO. I know some vees go a lot
    bigger, but they use rubber mounts etc...
  16. Rasman99
    Guest Guest
    I think that would shake itself apart in no time - you'd have to fire
    the cylinders alternately. In order to work, you'd have to have the
    cranks diametrically opposite, so that you firing strokes coincided.
    I thought Harley only get away with it coz it's a V-twin with a
    correspondingly odd ignition timing (and they rubber mount, etc.).
    The other intersting (nasty) thought is that, even if you balanced out
    the gyro twisting force (two contra-rotating masses ought to cancel
    out), it'd still want to keep going in a straight line no matter what
    you did with the bars or counter-steering. Nasty trade-off: a flywheel
    gives you smoothness, but also a tendency to ignore corners.
    Regards,
    Simonm.
    Guest, Jan 25, 2004
  17. Rasman99
    Pause and consider the concept of two 600cc pistons flying left together
    now right
    Ok, you have been flung 20ft from the bike, what now
    Hog, Jan 25, 2004
  18. Conside the concept of pistons flying outwards and inwards, together?
  19. It would be a bit over-relaxed getting to speed. As it is, the gearing puts
    the ratios closer together (and easier to change), which is good as going up
    and down the box is the order of the day if progress is to be made. It may
    only pull the ton, but it'll do that up hill and down dale even with madam
    on the back.
    The ratio on the RT is 3.36:1, the naked R80 is 3.20:1, and the R100RS/RT is
    3.00:1. If I decided to put up with top-gear sluggishness and fit an R100
    ratio, I could get a secondhand bevel box from Motorworks for £240, or a
    recon exchange for £225. If this gave me an improvement of, say, 5mpg
    average from 35 to 40, I'd save about £150 a year. However, I don't believe
    I'd see that much of an improvement, because I'd only be using less fuel
    while cruising at a sensible speed. The rest of the time I'd be using more
    fuel because I'd be in a lower gear. Of course, if I slung on twin-plugged
    heads to up the performance, it might work better - but It would be three
    years to break-even, and how much money am I going to throw at this SOB?
    Well, that's all right, then.
  20. On a single crank-pin, YTC?
