Paging Apple bods
Discussion in 'UK Motorcycles' started by rufty_tufty_hoolythug, Oct 19, 2009.
  1. A colleague has a new iMac with MacOS X Leopard installed. The old
    machine was a white iMac PowerPC with OSX Panther. The migration
    assistant was used to transfer all there settings from the old to the
    new machine.
    Everything mostly worked or could be made to work. One thing just
    won't though. When using "Connect to Server" to connect to a samba
    share it just comes back with "you have entered an incorrect username
    or password".
    Now, the username and password are correct. The machine with Panther
    on it will connect and I can ssh to the server. The difference that I
    see with the two OSes is that the window that opens to connect to the
    samba share on Panther has a workgroup entry as well as username and
    password entries. The Leopard system simply asks for a username and
    password.
    So, how to get the Leopard machine to connect? Is there a way of
    setting or entering the workgroup? Is not having the workgroup
    actually the problem?
  2. rufty_tufty_hoolythug
    Tim Guest
    In message
    [snip]
    Have you told the Samba server about this new machine?
    Tim, Oct 19, 2009
  3. I shall put on my Jobsworth hat and say, "It's not up to me to do
    that, that's handled by another department." But yes, the chaps in
    charge of the Samba server were contacted when I originally found the
    problem, so in a roundabout way they do know about it.
  4. rufty_tufty_hoolythug
    Ian White Guest
    Is the Samba server in a domain and do you have the user prefixed with
    the domain?
    Ian White, Oct 19, 2009
  5. The information I have is that the server is a Unix server. I can ssh
    in quite happily and see all the users files. It just won't work with
    the "Connect to Server" on the Mac, but this is what the user needs as
    ssh means nothing to them.
    rufty_tufty_hoolythug, Oct 20, 2009
  6. rufty_tufty_hoolythug
    prawn Guest
    IANA Mac expert but sshfs should work on a mac, surely.
    prawn, Oct 20, 2009
